cutsnake Member 122 Member For: 21y 7m 22d Posted 23/02/05 10:26 AM Share Posted 23/02/05 10:26 AM stardust said: 2 powersteering coolers ?Didn't they install auto coolers with some of the tow packs ?Ken<{POST_SNAPBACK}>Now I am confused Does every T have a tranny (auto) cooler or was it only fiited with a tow pack?P.S. I am interstate atm and don't have my car with me so I can't check..... Link to comment https://www.fordxr6turbo.com/forum/topic/15863-trans-oil-cooler/page/2/#findComment-223369 Share on other sites More sharing options...
Blown BA In Your Face Member 6,195 Member For: 22y 3m 12d Gender: Male Location: Peninsula Posted 24/02/05 05:05 AM Share Posted 24/02/05 05:05 AM stardust said: Mine is a 04/04 build and its above the intercooler.Not real smart if its in front of the intercooler, as heat from it, will pass on to the intercooler.Ken<{POST_SNAPBACK}>Mine is in between the radiator and condenser Link to comment https://www.fordxr6turbo.com/forum/topic/15863-trans-oil-cooler/page/2/#findComment-223726 Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 22y 3m 4d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 26/02/05 05:35 AM Share Posted 26/02/05 05:35 AM No T's have a tranny cooler (tow pack or not,) other than the excuse for one they have running through the radiator, early T's ran one below the IC & another in front of the condenser, later models run only one in the top posy but twice the length of the early jobby.The later one is available from Ford for about $150+, it can replace both the ones in an earlier model & leave ample room down under the IC for a Trans cooler. Hope this helps, I have done it to mine last week as have some othersScotty Link to comment https://www.fordxr6turbo.com/forum/topic/15863-trans-oil-cooler/page/2/#findComment-224733 Share on other sites More sharing options...
cutsnake Member 122 Member For: 21y 7m 22d Posted 26/02/05 07:00 AM Share Posted 26/02/05 07:00 AM ktford said: No T's have a tranny cooler (tow pack or not,) other than the excuse for one they have running through the radiator, early T's ran one below the IC & another in front of the condenser, later models run only one in the top posy but twice the length of the early jobby.The later one is available from Ford for about $150+, it can replace both the ones in an earlier model & leave ample room down under the IC for a Trans cooler. Hope this helps, I have done it to mine last week as have some othersScotty<{POST_SNAPBACK}>Thanks Scotty,It looks like an after market one is the way to go...CutSnake Link to comment https://www.fordxr6turbo.com/forum/topic/15863-trans-oil-cooler/page/2/#findComment-224755 Share on other sites More sharing options...
Johnny G Team Grandpa Qualified Donating Members 809 Member For: 20y 4m 8d Gender: Male Location: Brisbane North. Posted 27/02/05 04:57 AM Share Posted 27/02/05 04:57 AM Just checked my May 04 T.... auto trans cooler is via the radiator (do you reckon that would heat it up or cool it down?? Anyone know the temp gradient differential from one to the other?), with power steering cooler in front of the radiator above the intercooler.So - with the general concensus being a cooler is a must with anything that's even mildly warmed - what are the options? The guys I spoke to at Ford last week gave me the almost perfect blank look.... ..... so after market? And who from? Link to comment https://www.fordxr6turbo.com/forum/topic/15863-trans-oil-cooler/page/2/#findComment-225007 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 1m 26d Gender: Male Location: Victoria Posted 27/02/05 05:15 AM Share Posted 27/02/05 05:15 AM Oil coolers are a tricky thing, you don't want the oil to be cooled to much to the point where the temp drops below normal operating temp. Link to comment https://www.fordxr6turbo.com/forum/topic/15863-trans-oil-cooler/page/2/#findComment-225014 Share on other sites More sharing options...
stardust Member 537 Member For: 20y 11m 8d Location: Brisbane Posted 27/02/05 06:16 AM Share Posted 27/02/05 06:16 AM Quote Oil coolers are a tricky thing, you don't want the oil to be cooled to much to the point where the temp drops below normal operating temp.If you allow the transmission oil to enter the external oil cooler before the inbuilt cooler in the radiator then the transmission oil should leave the radiator inbuilt cooler at normal operating temp.By letting it enter the external cooler first also allows for heat to dissipate there for not heating up the radiator above normal temp.Ken Link to comment https://www.fordxr6turbo.com/forum/topic/15863-trans-oil-cooler/page/2/#findComment-225039 Share on other sites More sharing options...
Johnny G Team Grandpa Qualified Donating Members 809 Member For: 20y 4m 8d Gender: Male Location: Brisbane North. Posted 27/02/05 07:42 AM Share Posted 27/02/05 07:42 AM OK - so Ken - you're saying that there IS an aftermarket solution that will slot in, supplied firstly from the lower line going to the radiator (from the trans...), then to that port through the radiator and return....? Link to comment https://www.fordxr6turbo.com/forum/topic/15863-trans-oil-cooler/page/2/#findComment-225076 Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 22y 3m 4d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 27/02/05 10:16 AM Share Posted 27/02/05 10:16 AM I can't imagine a 4000lb car with as much torque & therefore as much friction as these machines have suffering from chill blanes to the auto just acuse one fitted an aftermarket cooler, unless you are planning a trip through SiberiaScotty Link to comment https://www.fordxr6turbo.com/forum/topic/15863-trans-oil-cooler/page/2/#findComment-225151 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 1m 27d Gender: Male Location: Brisbane Posted 27/02/05 11:08 AM Share Posted 27/02/05 11:08 AM But you wouldn’t want to be ramming all that torque and friction through the slushy before it reaches normal operating temp would you? My understanding was that the radiator mounted “heat exchanger” (notice I didn’t say cooler) is more of an equalizer than anything – brings the tranny up to temp faster and then helps cool it down when the fun starts.Have I got the tit by the bull?And in just typing that I think I’ve got new names for Scotty and Ian; Torque & Friction!Not Trent. Link to comment https://www.fordxr6turbo.com/forum/topic/15863-trans-oil-cooler/page/2/#findComment-225176 Share on other sites More sharing options...
