XR6TK1W1 Member 435 Member For: 21y 11m 8d Location: Wellington NZ Posted 04/06/03 04:05 AM Author Share Posted 04/06/03 04:05 AM If you could spend a couple of days without them I could do them over here.Over night courier on the plane may bump up the price a bit though. Plus I would want money first up since its a bit hard to chase across the tasman. Link to comment Share on other sites More sharing options...
Guest potai Guests Posted 04/06/03 08:38 AM Share Posted 04/06/03 08:38 AM Karl,Your problem sounds like the classic "LEDS around the wrong way syndrome". I made the mistake early on of measuring voltages to ground. I then thought it was the BEM because the symptoms were so weird. Last weekend I finally replaced the all the LEDs with SMD's and checked each switch on the bench with a battery charger as a power source as I went and hey presto all fine now. The Jaycar SMD's have a"<" (triangle) to mark the pins and all should go this way around (like a less than sign) when looking at the top (contact side) of the circuit board (I.e not from the pin side), except the one LED on the drivers switch.If checking the LEDs with a multimeter be aware that most analog meters output +ve on the black wire and -ve on the red (a trap for old and young).Failing that check that you hav'nt bridged a track, some of those are very close to the resistors...Best of luck. Link to comment Share on other sites More sharing options...
XR6TK1W1 Member 435 Member For: 21y 11m 8d Location: Wellington NZ Posted 04/06/03 09:17 AM Author Share Posted 04/06/03 09:17 AM Good news potai!!! Now theres two over here. Link to comment Share on other sites More sharing options...
Guest ROCKET Guests Posted 04/06/03 11:14 AM Share Posted 04/06/03 11:14 AM greetings allcan anybody confirm that this will work in a ute with the premium sound optionregardsrod Link to comment Share on other sites More sharing options...
Guest KarlDurrance Guests Posted 04/06/03 10:40 PM Share Posted 04/06/03 10:40 PM Potai,Yep, your correct.. I switched the LEDs around the other way on the drivers door and worked a charm.. what resistor values have people used ? I've used the SMD 47R as was suggested in this thread and it still is a 'little' bright with some light coming thru the cracks of the switches.. has anyone used a higher resistor value ? what were the results like ? Link to comment Share on other sites More sharing options...
XR6TK1W1 Member 435 Member For: 21y 11m 8d Location: Wellington NZ Posted 05/06/03 04:36 AM Author Share Posted 05/06/03 04:36 AM Karl, you can use any resistor above around 360 ohms and be safe for the LEDs. I think I ended up using around 630 ohms in the end. Only get a fraction of light between the cracks. I think if you want really dull light go for around 800 ohms resistance. If not just be lazy and dimm it via the dash light dimmer switch :D Link to comment Share on other sites More sharing options...
XR6TK1W1 Member 435 Member For: 21y 11m 8d Location: Wellington NZ Posted 05/06/03 04:41 AM Author Share Posted 05/06/03 04:41 AM Rocket, I pretty sure they will work but I havent been able to get my hands on a ute to find out. I also dont have the full wiring diagrams but the ones I do have seem to indicate only small changes to wiring between ute and car. Mainly position changes etc. If your dealer is good get them to try a fairmont switch from one of there lot cars and see if it works. If not pull out your switch and look for a blue with red striped wire in the center of the plug. It is slightly thinner than the rest and if its there bingo it will work. Link to comment Share on other sites More sharing options...
Guest ROCKET Guests Posted 05/06/03 11:00 AM Share Posted 05/06/03 11:00 AM greetings allCAM are you able to post a pic of the drivers door switch circuit board with the surface mount led's installedregardsrod Link to comment Share on other sites More sharing options...
Guest ROCKET Guests Posted 05/06/03 11:51 AM Share Posted 05/06/03 11:51 AM greetingsjust thought that I would post a pic of a ute switch & hope that somebody can show me how it is doneregardsrod :idea:http://www.fordxr6turbo.com/photogallery/u...p?aid=23&pid=88 Link to comment Share on other sites More sharing options...
NT TURBO Member 1,128 Member For: 21y 11m 18d Gender: Male Location: Darwin NT Posted 05/06/03 11:13 PM Share Posted 05/06/03 11:13 PM Yeah, that's different to a sedan, is there a pin missing from the other side where it plugs in? Link to comment Share on other sites More sharing options...
