  • Member For: 20y 7m 15d
I think you'll find that the cars that have thrown legs out of bed, that the factory assembly line workers forgot to do up one or both of the rod bolts nuts or that the forging or casting metal was ridden with impurities that they have now realised, cause many NA's have done the leg out of bed too, but the problem seems to have resolved on later builds
<{POST_SNAPBACK}>
Interesting point.
HYPOXR, how old was your car when the engine blew? What is the manufacture date?
<{POST_SNAPBACK}>
Given the fact its a 6 speed, I would assume it is a Mk2, which makes it very young.
I may be wrong though, I was once before. :lol:
  • Replies 66
Posted Images
  • Forum Superhero
  • Member For: 21y 5m 3d
Valve spring and clutch for me at 260rwkw
I am now over 300rwkw (310rwkw) but have dialed it back down to 300rwkw as I have concerns in the strength of the T5 box.
I will keep you posted fingers crossed. The rest of the car is running stock components, so far so good. :blink:
  • Member For: 20y 4m 25d
<{POST_SNAPBACK}>
Interesting point.
<{POST_SNAPBACK}>
The manufacture date is Nov 2004. It is a MKII with the factory 6 speed.
<{POST_SNAPBACK}>
Interesting point.
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
No you are right Eugene. My ute is in Lightning Strike as well. :blink:
<{POST_SNAPBACK}>
To be honest JB I dont think that the factury 6 speed is any better. Sometimes I get gear crunching going into third. I thought it was just my driving but my brother has the same problem when he drives it. I dont think the 6 speed can handle much more power but I could be wrong. :spoton:
  • Member For: 21y 5m 4d
Onya Steve...good topic mate.
Well mine's like a barina compared to some of the more highly modded T's out there now, but I was one of the first to go over 300rwkw, and here's what I found.
At 310 rwkw, my auto lasted 6 months before getting very noisy, slipping and eventually refusing to find reverse.
I got a a new auto rated at 360rwkw. I then went to over 330 rwkw, and the power was handled easily by the box. I dont drive my car very hard, but when I do, I do it properly. There are 3-4 times per day when I nail the throttle for no more than 5 seconds - at various speeds. That's the extent of my gard driving (and usually all I need to blow away any competition).
No detonation at all, no diff problems at all...hell I dont even get driveline shunt!.
If I were to keep my car, I would go up to 360 rwkw without doing the rods and pistons....for my driving anyway.
Hope this helps.
  • Forum Superhero
I will keep you posted fingers crossed. The rest of the car is running stock components, so far so good. :hrmm:
To be honest JB I dont think that the factury 6 speed is any better. Sometimes I get gear crunching going into third. I thought it was just my driving but my brother has the same problem when he drives it. I dont think the 6 speed can handle much more power but I could be wrong. :kissmy:
Yeah, I am not sure myself :k24t:
All I know is the T5 is not overly strong with various members getting different results out of them.
I was looking at a T56 as Ben from Mal Woods and others believe that it will hold the power alot better than the T5.
Bruce is now running 390rwkw and has installed a T56 and it seems to be handling that power well, so from that and a couple of othersw experiences with the T56 I would say it's the next step above the T5, as No one has got past 330rwkw with the T5.
With that being said the T56 whilst seeming to be able to handle the power better than the T5, still has very similar issues with bearing noise, not wanting to go into gear and so on. Maybe just a trait again of some of the :ermm: ford put in their cars.
If I was you try changing your gearbox oil to Castrol Transmax Z, this will no doubt improve your shift and I would suggest help it engage the problem gear you are having. This is what most people including myself have done.
There is a thread on which is the best oil to use under Mal Wood Autos, have a read. :w00t2:
  • Member For: 21y 6m 3d
I think that APS' current test mule HGAG falcon xrt still uses the T5 transmission and it has over 500rwkw. I believe they mention the secret is with the clutch but can't confirm. Perhaps this car is only used for dynos and testing so it doesn't take much harsh treatment...
Have you tried a heavy duty clutch JB?
I will keep you posted fingers crossed. The rest of the car is running stock components, so far so good. :ermm:
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
Yeah, I am not sure myself :huh:
With that being said the T56 whilst seeming to be able to handle the power better than the T5, still has very similar issues with bearing noise, not wanting to go into gear and so on. Maybe just a trait again of some of the :huh: ford put in their cars.
<{POST_SNAPBACK}>
Thanks for the advice JB. :hrmm:
I might get the mechanic to drop the gearbox oil at the next service and try out the Castrol. :k24t:
  • Forum Superhero
hey Steve, that car is an auto form the last time I checked? :w00t2: Happy to be corrected.
Then again if he is running 500rwkw odd then with a T5 I am very interested on how he has! :kissmy:
Mate have already got a cushion button clutch in, the factory one was slipping at 260rwkw and scorched the flywheel. The one currently in will be coming out in the next week or so as the centre is too strong for the car. Another similar setup will go in with a softer centre.
Pic of what is currently in the car.
