Goose 00-XRG / 006-FPV Donating Members 530 Member For: 22y 7d Gender: Male Location: Brisbane, QLD Posted 27/02/05 12:30 AM Share Posted 27/02/05 12:30 AM My dealer wanted to sting me $80 as well. I'll go down to SuperDump today and buy the tool and give it a go.Adam Link to comment Share on other sites More sharing options...
xrturb god bless my kids Member 611 Member For: 20y 7m 18d Gender: Male Location: claremont meadows, sydney Posted 27/02/05 12:34 AM Share Posted 27/02/05 12:34 AM they done it but I refused to pay it on the grounds my car only travelled 9000km Link to comment Share on other sites More sharing options...
cro142 Member 25 Member For: 21y 1m 7d Location: Brisbane Posted 27/02/05 01:18 AM Author Share Posted 27/02/05 01:18 AM (edited) Guys,Thanks for all the suggestions.I feel I am now armed with enough info to give it a go this arvo.It sounds like it is a job best left to the dealer, but the trouble is I need to have it right before tomorrow morning, so I'll give it a try.Thanks again.Peter Edited 27/02/05 01:19 AM by cro142 Link to comment Share on other sites More sharing options...
Goose 00-XRG / 006-FPV Donating Members 530 Member For: 22y 7d Gender: Male Location: Brisbane, QLD Posted 27/02/05 02:27 AM Share Posted 27/02/05 02:27 AM But before you even try to adjust it at that point you have to set the inside adjuster at the handbrake lever to be right off ie. undo the nut right to the end of the thread.I've spent like an hour looking for this adjustment nut inside the car, but can't find anything that resembles what it should look like. Any ideas what panels I have to take off, or if there is an easy way to get the handbrake lever boot off? I've gone and gotten my adjustment tool from SuperCheap, and will just give the wheel adjustment a go now I think.Guys,Thanks for all the suggestions.I feel I am now armed with enough info to give it a go this arvo.It sounds like it is a job best left to the dealer, but the trouble is I need to have it right before tomorrow morning, so I'll give it a try.Thanks again.PeterHow are you coming along Pete?? Link to comment Share on other sites More sharing options...
cro142 Member 25 Member For: 21y 1m 7d Location: Brisbane Posted 27/02/05 04:06 AM Author Share Posted 27/02/05 04:06 AM (edited) Well, here's the story:Put the car up on jacks, removed the wheels, and removed the rubber grommet on the face of the disc. So far, so good.Trouble was, I could not find an adjuster wheel in there to work on...My son had the rear wheels off his NL Fairlane, so I removed the rubber grommet from one of his discs - and sure enough I could clearly see an adjusting wheel in there for the handbrake shoes. So, even though the rear brake systems of both the BA and the NL look identical from the outside, there must be an internal difference. Damned if I could find an adjuster wheel on the BA.Dead end it seemed.While crawling around under the car, I found the handbrake lever cable adjuster. It is located up above the big muffler in front of the axle, just beside the tailshaft.It's not very easy to get to, but possible.(Goose, this answers your question above).I did an adjustment on the cable length, and that has fixed the problem, at least temporarily. Edited 27/02/05 04:07 AM by cro142 Link to comment Share on other sites More sharing options...
Goose 00-XRG / 006-FPV Donating Members 530 Member For: 22y 7d Gender: Male Location: Brisbane, QLD Posted 27/02/05 04:42 AM Share Posted 27/02/05 04:42 AM Hey bud I went one step further than yourself. Got the grommet off and couldn't find the adjuster wheel, so thought bugger this, and I ripped the disc off as well. Just undid the 2 main caliper nuts and it came off (with some force). see attached pics.The first pic the bottom arrow shows the adjuster wheel, and top arrow show the access hole that the grommet lines up with. Either Ford have an extra special adjustment tool, or they take off the disc's as well.Second pic shows me actually adjusting the handbrake. Link to comment Share on other sites More sharing options...
cro142 Member 25 Member For: 21y 1m 7d Location: Brisbane Posted 27/02/05 10:00 AM Author Share Posted 27/02/05 10:00 AM Ripper, Goose - you've done it !!I can see now why I could not see the adjuster wheel through the hole.I actually did try to remove the disc - I took the caliper off, but could not get the disc to budge. I whanged it as hard as I dared, but it was rusted on solid.Anyway, now we know how to do it.Cheers,Peter Link to comment Share on other sites More sharing options...
Goose 00-XRG / 006-FPV Donating Members 530 Member For: 22y 7d Gender: Male Location: Brisbane, QLD Posted 27/02/05 11:04 AM Share Posted 27/02/05 11:04 AM Yeah I had a pretty hard time getting the disc off, it was just that the drum brake was applying pressure to it. It had to come off perfectly even.I only did the one side, and it was way too much effort. I might just shop around and find the cheapest dealer to adjust it for me properly.Adam Link to comment Share on other sites More sharing options...
