FPV 521 FPV521 Member 989 Member For: 20y 8m 20d Gender: Male Posted 19/02/05 11:30 PM Share Posted 19/02/05 11:30 PM Hello, Have had the car back at the dealers 3 times now with the brake squeel. Its going back again tomorrow as its still thereThey have fixed the handbrake squeel but it sounds as though the brakes are dragging on the disc.Will a pad upgrade or new set of pads fix the problem?I am running out of options here. Link to comment https://www.fordxr6turbo.com/forum/topic/15806-replacement-pads/ Share on other sites More sharing options...
badxr6 HEINRICH PERFORMANCE AND TUNING Donating Members 439 Member For: 21y 3m 17d Gender: Male Location: adelaide Posted 19/02/05 11:34 PM Share Posted 19/02/05 11:34 PM Gavin Conroy said: Hello, Have had the car back at the dealers 3 times now with the brake squeel. Its going back again tomorrow as its still thereThey have fixed the handbrake squeel but it sounds as though the brakes are dragging on the disc.Will a pad upgrade or new set of pads fix the problem?I am running out of options here. put new pads in and machine the discs Link to comment https://www.fordxr6turbo.com/forum/topic/15806-replacement-pads/#findComment-221467 Share on other sites More sharing options...
FPV 521 FPV521 Member 989 Member For: 20y 8m 20d Gender: Male Posted 19/02/05 11:38 PM Author Share Posted 19/02/05 11:38 PM badxr6 said: Gavin Conroy said: Hello, Have had the car back at the dealers 3 times now with the brake squeel. Its going back again tomorrow as its still thereThey have fixed the handbrake squeel but it sounds as though the brakes are dragging on the disc.Will a pad upgrade or new set of pads fix the problem?I am running out of options here. <{POST_SNAPBACK}>put new pads in and machine the discs <{POST_SNAPBACK}>Its been a waraanty job thus far and Im not sure weather Ford would machine the discs for free. Link to comment https://www.fordxr6turbo.com/forum/topic/15806-replacement-pads/#findComment-221469 Share on other sites More sharing options...
Guest FatBAt Guests Posted 20/02/05 12:00 AM Share Posted 20/02/05 12:00 AM Gavin Conroy said: badxr6 said: Gavin Conroy said: Hello, Have had the car back at the dealers 3 times now with the brake squeel. Its going back again tomorrow as its still thereThey have fixed the handbrake squeel but it sounds as though the brakes are dragging on the disc.Will a pad upgrade or new set of pads fix the problem?I am running out of options here. <{POST_SNAPBACK}>put new pads in and machine the discs <{POST_SNAPBACK}>Its been a waraanty job thus far and Im not sure weather Ford would machine the discs for free.<{POST_SNAPBACK}>There is no reason why Ford would not machine the discs for free. Its not like its a major operation. Again, you have been there 3 times now! If you do get them machined and you want to upgrade your pads, try Bendix Ultimates. I run them and they a fine. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/15806-replacement-pads/#findComment-221482 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 9m 19d Gender: Male Location: Newcastle Posted 20/02/05 01:04 AM Share Posted 20/02/05 01:04 AM If you go to after market performance pads there likely to squeel more due to the higher metal content.Bendix Ultimates "yuk" had those nothin but trouble. Link to comment https://www.fordxr6turbo.com/forum/topic/15806-replacement-pads/#findComment-221506 Share on other sites More sharing options...
Guest FatBAt Guests Posted 20/02/05 01:09 AM Share Posted 20/02/05 01:09 AM (edited) Benny said: If you go to after market performance pads there likely to squeel more due to the higher metal content.Bendix Ultimates "yuk" had those nothin but trouble.<{POST_SNAPBACK}>Each to there own I guess. I have not had a problem with them and on my second pairEdit: Perhaps instead of saying "yuk" you could elaborateNO Flames either Edited 20/02/05 01:10 AM by FatBAt Link to comment https://www.fordxr6turbo.com/forum/topic/15806-replacement-pads/#findComment-221507 Share on other sites More sharing options...
