Guest ROCKET Guests Posted 09/06/03 12:54 PM Share Posted 09/06/03 12:54 PM greetings allis there any way at all that I can do this were they only come on with the lights without haveing to run wire's front the light switch to the doorson the subject of lights have any of you guys found a way to fit footwell lights in a car fitted with premium sound system, any ideas on what wire's to splice into ect......regardsrod Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/21/#findComment-27588 Share on other sites More sharing options...
CJF077 The Noble Leader Administrator 4,786 Member For: 22y 8m 5d Gender: Male Location: Sydney Australia Posted 09/06/03 10:54 PM Share Posted 09/06/03 10:54 PM ROCKET said: on the subject of lights have any of you guys found a way to fit footwell lights in a car fitted with premium sound system, any ideas on what wire's to splice into ect......regardsrod Rod,For the footwell lights you just plug them in to the sockets. They are already there if you have Premium Sound.Cheers Chris Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/21/#findComment-27627 Share on other sites More sharing options...
Cam Member 397 Member For: 22y 4m 18d Location: Brisbane Posted 10/06/03 02:52 AM Share Posted 10/06/03 02:52 AM CJF077 said: ROCKET said: on the subject of lights have any of you guys found a way to fit footwell lights in a car fitted with premium sound system, any ideas on what wire's to splice into ect......regardsrodRod,For the footwell lights you just plug them in to the sockets. They are already there if you have Premium Sound.Cheers Chris Rod has a ute with prestige sound - premium sound is not availiable in the ute. Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/21/#findComment-27692 Share on other sites More sharing options...
XR6TK1W1 Member 435 Member For: 22y 2m 23d Location: Wellington NZ Posted 10/06/03 03:51 AM Author Share Posted 10/06/03 03:51 AM ROCKET said: greetings allis there any way at all that I can do this were they only come on with the lights without haveing to run wire's front the light switch to the doorson the subject of lights have any of you guys found a way to fit footwell lights in a car fitted with premium sound system, any ideas on what wire's to splice into ect......regardsrod If the Blue/Red wire aint there then unless the window switch has ESP you wont be able to. You can't see them in the day when they are on anyway so I can't see the big deal. But If you only want them on with the lights then you would have to run a wire from the Tail relay or light feed to do this. Big big hassle for bugger all I say. Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/21/#findComment-27716 Share on other sites More sharing options...
Cam Member 397 Member For: 22y 4m 18d Location: Brisbane Posted 10/06/03 03:55 AM Share Posted 10/06/03 03:55 AM I drove around this morning with my lights on (in normal sunny weather) and you can not see the blue lighting during the day at all. Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/21/#findComment-27718 Share on other sites More sharing options...
AWW XR6T UTE Member 129 Member For: 22y 1m 11d Location: Brisbane Posted 10/06/03 05:52 AM Share Posted 10/06/03 05:52 AM I have installed the leds in my Ute as per K1W1's diagram and they work fine, you just have to be carefull with the trace on the bottom side of the circuit board, as in sections of the board it is negative on top and positive directly below, meter all connections before installing. In the daylight they look normal.Also I had to connect to leds on the passenger side switch to the window circuit, to be on when the widows are active, (ie smd led & resistor as per this thread and a wire from where the new pin is suppose to go to the negative on the lower left hand corner of the switch) as the blue/red trace wire does nothing. It is there but does not provide a neg or pos feed. Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/21/#findComment-27746 Share on other sites More sharing options...
XR6TK1W1 Member 435 Member For: 22y 2m 23d Location: Wellington NZ Posted 10/06/03 06:05 AM Author Share Posted 10/06/03 06:05 AM Good to hear AWW XR6T UTE. Glad to help. Now we have Turbo's premium and non premium, Utes with prestige all we need now is to do a GT and an XR8. Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/21/#findComment-27748 Share on other sites More sharing options...
XR6TK1W1 Member 435 Member For: 22y 2m 23d Location: Wellington NZ Posted 10/06/03 08:42 AM Author Share Posted 10/06/03 08:42 AM :idea: :idea: Just a note to say about another place to change to blue LED's. I just put one in the PC board that lights up the key entry. Looks awesome. Easy as to install!! :idea: Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/21/#findComment-27810 Share on other sites More sharing options...
NT TURBO Member 1,128 Member For: 22y 3m 2d Gender: Male Location: Darwin NT Posted 10/06/03 08:57 AM Share Posted 10/06/03 08:57 AM K1W1 what was original and hows it come out? Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/21/#findComment-27813 Share on other sites More sharing options...
XR6TK1W1 Member 435 Member For: 22y 2m 23d Location: Wellington NZ Posted 11/06/03 04:23 AM Author Share Posted 11/06/03 04:23 AM The lamp was incandesant type like the ones in your fog light/traction control switch. Undo screws on steering coloum cover, unplug green plug going to clear unit, Undo one screw on inner back. Remove unit, pop open black cover, remove lamp. Insert Blue LED with resistor. On mine Pos was closest to out side but with yours NT I'd hate to guess but it should be the same. Easy as that. Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/21/#findComment-27994 Share on other sites More sharing options...
