Guest fredwho Guests Posted 29/01/05 07:48 AM Share Posted 29/01/05 07:48 AM Geeseman, seems to me you've been fed and ingested so much propaganda that you have become a believer in something you know nothing about. Link to comment Share on other sites More sharing options...
rapt Donating Members 317 Member For: 21y 1m 7d Location: gippsland Posted 29/01/05 08:07 AM Share Posted 29/01/05 08:07 AM Geeseman, seems to me you've been fed and ingested so much propaganda that you have become a believer in something you know nothing about Not bad for your 20th post :lol: Link to comment Share on other sites More sharing options...
Geeseman Donating Members 1,805 Member For: 21y 25d Location: Sydney Posted 29/01/05 08:53 AM Share Posted 29/01/05 08:53 AM Geeseman, seems to me you've been fed and ingested so much propaganda that you have become a believer in something you know nothing about.What? Your statement makes no sense Link to comment Share on other sites More sharing options...
xrdreaming Lifetime Members 1,693 Member For: 21y 9m 23d Gender: Male Location: Melbourne Posted 29/01/05 10:00 AM Share Posted 29/01/05 10:00 AM C'mon guys this is getting boring. Geeseman's car ran a 118mph. Now my 11.7 was run at 119.05 mph so his car has every bit of power he claims, he just doesn't have the experience to use it at the track that I have.Geea runs around the 120mph as well. Now back to the edit, it sounds as though if you flash your standard tune back into it before you go in for a service then the dealer won't be able to tell. Now ethics is a topic I will stand well clear of, I wouldn't lie and didn't when my engine blew so I can back that up. But if other people choose to it is your decision to make and if you can get away with it then good luck.The edit should be more focused on providing a wider range of modification options and not on defrauding the Ford motor company.I will use the edit to mod my auto setup in time so I will let you all know how it goes. Link to comment Share on other sites More sharing options...
geea Site protagonist Lifetime Members 4,320 Member For: 21y 6m 10d Gender: Male Location: At the lights, waiting for you. Posted 29/01/05 01:42 PM Share Posted 29/01/05 01:42 PM C'mon guys this is getting boring. Geeseman's car ran a 118mph. Now my 11.7 was run at 119.05 mph so his car has every bit of power he claims, he just doesn't have the experience to use it at the track that I have.Geea runs around the 120mph as well. Now back to the edit, it sounds as though if you flash your standard tune back into it before you go in for a service then the dealer won't be able to tell. Now ethics is a topic I will stand well clear of, I wouldn't lie and didn't when my engine blew so I can back that up. But if other people choose to it is your decision to make and if you can get away with it then good luck.The edit should be more focused on providing a wider range of modification options and not on defrauding the Ford motor company.I will use the edit to mod my auto setup in time so I will let you all know how it goes.<{POST_SNAPBACK}>Very wise words Deano. I hope you're feeling better. Geea. Link to comment Share on other sites More sharing options...
Guest Guests Posted 29/01/05 03:16 PM Share Posted 29/01/05 03:16 PM what deano and geea said geeseman come down and run at calder with us!!!seems to me this site is getting more and more b**chy relax and post facts not crap?its still my favorite site but its getting boring very boring !!! Link to comment Share on other sites More sharing options...
Paranormal Member 469 Member For: 21y 2m 28d Location: Brissy Posted 29/01/05 11:22 PM Share Posted 29/01/05 11:22 PM I have a question... the XR6T is fitted with knock sensors, yet a few of you guys said that you were geting detonation.Does this mean that the Unichip also affects the engine computers ability to retard the timing in order to avoid detonation? I would be very worried if this was the case.Im assuming the SCT method of direct PCM flashing would not have this problem.Ross<{POST_SNAPBACK}>Answer anyone? Link to comment Share on other sites More sharing options...
Guest Guests Posted 30/01/05 12:30 AM Share Posted 30/01/05 12:30 AM I have a question... the XR6T is fitted with knock sensors, yet a few of you guys said that you were geting detonation.dw....yes sounds that wayDoes this mean that the Unichip also affects the engine computers ability to retard the timing in order to avoid detonation? I would be very worried if this was the case.dw.... I'd say no as both unichip/xede both give or take from std figgure! eg std 20deg +2=22 det/knock retard std 16deg+1.6=17.6 etc. so it would still retard acordingly?Im assuming the SCT method of direct PCM flashing would not have this problem.dw....it seems some do especially in sunny qld there is a guy who posted his sheets and stated he had knock on both 8 and 10 psi maps!!Ross<{POST_SNAPBACK}>Answer anyone?<{POST_SNAPBACK}>hope that helps!!! Link to comment Share on other sites More sharing options...
Geeseman Donating Members 1,805 Member For: 21y 25d Location: Sydney Posted 30/01/05 03:31 AM Share Posted 30/01/05 03:31 AM I have a question... the XR6T is fitted with knock sensors, yet a few of you guys said that you were geting detonation.My experience with it, and it has only happened once, is that it happened under full accelleration in 3rd gear, more specifically on the strip when I ran. Perhaps heat could have been a contributing factor (Im soon to fit an oil cooler but am already running aps intercooler). I had surging across the rpm range when I filled the tank which was 2 days before the event. Have bled it and since then havent had a repeat problem. Should have used octane booster beforehand but didnt think of it. My second car, a civic, has it often under hard accelleration. I think the fuel in sydney is often of very poor quality even the 98 stuff. Try to find a good servo and stick with it methinks Link to comment Share on other sites More sharing options...
Guest fredwho Guests Posted 30/01/05 04:37 AM Share Posted 30/01/05 04:37 AM Geeseman, seems to me you've been fed and ingested so much propaganda that you have become a believer in something you know nothing about.<{POST_SNAPBACK}>What? Your statement makes no sense <{POST_SNAPBACK}>I don't disagree that you car is fast geeseman, which is great, nothing wrong with that or what you have acheived.Was reading your post about real time tuning, from which I came up with my statement. Real time tuning beats edit...sorry buddy, that's where the ingestion of propaganda comes into play. Link to comment Share on other sites More sharing options...
