tab Sucker Moderating Team 32,303 Member For: 20y 11m 8d Gender: Male Location: Brisbane Posted 20/02/05 07:15 AM Share Posted 20/02/05 07:15 AM Falchoon I take your advice,however I noticed from other posts you have made today you are in a fowl mood, you know the saying : if you cant say something nice dont say nothing at all. I noticed other members showed empathy about your job loss and subseqent car sale,you could possibly learn from it when you lecture people ,when they loose their licences, or use capslock,have a nice day !<{POST_SNAPBACK}>Yes, I think falchoon needs some lovin' and a few tolerance lessons.But anyway Scootre, although an expensive lesson, I hope that you now realise not to trust a dealer to look after your tyres. I would recommend to anyone to go to a real tyre place periodically to get a balance and alignment done. It'll be the best $70 you ever spend, not only for the immediate improvement in drivability but also in the potential savings in replacing tyres sooner than required.Trent. Link to comment Share on other sites More sharing options...
maximum_velocity Lemming No #5 Member 1,991 Member For: 20y 4m 10d Gender: Male Location: Endeavour Hills, Victoria Posted 20/02/05 07:22 AM Share Posted 20/02/05 07:22 AM RIGHTO BUDDY, YOU CAN TURN THE CAPS LOCK OFF now please. <{POST_SNAPBACK}>Falchoon I take your advice,however I noticed from other posts you have made today you are in a fowl mood, you know the saying : if you cant say something nice dont say nothing at all. I noticed other members showed empathy about your job loss and subseqent car sale,you could possibly learn from it when you lecture people ,when they loose their licences, or use capslock,have a nice day !<{POST_SNAPBACK}> :lol: :lol: Link to comment Share on other sites More sharing options...
CrankyBen Member 37 Member For: 20y 7m 1d Location: Canberra Posted 20/02/05 07:23 AM Share Posted 20/02/05 07:23 AM This is only correct if the tyre is true to the road. If you have -/+ camber, then that is where it will wear. Positive wear on the inside and negative wear on the outside. I have a set of 2 18's with 40% rubber on the outside and none on the inside. Goodyear EAGLE F1'S here I come...after a camber kit.<{POST_SNAPBACK}>Zuh?Negative camber means the top of the wheel is angled towards the car. This means that when you corner hard, the wheel get's pushed towards vertical - making more of the tyre contact the road.Hence, when driving in a straight line, negative camber wears the INSIDE of the tyre.From factory, most XRs have somewhere between 0.25 - 1.0 degrees negative camber. Camber kits are usually purchased to achieve MORE not LESS camber. This would only exacerbate the wear on the inside of the tyres that you are seeing.You must drive hella slow around corners Link to comment Share on other sites More sharing options...
Antisocial Weird Member Member 1,347 Member For: 22y 1m 30d Location: ACT Posted 20/02/05 12:31 PM Share Posted 20/02/05 12:31 PM Hey whatchoo guy's doin hasseling Falchoon that's my job. As an asside my SP9000's wore evenly, as have my Pirelli's which are about worn out too... Link to comment Share on other sites More sharing options...
mickq Member 740 Member For: 21y 11m 11d Posted 20/02/05 01:16 PM Share Posted 20/02/05 01:16 PM I wear the inside of my tyres much faster than the outside. My fronts wear pretty slow, but by the time my inside rears are on the tread wear indicator, the outside rear still has 5mm to go!But hey, I get endless tyres with my car, so who am I to complain? Every 9000km I just grab a new set of rears! Link to comment Share on other sites More sharing options...
Guest FatBAt Guests Posted 20/02/05 07:53 PM Share Posted 20/02/05 07:53 PM This is only correct if the tyre is true to the road. If you have -/+ camber, then that is where it will wear. Positive wear on the inside and negative wear on the outside. I have a set of 2 18's with 40% rubber on the outside and none on the inside. Goodyear EAGLE F1'S here I come...after a camber kit.<{POST_SNAPBACK}>From factory, most XRs have somewhere between 0.25 - 1.0 degrees negative camber. Camber kits are usually purchased to achieve MORE not LESS camber. This would only exacerbate the wear on the inside of the tyres that you are seeing<{POST_SNAPBACK}>Negative camber means the top of the wheel is angled towards the car. This means that when you corner hard, the wheel get's pushed towards vertical - making more of the tyre contact the road.Hence, when driving in a straight line, negative camber wears the INSIDE of the tyre.I stand corrected You must drive hella slow around corners You drive in a straight line more than turning corners. Unless you are reading about injector output on this forum in which case you go round and round in circles. I put a camber kit on a VT I had for five years which was running 17's and it fixed the problem. Can only speak from my own personal experiences. VT's had a real problem with negative camber. Link to comment Share on other sites More sharing options...
Blown BA In Your Face Member 6,195 Member For: 22y 24d Gender: Male Location: Peninsula Posted 21/02/05 05:29 AM Share Posted 21/02/05 05:29 AM Falchoon I take your advice,however I noticed from other posts you have made today you are in a fowl mood<{POST_SNAPBACK}>Steggels is ALWAYS in a fowl mood :lol:<{POST_SNAPBACK}>Fowl......Steggles it's got something there :lol: Link to comment Share on other sites More sharing options...
aaronmihe Upstanding Member Member 759 Member For: 21y 6m 29d Location: Canberra - ACT Posted 22/02/05 11:12 PM Share Posted 22/02/05 11:12 PM mmmm My 17" stocko SP3000s are wearing on the outer edge of the front, been aligned at least once....Thinking it's about time I invested some time into suspension settings and mods....A. Link to comment Share on other sites More sharing options...
Grant Member 453 Member For: 22y 4m Location: Kurrajong, Sydney Posted 23/02/05 12:27 AM Share Posted 23/02/05 12:27 AM You drive in a straight line more than turning corners. Unless you are reading about injector output on this forum in which case you go round and round in circles. LMAO... funniest thing I've read here in a while....Grant Link to comment Share on other sites More sharing options...
drcook Member 752 Member For: 20y 7m 14d Location: leonay Posted 24/02/05 02:17 AM Share Posted 24/02/05 02:17 AM I think im running 30-32psi in mine. is that too low? Link to comment Share on other sites More sharing options...
