  • Member For: 22y 4m 24d
Guys,
After reading through the whole thread again, I'm not too sure....
Can illuminated switches be fitted to a ute?
If so, can somebody post the ute procedure?
Thanks
  • Replies 298
Posted Images
  • Brendan Dennis
  • Member For: 22y 8m 5d
Mate,
Yes the switches can be done in a ute. They are exactly the same as a sedan. Just pop the switch block out of the dorr handle and away you go..
  • 2 weeks later...
  • Member For: 20y 8m 19d
After reading this post, I fitted SMD blue LEDs to the driver / passenger window switches. Then I decided decided to do a bit extra. The driver side rear window cutoff switch is illuminated blue when enabled, but if you switch the rear windows off, it changes to red :kissmy: I did this by fitting a SMD red led + series SMD 390 ohm dropper resistor across the cutoff switch contacts. I also put a SMD blue LED + 390 ohm resistor from the switched contact to the "new pin". I had to fit a 270 ohm ground shunt resistor to stop the rear window door switches from illuminating all the time. I added the SMD LED by scraping a small square (1mmx1mm) on the lacquer coated PCB pads, to give the SMD LEDs somewhere to "sit".
It works like this, if the rear switches are enabled, the switch is closed, which means the red LED is shorted out, but 12V is applied to the switched contact, ie the blue LED is powered up (if the "new pin" is grounded, ie when the illumination is ON). Then if you open the switch contact, ie disable the rear windows, the 12V is applied to the red LED, and it is shunted to ground via the 270 ohm resistor.
  • Former XT pilot
  • Member For: 21y 10m 28d
Nice work! :kissmy:
  • In Your Face
  • Member For: 22y 3m 11d
  xlnt6 said:
Then I decided decided to do a bit extra. The driver side rear window cutoff switch is illuminated blue when enabled, but if you switch the rear windows off, it changes to red :spoton:
Well done ....why didn't we think of this :spoton:
Can anyone give me the exact procedure for adding blue lighting to my ute window switches?
Or, is anyone still keen on doing the switches for payment?
Thanks
  • Member For: 22y 3m 5d
Thanks
I'll find the word doc I posted before and repost.....juz lemme find it lol.
  • Member For: 21y 7m 15d
for you melbourne people out ther I am in melbourne & own an xrt ute & am going to fit blue leds to mine in the next weeks or so(when I get time) The reason for my post is I have had some apart already & am not thinking I am going to have too much difficulty & will be happy to help you guys in the future. especially since I will use mine to experiment on. After that if I am successful I will be happy to helo any of you guys. I should also point out I am a qualified auto electrician. The main reason for my post, is I am wondering if I should buy extra leds & resistors? let me know if u guys are still interested
