  • SportCompact.biz
  • Member For: 22y 2m 21d
I believe that he is saying the factory computer will sort out the fueling and ignition timing.. pesonally im not entirely convinced they would have mapped every point above stock boost perfectly as the car was never designed to run that much boost.. then again if they were running higher boost during testing then they may have tuned the car with that much boost and left the mapping in the ECU.. either way sounds plausible really. Maybe street tuner can answer this :)
  • Replies 69
Posted Images
  • Mal Wood Automotive
  • Member For: 22y 6m 26d
  Fijneman said:
Ever heard of cryogenic threating?
I assume you are talking about nitriding. These gears have already been heat treated and shot peened. Further attempts to treat them may be a backward step. You have to drop the engine to get the gearbox back in, so it becomes a big job. Re the thermal issues, how many T5's have you cooked? I personally have done three in my car, and have seen inside many others. A highly stressed T5 will run at 240F, and even when you select oil to survive this the box still dies.
  • Member For: 22y 5m 9d
  Fijneman said:
I assume if you’re trying to crack the serial programming protocol, you are an electrical engineer?
No I am not an electrical engineer. Since you seem to have a fascination for engineering backgrounds, and claim to have one, then understand that embedded system coding/decoding is more the job of an electronic engineer. Putting it simply son, Elecs work with the big stuff :huh:
However, having studied both B.Mech Eng and Ass.Dip Comp Science at Tertiary level (USA), I can tell you now that when it comes to reverse engineering proprietary protocols that are serially encrypted, there is no training school. Rather there is experience. Experience I have, with decoding automotive manufacturers low level code since 1992 in a commerical environment. :geek:
Like I said, rather than trying to gain status for your qualification (and it is something to be proud of) by sniping at others, please put your engineering skills to good use and contribute to the conversation in a productive and mature manner. The others you represent here do not look any better for your attempts to bring down this thread :thumbsup:
Guest Fijneman
  • Guests
  CnC said:
I think its obvious that the gearbox is not going to withstand 1000ft/lb of torque, but as you claim to be from an engineering background I'm sure you would know that most components are rated conservatively in terms of what they can really handle.. and OEM's are naturally very conservative to be 110% sure that few warranty claims are made.
Although the gearboxes may be rated at 450nm or whatever, keeping the fluid temperates in check will help greatly when pushing them slightly over their rated specs by 30-35%.
Yes it is obvious, but I was making a point that thermal management isn't your savour, there is still physical constraints on the gearbox. Yes, most components that are mission critical ie for safety well be over engineered.
Guest Fijneman
  • Guests
Ah, what are you trying to imply with this? I hope you aren’t implying I'm on someone else’s payroll?
If you think my questions are "sniping at others" then I suggest you learn to take a little constructive criticism. Most of the questions I asked you where either never answered or feed rubbish responses. This is why I asked for your qualifications, as you were coming off to me as a glorified marketing spokesperson. I believe I have been very mature about this, in that I have never sworn or made this personal. If I remember correctly the first answer you gave me in the TSI thread wasn't exactly friendly.
If I have somehow infringed upon your territory then by all means I'm sorry and I'll leave you to your constituents.
  • Member For: 22y 5m 26d
Now now guys. I'm sure you are really impressive in the tackle department.
The rest of us who are not engineering masters wouldn't mind at all learning from a reasoned debate. No-one has to agree. Just direct your energies on the topic rather than sniping at each other.
Thermo dynamics? Your talking about the wheather aren't you.
Say can either of you tell me why my car gave out and miss-fired under power? Then worked when turned off then on?
And no street tuna, I'm not a mod or admin. Just someone who spends more time around here for his own good.
  • The Noble Leader
  • Administrator
  • Member For: 22y 7m 21d
I totally agree with AMoffat. Lets try and keep it this way instead of trying to prove who is the better technically, and concentrate more on imforming people via more educational posts.
  • SportCompact.biz
Ok so you think you can have a debate without proving which solution is more technically advanced? Isnt this completely counter-intuitive considering that this is exactly what the point of the debate is!?!
What I believe you mean is without getting personal, a technical discussion about what is better/worse is completely productive and the entire point!
  • Poison Fish. Poison Fish. TASTY FISH!!!
  • Member For: 22y 2m 18d
Dont all you lucky buggers just want your XR6T's to go alot faster?I know I'd want mine to, I wouldnt care who was doing it.Just as long as it was tested and reliable....and of course FAAAAAAST...
As someone who has followed the development of "go fast" modifications for the XR6T for some time, I have to say that I enjoy most of the debate posted on this topic.
I do however agree with Chris CJF077 that personal attacks and flaming is unbecoming for this site, and ultimately you should all respect the healthy competitive environment, which I am sure will lead to a range of solutions for our XR6T, some good, some maybe less good.
It's up to us as owners to sort through the facts and fiction being posted here and on companies web pages, before making a decision on purchase.
The more informative you are on the product you promote, without cra**ing on other developments, the more we as a group will be willing to read your findings, and ultimately make a choice on a supplier.
Keep up the good discussions - BUT PLEASE KEEP IT CLEAN AND INFORMATIVE :idea:
