Guest potai Guests Posted 07/06/03 07:16 AM Share Posted 07/06/03 07:16 AM Cam,You should get some CRC Contact Cleaner, spray an old tooth brush and scrub that printed circuit board to remove that solder flux residue. Not only will it look more "professional" it will stop any cross tracking should the flux be dirty (have any solder contaminants in it). The danger of posting good quality digital photo's....Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/20/#findComment-27162 Share on other sites More sharing options...
Guest ROCKET Guests Posted 08/06/03 10:32 AM Share Posted 08/06/03 10:32 AM greetings allI have removed the window switch on the ute & the wiring to the plug is as followsnote the only power at the switch is positive 12 volts on the grey wire with the yellow trace all others are earth's hope this is of some helpregardsrod Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/20/#findComment-27322 Share on other sites More sharing options...
Cam Member 397 Member For: 22y 4m 19d Location: Brisbane Posted 08/06/03 10:56 AM Share Posted 08/06/03 10:56 AM RockeyHow many wires do you have going to the switch, and if more then 6 what positions are they in ?(if only 6 - they are 4 for the motors, +ve and Gnd - no wire for illumination - you could stil do somehting just a little trickier) Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/20/#findComment-27332 Share on other sites More sharing options...
AWW XR6T UTE Member 129 Member For: 22y 1m 11d Location: Brisbane Posted 08/06/03 11:10 AM Share Posted 08/06/03 11:10 AM I have also checked my utes switches. The passenger side is no problem as the blue/red feed is present, but on the drivers side it only has the 6 wires with Yellow/Black, Yellow, Red/Black, Red, Black, Grey/Yellow wires. It does not have the blue/red feed. The only other suggestion that I have, which I will look for tomorrow, is to see if the feed wire actually goes into the door through the connector near the hinges, if it does it could be extended to go to the switch. I'll let you know. Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/20/#findComment-27334 Share on other sites More sharing options...
Guest ROCKET Guests Posted 08/06/03 11:21 AM Share Posted 08/06/03 11:21 AM greetings allI have a picture of how the wiring is on the back of the switch but am unable to post it, can somebody do it for me if I email it to themregardsrod Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/20/#findComment-27336 Share on other sites More sharing options...
NT TURBO Member 1,128 Member For: 22y 3m 3d Gender: Male Location: Darwin NT Posted 08/06/03 11:32 AM Share Posted 08/06/03 11:32 AM Rocket, email me, adress below Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/20/#findComment-27337 Share on other sites More sharing options...
NT TURBO Member 1,128 Member For: 22y 3m 3d Gender: Male Location: Darwin NT Posted 08/06/03 10:16 PM Share Posted 08/06/03 10:16 PM Rocket's Ute SwitchAccording to Rocket there is no blue/red trace, any ideas anyone? Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/20/#findComment-27393 Share on other sites More sharing options...
Cam Member 397 Member For: 22y 4m 19d Location: Brisbane Posted 08/06/03 11:19 PM Share Posted 08/06/03 11:19 PM The yellow, red are the window motor wires for the drivers side.The yellow/black, red/black are the window motor wires for the passenger side.The Grey/Yellow is the +ve voltageThe Black is groundYou are going to have to improvise a solution using the wires you have availiable.Basically use standard LEDs and resistors and wire them fromt he Grey/Yellow to the black. They will be on all the time that the windows have power going to them. Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/20/#findComment-27404 Share on other sites More sharing options...
XR6TK1W1 Member 435 Member For: 22y 2m 24d Location: Wellington NZ Posted 09/06/03 04:17 AM Author Share Posted 09/06/03 04:17 AM Rocket try this. Scratch away some of the coating where I have marked the red and black dots. If the back of the PC board has not got any tracks running across the back drill through with fine drill so the resistor and or LED legs can go through. This will give you a soldiering point. If your really tricky you can scratch away the coating and use surface mount LED's with one leg direct soldierd to a surface mount resistor or a standard resistor.Good luck with the upgrade.PS like I said earlier they will be on at all times but will go out when the car is locked or the Power window times out.Dave Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/20/#findComment-27475 Share on other sites More sharing options...
NT TURBO Member 1,128 Member For: 22y 3m 3d Gender: Male Location: Darwin NT Posted 09/06/03 05:34 AM Share Posted 09/06/03 05:34 AM As K1W1 says looks good they may be on all the time but you can't see mine if there on in the daylight anyway. Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/20/#findComment-27495 Share on other sites More sharing options...
