  • Member For: 21y 5m 18d
  stardust said:
2 powersteering coolers ?
Didn't they install auto coolers with some of the tow packs ?
Ken
<{POST_SNAPBACK}>
Now I am confused :spoton:
Does every T have a tranny (auto) cooler or was it only fiited with a tow pack?
P.S. I am interstate atm and don't have my car with me so I can't check.....
  • Replies 21
  • In Your Face
  • Member For: 22y 1m 8d
  stardust said:
Mine is a 04/04 build and its above the intercooler.
Not real smart if its in front of the intercooler, as heat from it, will pass on to the intercooler.
Ken
<{POST_SNAPBACK}>
Mine is in between the radiator and condenser :spoton:
  • FORD FORD FORD
No T's have a tranny cooler (tow pack or not,) other than the excuse for one they have running through the radiator, early T's ran one below the IC & another in front of the condenser, later models run only one in the top posy but twice the length of the early jobby.
The later one is available from Ford for about $150+, it can replace both the ones in an earlier model & leave ample room down under the IC for a Trans cooler. Hope this helps, I have done it to mine last week as have some others
Scotty
Scotty
<{POST_SNAPBACK}>
Thanks Scotty,
It looks like an after market one is the way to go...
CutSnake
  • Team Grandpa Qualified
  • Member For: 20y 2m 4d
Just checked my May 04 T.... auto trans cooler is via the radiator (do you reckon that would heat it up or cool it down?? Anyone know the temp gradient differential from one to the other?), with power steering cooler in front of the radiator above the intercooler.
So - with the general concensus being a cooler is a must with anything that's even mildly warmed - what are the options? The guys I spoke to at Ford last week gave me the almost perfect blank look.... :ermm: ..... so after market? And who from?
  • Here since the start...
  • Member For: 21y 11m 22d
Oil coolers are a tricky thing, you don't want the oil to be cooled to much to the point where the temp drops below normal operating temp.
  • Member For: 20y 9m 4d
  Quote
If you allow the transmission oil to enter the external oil cooler before the inbuilt cooler in the radiator then the transmission oil should leave the radiator inbuilt cooler at normal operating temp.
By letting it enter the external cooler first also allows for heat to dissipate there for not heating up the radiator above normal temp.
Ken
OK - so Ken - you're saying that there IS an aftermarket solution that will slot in, supplied firstly from the lower line going to the radiator (from the trans...), then to that port through the radiator and return....?
  • FORD FORD FORD
I can't imagine a 4000lb car with as much torque & therefore as much friction as these machines have suffering from chill blanes to the auto just acuse one fitted an aftermarket cooler, unless you are planning a trip through Siberia
Scotty
  • Sucker
  • Moderating Team
  • Member For: 20y 11m 23d
But you wouldn’t want to be ramming all that torque and friction through the slushy before it reaches normal operating temp would you? My understanding was that the radiator mounted “heat exchanger” (notice I didn’t say cooler) is more of an equalizer than anything – brings the tranny up to temp faster and then helps cool it down when the fun starts.
Have I got the tit by the bull?
And in just typing that I think I’ve got new names for Scotty and Ian; Torque & Friction!
:spoton:
Not Trent.
