macka'sxr6t Member 1,480 Member For: 20y 10m 9d Location: Mildura Posted 04/02/05 08:44 AM Share Posted 04/02/05 08:44 AM Aidan,I had the same problem back when the car was stock and only had 3000k. Check the rubber seal that connects the crossover pipe to the throttle body. They are prone to move or leak. If you are running higher boost than stock it will be the first place that I would look.Fixed mine macka Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 7m 2d Gender: Male Location: Townsville Posted 05/02/05 02:54 PM Share Posted 05/02/05 02:54 PM I had the same problem after I got it back from ford with the stalling problem. The idiots forgot to tighten the piping to the throttle body, so you probably have a loose connection somewhere.And by the way they wouldn't touch it unless it was converted back to standard.Brett Link to comment Share on other sites More sharing options...
jordak Member 1,226 Member For: 20y 9m 27d Posted 06/02/05 12:08 AM Share Posted 06/02/05 12:08 AM bjc said: I had the same problem after I got it back from ford with the stalling problem. The idiots forgot to tighten the piping to the throttle body, so you probably have a loose connection somewhere.And by the way they wouldn't touch it unless it was converted back to standard.Brett<{POST_SNAPBACK}>Same deal only in my case the rubber seal around the throttle body had actually split........worth checking Steve Link to comment Share on other sites More sharing options...
drcook Member 752 Member For: 20y 7m 17d Location: leonay Posted 07/02/05 05:47 AM Share Posted 07/02/05 05:47 AM if you have premium sound it may be a bad earth. ive got it too. 04 xr6t. the sound may actually be coming through your speakers. Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 3m 13d Gender: Male Location: Perth, WA Posted 07/02/05 07:22 AM Share Posted 07/02/05 07:22 AM jordak said: bjc said: I had the same problem after I got it back from ford with the stalling problem. The idiots forgot to tighten the piping to the throttle body, so you probably have a loose connection somewhere.And by the way they wouldn't touch it unless it was converted back to standard.Brett<{POST_SNAPBACK}>Same deal only in my case the rubber seal around the throttle body had actually split........worth checking Steve<{POST_SNAPBACK}>Same here, split rubber! Link to comment Share on other sites More sharing options...
Hazey Member 234 Member For: 21y 7m 30d Posted 09/02/05 10:02 PM Author Share Posted 09/02/05 10:02 PM Thanks for all your suggestions macka said: Aidan,I had the same problem back when the car was stock and only had 3000k. Check the rubber seal that connects the crossover pipe to the throttle body. They are prone to move or leak. If you are running higher boost than stock it will be the first place that I would look.Fixed mine macka<{POST_SNAPBACK}>Macka,I checled this Rubber seal and it had no cracks. I tightened securley and tightened every hose in the car.Still same problem.... What I have noticed is the sound is now intermittent.For example driving to work today it was not there, but tonight it might beAnd Yes its definatly not a normal sound. Its not turbo spooling up or that rushing air sound (which has become louder since fitting 2nd CAI)Aidan Link to comment Share on other sites More sharing options...
macka'sxr6t Member 1,480 Member For: 20y 10m 9d Location: Mildura Posted 10/02/05 10:08 AM Share Posted 10/02/05 10:08 AM Hazey said: Thanks for all your suggestions macka said: Aidan,I had the same problem back when the car was stock and only had 3000k. Check the rubber seal that connects the crossover pipe to the throttle body. They are prone to move or leak. If you are running higher boost than stock it will be the first place that I would look.Fixed mine macka<{POST_SNAPBACK}>Macka,I checled this Rubber seal and it had no cracks. I tightened securley and tightened every hose in the car.Still same problem.... What I have noticed is the sound is now intermittent.For example driving to work today it was not there, but tonight it might beAnd Yes its definatly not a normal sound. Its not turbo spooling up or that rushing air sound (which has become louder since fitting 2nd CAI)Aidan <{POST_SNAPBACK}>Did you completely remove the crossover and check, then refit. If you did, it's worth the effort anyway as Ford assembly QA needs some improving.Have you tried blocking of the second intake to see if it goes away or is still there.macka Link to comment Share on other sites More sharing options...
hypnodoc It's All In Your Mind Gold Donating Members 2,198 Member For: 21y 5m 7d Gender: Male Location: Melbourne Posted 10/02/05 10:17 AM Share Posted 10/02/05 10:17 AM drcook said: if you have premium sound it may be a bad earth. ive got it too. 04 xr6t. the sound may actually be coming through your speakers.<{POST_SNAPBACK}>I get that in the Typhoon Link to comment Share on other sites More sharing options...
slapnut Member 216 Member For: 21y 15d Location: Siddie Posted 10/02/05 10:22 AM Share Posted 10/02/05 10:22 AM (edited) fordboy1981 said: I noticed my turbo whistle louder as the kms go higher...I donno if that's what your refering to...Dave.<{POST_SNAPBACK}>Mine has done this too.55,000 now and the whistle when boost is building is very noticeable.I have chopped extra holes in the airbox. BOV is very audible as well.It's all good Edited 10/02/05 10:24 AM by slapnut Link to comment Share on other sites More sharing options...
Guest sully59 Guests Posted 11/02/05 08:10 PM Share Posted 11/02/05 08:10 PM I hear some "T"s develop a giggling sound as well, particularly when they pass holdens. Link to comment Share on other sites More sharing options...
