cro142 Member 25 Member For: 21y 1m 7d Location: Brisbane Posted 26/02/05 03:54 AM Share Posted 26/02/05 03:54 AM I need to adjust the handbrake on my XR6T sedan, but when I went looking I could not find where to do it !!Its a different system than I'm used to, so could someone please tell me where the adjustment is located ??Thanks. Link to comment Share on other sites More sharing options...
Goose 00-XRG / 006-FPV Donating Members 530 Member For: 22y 7d Gender: Male Location: Brisbane, QLD Posted 26/02/05 04:19 AM Share Posted 26/02/05 04:19 AM Hey chief, there's a bodgy way to adjust it, and there's the right way to adjust it.Under the car you'll find the park brake cable, where it splits into 2 you "should" be able to adjust it there. But this won't last for long. The right way is to pull off rear wheels, pull off rear brake discs and inside the rear disc you'll see a drum kind of setup for the park brake.that's my understanding of it anyways, haven't done it on my car yet, but have to pretty soon.Adam Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 9m 28d Gender: Male Location: Sydney Posted 26/02/05 04:31 AM Share Posted 26/02/05 04:31 AM Close Goose,You do not need to pull the wheels off.On the brake backing plate you will find a small rubber grommet. You need to remove this and inside there is the handbrake ajustment wheel. It is a toothed wheel that requres a special tool to ajust. It looks like a bent flat blade screwdriver....and its called a handbrake ajuster tool, about $10 from an auto store I would recommend that you get it done professionally as it can be a b**ch of a job without a hoist. You also need to know how to move the ajuster and how far to ajust to be right. I have never done a XR one, but done many in my time and some are easy, but from my understanding, the XR one sux.It is a job best left to aprentices Link to comment Share on other sites More sharing options...
TBO240 Member 628 Member For: 21y 4m 7d Gender: Male Location: Geelong Posted 26/02/05 04:58 AM Share Posted 26/02/05 04:58 AM Close Goose,You do not need to pull the wheels off.On the brake backing plate you will find a small rubber grommet. You need to remove this and inside there is the handbrake ajustment wheel. It is a toothed wheel that requres a special tool to ajust. It looks like a bent flat blade screwdriver....and its called a handbrake ajuster tool, about $10 from an auto store I would recommend that you get it done professionally as it can be a b**ch of a job without a hoist. You also need to know how to move the ajuster and how far to ajust to be right. I have never done a XR one, but done many in my time and some are easy, but from my understanding, the XR one sux.It is a job best left to aprentices<{POST_SNAPBACK}>isnt that the method for a drum brake Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 9m 28d Gender: Male Location: Sydney Posted 26/02/05 05:06 AM Share Posted 26/02/05 05:06 AM The XR's have a small drum for the handbrake as far as I know. I am not 100% as I have never done anything on the rear of my car.If anyone has done this job before, please correct me if I am wrong Link to comment Share on other sites More sharing options...
Goose 00-XRG / 006-FPV Donating Members 530 Member For: 22y 7d Gender: Male Location: Brisbane, QLD Posted 26/02/05 06:33 AM Share Posted 26/02/05 06:33 AM Yeah it's definately a drum assembly, that's why they suck so much. My old EB, when you pulled the handbrake it squeezed the rear calipers. Much nicer. Don't think it ever needed adjusting. Link to comment Share on other sites More sharing options...
crisso . Donating Members 1,199 Member For: 21y 28d Location: Sydney Posted 26/02/05 06:34 AM Share Posted 26/02/05 06:34 AM Ford service did it for me I think it cost me something like $38, worth it for me, I would have no clue.They did take the rear wheels off FYI. Link to comment Share on other sites More sharing options...
mickq Member 740 Member For: 21y 7m 20d Posted 26/02/05 01:33 PM Share Posted 26/02/05 01:33 PM When I dropped past my dealer recently, they confirmed it does require to take the rear wheels off to do it properly. No idea if there is another temporary way to do minor adjustments, but it would seem that whoever mentioned the need to take the rear wheels off is correct. Link to comment Share on other sites More sharing options...
Turbo6man Lifetime Members 4,084 Member For: 22y 2m 2d Gender: Male Location: South Coast NSW Posted 26/02/05 10:58 PM Share Posted 26/02/05 10:58 PM Close Goose,You do not need to pull the wheels off.On the brake backing plate you will find a small rubber grommet. You need to remove this and inside there is the handbrake ajustment wheel. It is a toothed wheel that requres a special tool to ajust. It looks like a bent flat blade screwdriver....and its called a handbrake ajuster tool, about $10 from an auto store I would recommend that you get it done professionally as it can be a b**ch of a job without a hoist. You also need to know how to move the ajuster and how far to ajust to be right. I have never done a XR one, but done many in my time and some are easy, but from my understanding, the XR one sux.It is a job best left to aprentices<{POST_SNAPBACK}>Close Zap,The grommet is in the front face of the disc/drum hub and you DO have to take the wheels off.But before you even try to adjust it at that point you have to set the inside adjuster at the handbrake lever to be right off ie. undo the nut right to the end of the thread.As far as the adjustment point above the diff is concerned you can forget it as I have never been able to find a way of reaching it while the diff is in the car.Basically it is a b!tch of a job if you aren't sure what you are doing. It is worth the dollars to get your dealer to do it if you have any doubts. Link to comment Share on other sites More sharing options...
xrturb god bless my kids Member 611 Member For: 20y 7m 17d Gender: Male Location: claremont meadows, sydney Posted 26/02/05 11:04 PM Share Posted 26/02/05 11:04 PM took mine into ford to do and they tryed to charge me 80 dollars ..told them to stick it Link to comment Share on other sites More sharing options...
