Guest KarlDurrance Guests Posted 01/06/03 10:56 PM Share Posted 01/06/03 10:56 PM Hi all,Well I had a go at installing the LEDs in the switches on the w.e, all the passenger doors were easy and they work as expected.. BUT the drivers door has got me puzzled.. when I plug it it all the LEDs flash breifly (so I know all the LEDs are working), I then turn on the headlights which activates all the other switches, the drivers door brightens up breifly (about 1 second) then turns off, never to be on again..I followed the premium sound instructions word for word and am not sure what is going on..Anyone have any ideas ?? BTW I used SMD components..BTW, for the red cutoff switch is there a SMD pad for that LED ? its not in the instructions..Karl Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/17/#findComment-25915 Share on other sites More sharing options...
NT TURBO Member 1,128 Member For: 22y 3m 4d Gender: Male Location: Darwin NT Posted 01/06/03 11:21 PM Share Posted 01/06/03 11:21 PM KarlDurrance said: Hi all,Well I had a go at installing the LEDs in the switches on the w.e, all the passenger doors were easy and they work as expected.. BUT the drivers door has got me puzzled.. when I plug it it all the LEDs flash breifly (so I know all the LEDs are working), I then turn on the headlights which activates all the other switches, the drivers door brightens up breifly (about 1 second) then turns off, never to be on again..I followed the premium sound instructions word for word and am not sure what is going on..Anyone have any ideas ?? BTW I used SMD components..BTW, for the red cutoff switch is there a SMD pad for that LED ? its not in the instructions..Karl Sounds like a job for K1W1, but theres no pad for the cut off switch to my knowledge and check the diodes polarity (maybe feedback is causing them to flash?) bit strange, what size resistors?, all good-no dry joints? and extra pin is locating in socket OK? And the only time mine go out is on one of the dash brightness levels. Let us know how you go and or post a pic. Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/17/#findComment-25918 Share on other sites More sharing options...
XR6TK1W1 Member 435 Member For: 22y 2m 24d Location: Wellington NZ Posted 01/06/03 11:51 PM Author Share Posted 01/06/03 11:51 PM Karl, NT could be right with an LED out of polarity. And no theres no pad for the cut off. The factory cut off doesn't light up NT was being clever LOL. If they are lighting up briefly and going out sounds abit wierd but to check for backwards LEDS open the switch and plug it in. Short each individual LED out and see what happens. If the rest light up with one shorted out that is the LED which is wrong. Also if the Pin had a dry joint this can happen. Remember one of the LEDs is backwards I think it was the bootom drivers one. But if you followed word for word it should be correct. Hope this helps, any probs just yell. Also make sure there is still a neg at the pin when they go out. If its the BEM playing up it could waste you alot of time. Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/17/#findComment-25927 Share on other sites More sharing options...
richdave SLOJAM, Gone but not forgotten Lifetime Members 1,841 Member For: 22y 8m 8d Gender: Male Location: Outer east - Melbourne Posted 02/06/03 01:15 AM Share Posted 02/06/03 01:15 AM one question for those who have done this mod...do the lights only illuminate when the dash lights are on OR are they always on? Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/17/#findComment-25937 Share on other sites More sharing options...
Guest KarlDurrance Guests Posted 02/06/03 01:34 AM Share Posted 02/06/03 01:34 AM Ok, so far I have not been testing it out of the car, I've done the work and plugged it in (and I guess haev been lucky until now).. What is the voltage to the board (I don't have a multimeter) can I just use a 9v batt and plug touch the wires to the + and - pins, I know if the voltage from the car is higher it would be a little dull, but at least it will prove the LEDs are getting power properly??Richdave, mine only light up when the headlights are turned on.. not like others which from what I have read also turn on when the interior lights are on ??Sorry for my ignorance, but I don't have very much experience with electronics.. BTW for those who are going to attempt this with SMD components there is a SMD training kit from Jaycar that I bought for practise before hand.. helped me out heaps.. Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/17/#findComment-25944 Share on other sites More sharing options...
XR6TK1W1 Member 435 Member For: 22y 2m 24d Location: Wellington NZ Posted 02/06/03 02:18 AM Author Share Posted 02/06/03 02:18 AM Richdave, for the Premium Sound cars they only go when the lights are on. If you leave your fog light switch on with the lights off it also illuminates. It goes off with the interior lights etc and when you lock the car. Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/17/#findComment-25967 Share on other sites More sharing options...
geea Site protagonist Lifetime Members 4,320 Member For: 22y 1m 6d Gender: Male Location: At the lights, waiting for you. Posted 02/06/03 02:22 AM Share Posted 02/06/03 02:22 AM Got mine all sorted now. The problem was my lack of experience with soldiering, I heated the LED's up to much when conecting the resistor to them. Its all fixed now and they all work great. The window lights only come on when I turn my lights on. Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/17/#findComment-25969 Share on other sites More sharing options...
NT TURBO Member 1,128 Member For: 22y 3m 4d Gender: Male Location: Darwin NT Posted 02/06/03 02:38 AM Share Posted 02/06/03 02:38 AM When K1W1 is suggesting testing I think he means plug it into the car without the top half or contacts in place. Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/17/#findComment-25978 Share on other sites More sharing options...
XR6TK1W1 Member 435 Member For: 22y 2m 24d Location: Wellington NZ Posted 02/06/03 05:02 AM Author Share Posted 02/06/03 05:02 AM NT TURBO said: When K1W1 is suggesting testing I think he means plug it into the car without the top half or contacts in place. Yeah what he said :idea: Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/17/#findComment-26048 Share on other sites More sharing options...
Henry Member 180 Member For: 22y 4m 13d Gender: Not Telling Posted 04/06/03 03:38 AM Share Posted 04/06/03 03:38 AM Anybody in Sydney doing successful conversions? :idea: I am not technically competent to do it alone, so would like some help.Has to be better than spending $130 for a fairmont switch for the drivers door alone!! Link to comment https://www.fordxr6turbo.com/forum/topic/1583-blue-window-switches/page/17/#findComment-26560 Share on other sites More sharing options...
