turb06 Dark Knight Mafia Member No. - 666 Member 3,667 Member For: 21y 11m 24d Location: Toowoomba Posted 04/03/05 02:58 PM Share Posted 04/03/05 02:58 PM 4 psi is normal for Peak power boost figures. You may see it hit 5/5/6psi early in the rpm range.Your rwkw figure is normalA lot of tuners supply only their peak power boost figure which is a little misleading. Peak power boost is usually 2-3psi lower than peak boost itself going by what I have seen.<{POST_SNAPBACK}>Very true.Dazza. Link to comment Share on other sites More sharing options...
YOOT Member 1,201 Member For: 21y 7m 30d Location: Birkdale Posted 05/03/05 12:00 AM Share Posted 05/03/05 12:00 AM My boost guage shows 4spi in 1st gear, I think the needle can't move fast enough and by the time I hit 5000rpm the boost is back to 4 anyway, which is where it is supposed to be (ie, not embarissing the GT kind of boost).In second and thrid were the car takes a while to move throught the rev range the needle goes all the way to 6psi and comes back to about 5psi at redline.I have the reflash that fixes over boost or whatever, and the car is definately not as peaky as it was, much smoother and uses more fuel. Thank god for edit, I'll get that I think. Link to comment Share on other sites More sharing options...
Guest PSIXR6 Guests Posted 11/03/05 01:24 AM Share Posted 11/03/05 01:24 AM Just had my car on the dyno today, and was quite happy with the results.Car is stock apart from 2nd CAI, Center muffler removed and KnN Airfilter.Had 3 pulls resulting in;191.5kw194 kw193.2 kwAs u can see the boost curve was all over the place, ranging between 4.3 up to 5.6 psi.Fairly healthy donk though, I think. Now For the EDIT ~Allen Link to comment Share on other sites More sharing options...
RAPHOON Donating Members 1,776 Member For: 21y 7m 22d Posted 11/03/05 03:15 AM Share Posted 11/03/05 03:15 AM I've seen that boost curve on a number of standard cars, including mine. Link to comment Share on other sites More sharing options...
