  • 1 month later...
  • Replies 169
Posted Images
  • 3 months later...
  • Senior Member
  • Member For: 18y 8m 5d
  youngy said:
I think u better change your sig mate as mu manual xr6t has run 11.70. cheers
Is that 11.70 for a XR6T or is it a F6?
And was that with 430+ rwklw?
CV PERFORMANCE
Edited by CV PERFORMANCE
  • Member For: 19y 7m 13d
CV PERFORMANCE
can't you read my sig??? 11.70@121mph with 365rwkw. I ran125mph on my 395rwkw tune with major wheelspin (mt streets, full weight and stock suspension xr6t ute) and didnt even bother with the 433rwkw tune as couldnt get traction with 395rwkw.
  • - Track Bound EVO III -
  • Member For: 20y 4m 1d
mine was 11.81 @ 117mph 1.61 60'
35 degree heat. Several other 11's on that day..
Also did 11.87 @ 115mph (once) with injectors and a tune -> cat punched.
Con, our track over here in WA is not prepped unless it's a major event. Most of the runs Youngy and I ever did were on non prepped tracks. I ran on a prepped track once, hence the 1.61 60'... With more events than we actually have and a track that doesn't shut for winter, I'm sure our times could have been bettered..
I have also never made a full pass down the strip with more than ~320rwkw.. My 350rwkw tune blew the intake pipe off on the 2nd or 3rd gear change.
It's been quiet on the drag front for a bit... should be some big numbers falling with Gav's ute and a couple of others floating. Beefed up CV's seem to be more common nowadys too.. good times ahead.. just in time for Orion, then it starts again..
