stang Donating Members 1,353 Member For: 20y 9m 24d Location: Melbourne Posted 02/03/05 12:36 PM Share Posted 02/03/05 12:36 PM I am looking at the Pivot gauges, they ligh up blue.I am getting the Boost gauge but should I get the oil temp or oil pressure.which one is more relevant and why.What do u think of Pivot there japaneese and are aparently pretty good they have stepper motors and are electrical gauges. Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 8m 30d Gender: Male Location: Sydney Posted 02/03/05 11:46 PM Share Posted 02/03/05 11:46 PM Stang,Oil Pressure is far more important than temp. Pressure will determin if you motor lives or dies, where the Temp is for when the oil will break down. I have Boost and Oil pressure, and after a serious run the pressure will drop below normal as the oil temp is higher, this is because the oil thins out the hotter it gets.I do not know about these gauges you are planning on getting, but if there are electronic, I say go for it. Link to comment Share on other sites More sharing options...
KBB Member 55 Member For: 20y 1m 22d Posted 03/03/05 12:53 AM Share Posted 03/03/05 12:53 AM That's a big call cause if either of those goes out of acceptable range your engine will be f*cked. If you were on a curcuit at high rpm for long enough the oil pressure would remain acceptable even where the oil was superheated depending on the efficiency of the oil pump. Link to comment Share on other sites More sharing options...
Turbo6man Lifetime Members 4,084 Member For: 22y 1m 3d Gender: Male Location: South Coast NSW Posted 03/03/05 01:35 AM Share Posted 03/03/05 01:35 AM Zap, I'd have to disagree for a couple of reasons.Firstly the engine already has low oil pressure warning so you are just duplicating in a sense.Secondly, esp with a turbo motor the temp of the oil is more relevent to the safe operation of the turbo than pressure. If the temp rises dramatically you KNOW you are going to be losing pressure in any case BUT if pressure is low it is not necessarily telling you what the temp may be ie. you can have heat damage caused to components BEFORE the pressure indicates a problem. Link to comment Share on other sites More sharing options...
PLAYRZ Donating Members 333 Member For: 19y 9m 6d Gender: Male Location: VIC Posted 03/03/05 01:35 AM Share Posted 03/03/05 01:35 AM I have also fitted both boost (mechanical) & oil pressure (electrical) gauges to my T. I used the Blitz BLM Racing Meters.These gauges can be ordered through your local Autobarn store. Link to comment Share on other sites More sharing options...
fordboy1981 Donating Members 2,075 Member For: 21y 9m 26d Gender: Male Location: Sydney, NSW Posted 03/03/05 01:54 AM Share Posted 03/03/05 01:54 AM Zap, I'd have to disagree for a couple of reasons.Firstly the engine already has low oil pressure warning so you are just duplicating in a sense.Secondly, esp with a turbo motor the temp of the oil is more relevent to the safe operation of the turbo than pressure. If the temp rises dramatically you KNOW you are going to be losing pressure in any case BUT if pressure is low it is not necessarily telling you what the temp may be ie. you can have heat damage caused to components BEFORE the pressure indicates a problem.Exactly...Pressure is relevent, but there's already a light on the dash when it gets low! Oil temp is more important. It has been describe by many a tuner that this could become a problem for the XRT. The likely hood of a lightly modded XRT (around 280rwkws) loosing oil pressure is pretty slim, however the oil temp going through the roof if your circuit racing is very likely...just my 2cDave. Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 8m 30d Gender: Male Location: Sydney Posted 03/03/05 02:06 AM Share Posted 03/03/05 02:06 AM While I think the Temp is very important, I think the pressure is more so.With the oil Pressure light the same could be said about a high oil temp, as it causes the XR6T to go into limp home mode, and I think a light will also show up on the dashboard, so the iddiot light statement is not relevent.Yes there is an iddiot light on the dash, but it is not very sensative. I have had my pressure drop below 500 kpa, this triggered the pressure gauge warning light, but the iddiot light did not light. The pressure was below acceptable, and would have caused damage if left long enough.If I was to get another gauge it would be oil temp Link to comment Share on other sites More sharing options...
fordboy1981 Donating Members 2,075 Member For: 21y 9m 26d Gender: Male Location: Sydney, NSW Posted 03/03/05 02:44 AM Share Posted 03/03/05 02:44 AM While I think the Temp is very important, I think the pressure is more so.With the oil Pressure light the same could be said about a high oil temp, as it causes the XR6T to go into limp home mode, and I think a light will also show up on the dashboard, so the iddiot light statement is not relevent.Yes there is an iddiot light on the dash, but it is not very sensative. I have had my pressure drop below 500 kpa, this triggered the pressure gauge warning light, but the iddiot light did not light. The pressure was below acceptable, and would have caused damage if left long enough.If I was to get another gauge it would be oil tempNot the case, if the car is modded with a chip, the limp-home mode will very rarely work...As for the idiot (only 1 'd') light, it would be set on a ford setting, so it would be set to come on when ford thinks it's too low...so clearly they don't believe 500Kpa is low enough...Pressure is not as relative as temp...oh bugger it, just GET BOTH!!! have three of them, boost, oil temp and pressure!Dave. Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 8m 30d Gender: Male Location: Sydney Posted 03/03/05 04:19 AM Share Posted 03/03/05 04:19 AM Dave,I just wished they made a 3 pod holder......the I could fit it in.Any idea where to fit a 3rd gauge ?I feel like a idiot for my badd spulling Link to comment Share on other sites More sharing options...
Cro Flower Power Lifetime Members 6,114 Member For: 22y 1m 3d Gender: Male Location: Sydney Posted 03/03/05 04:24 AM Share Posted 03/03/05 04:24 AM Dave,I just wished they made a 3 pod holder......the I could fit it in.Any idea where to fit a 3rd gauge ?I feel like a idiot for my badd spulling <{POST_SNAPBACK}>Low boost performance has made a special mount for a boost guage. That way you can replace boost guage in your pod with oil pressure.Speak to Jeff, I think he's the CEO Link to comment Share on other sites More sharing options...