FPV 521 FPV521 Member 989 Member For: 20y 8m 20d Gender: Male Posted 20/02/05 01:31 AM Author Share Posted 20/02/05 01:31 AM FatBAt said: Gavin Conroy said: badxr6 said: Gavin Conroy said: Hello, Have had the car back at the dealers 3 times now with the brake squeel. Its going back again tomorrow as its still thereThey have fixed the handbrake squeel but it sounds as though the brakes are dragging on the disc.Will a pad upgrade or new set of pads fix the problem?I am running out of options here. <{POST_SNAPBACK}>put new pads in and machine the discs <{POST_SNAPBACK}>Its been a waraanty job thus far and Im not sure weather Ford would machine the discs for free.<{POST_SNAPBACK}>There is no reason why Ford would not machine the discs for free. Its not like its a major operation. Again, you have been there 3 times now! If you do get them machined and you want to upgrade your pads, try Bendix Ultimates. I run them and they a fine. Cheers<{POST_SNAPBACK}>I am going to discuss ford machining the discs and when I replace the pads I do want to use other pads that could be less prone to do this. Not sure if there is such a thing Link to comment https://www.fordxr6turbo.com/forum/topic/15806-replacement-pads/#findComment-221524 Share on other sites More sharing options...
FPV 521 FPV521 Member 989 Member For: 20y 8m 20d Gender: Male Posted 20/02/05 01:33 AM Author Share Posted 20/02/05 01:33 AM Benny said: If you go to after market performance pads there likely to squeel more due to the higher metal content.Bendix Ultimates "yuk" had those nothin but trouble.<{POST_SNAPBACK}>Why were they so much trouble. I might use different to the factory ones if they are better so need some feedback on different types and how they go or are the standard ones as good as anything else on the market. I would be thinking no. Link to comment https://www.fordxr6turbo.com/forum/topic/15806-replacement-pads/#findComment-221525 Share on other sites More sharing options...
FPV 521 FPV521 Member 989 Member For: 20y 8m 20d Gender: Male Posted 20/02/05 01:35 AM Author Share Posted 20/02/05 01:35 AM badxr6 said: Gavin Conroy said: Hello, Have had the car back at the dealers 3 times now with the brake squeel. Its going back again tomorrow as its still thereThey have fixed the handbrake squeel but it sounds as though the brakes are dragging on the disc.Will a pad upgrade or new set of pads fix the problem?I am running out of options here. <{POST_SNAPBACK}>put new pads in and machine the discs <{POST_SNAPBACK}>Does that fix the problem altogether. I dont want to get it done and having it squeeling again soon after I get it home. Its hard to know from where you are sitting but obviously this method cured your car? Link to comment https://www.fordxr6turbo.com/forum/topic/15806-replacement-pads/#findComment-221526 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 9m 19d Gender: Male Location: Newcastle Posted 20/02/05 03:23 AM Share Posted 20/02/05 03:23 AM Gavin Conroy said: Benny said: If you go to after market performance pads there likely to squeel more due to the higher metal content.Bendix Ultimates "yuk" had those nothin but trouble.<{POST_SNAPBACK}>Why were they so much trouble. I might use different to the factory ones if they are better so need some feedback on different types and how they go or are the standard ones as good as anything else on the market. I would be thinking no.<{POST_SNAPBACK}>Sorry for the "yuk" without explanation but I chose Bendix when I upgraded to 4000 series slotted rotors and after only a few hundred kilometres found the pads were breaking down under heavy braking (no track work) and transfering pad material onto the rotor giving me shudder again. The rotors were replaced and I ended up putting Ferrodo's in which I've had no trouble what so ever and less dust. Other people on these forums have had the same problem.If you want a set of near new Bendix for nothing then I've got them under the house. Link to comment https://www.fordxr6turbo.com/forum/topic/15806-replacement-pads/#findComment-221561 Share on other sites More sharing options...
