Vote yes if you have had a problem of some kind with your car... ANYTHING at all.
80 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Colossal Member
  • Member For: 20y 8m 9d
Just wanted to find out if there was anyone out there who has never had a problem of any kind with their BA XR/FPV? I'm talking anything from noisy diff to complete rebuild. Just out of curiosity.
Yes if you have
No if your havent.
https://www.fordxr6turbo.com/forum/topic/15293-who-has-problems-with-their-car/
  • Replies 48
  • Forum Superhero
  • Member For: 21y 5m 6d
Well just picked mine up from the dealers not 10 minutes ago, just a small list this time:
New Diff
New Gearbox (Transmax Z oil to be put in)
New clutch -Supplied by JB
Machine the flywheel
Machine the discs
Fit new pads - Supplied by JB
New Tint on rear left hand door
Reflash Pcm
Replace Gear knob
Replace Leather Gear boot
I think that's enough for one trip to the dealers, will see how the car goes over the next month or so. The clutch definately needs bedding in, it's either on or off, reminds me of my racing days, and the new RB 74 pads are the same.
Fingers crossed... :smilielol:
  • Iconoclast
  • Member For: 20y 7m 6d
Might save some bandwidth to start a thread...
Who hasnt has problems.... With their T
But then again, the *beep* and wheels thing remember
  • Former XT pilot
  • Member For: 21y 9m 10d
Has our T had problems.... HA! :lol:
October 2003 BA XR6T Sedan- 28,500km
1.‘shh shh’ noise coming from wheels (handbrake)
2. dented sun visor since brand new (looks like someones punched it hard)
3. audible diff whine at 85-110km/h
4. clunk when changing gears at low speeds (auto)
5. exhaust heat shield rattle on idle
6. paint defect on drivers side rear lower door (splodge mark)
7. paint flaking off intercooler
8. Car stalls often at traffic lights or when coming to a stop
9. Car will idle very roughly and RPM drops like its going to stall
10. Drivers side rear window sill strip jerks out when window is rolled down, and makes shuddering noise
11. Steering wheel shudders heaps when turning at low speeds
12. rear passenger side window seal is dodgy and creates wind noise
13. Front passenger seat has excessively worn causing the grey material to turn fuzzy (like the soft part of Velcro)
14. Front passenger side arm rest handle feels like it will fall off when you pull the door shut (very loose)
15. shuddering windscreen wipers
16. windscreen seal is dodgy and causes a lot of wind noise (loud whistling)
17. Clunk from rear when you plant it in 'D' (haha yes.. with an empty boot)
18. Horn is broken, only the high works and not the low so it sounds ghey..
19. Another mysterious clunk coming from the back of the car... possibly suspension?
20. Engine light keeps coming on, engine goes really flat but is fine when restarted (but for how long..)
21. Loss of power.. seems sluggish sometimes.
:sofa:
EDIT: Car's boorked in on monday for 30,000km service, I'll let you all know how it goes, should be an absolute pissa! :smilielol:
Guest TRACK
  • Guests
Just one or two issues with my T
1. 12 week wait – Quoted 6 weeks
2. Resprayed bonnet, faulty paint
3. Retinted 5 windows – scratches
4. Loose steering rack
5. Exhaust rattle
6. Squealing brakes – Machined rotors
7. Sunroof rattles - still does
8. Back fire – blew off a number of inlet hoses
9. Replaced drivers side air bag assembly and wiring harness
10. Drivers door lock rattles - still does
11. Flat spots - still does
12. Overboosts - still does
13. Rough idle - still does
14. Stalls - still does
15. Notchy power delivery - still does
16. Inconsistent power delivery - still does
17. Faulty handbrake / Scraping noise – attempted to be fixed 6 times
18. Drive line clunk - still does
19. Replaced gearbox – 5th gear crunching
20. Replaced fuel pump
21. Replaced waste gate
22. Bi-passed turbo boost solenoid
23. Replaced turbo boost solenoid
24. Hydraulic lifter type noise when cold
25. Replaced turbo
26. Replaced water pump
27. Replaced driver door locking mechanism
28. Replaced brake pads – TSB on squealing premium brakes
29. Replaced broken trim while being serviced
30. Clunk on full lock – Re-adjust steering rack
31. Grumble from rear end – Diff chatter. Further inspections required
32. Engine re-flash LOTS of times
33. Air leak around the turbo somewhere
NOT HAPPY JAN :smilielol::sofa::sofa:
  • FPV521
  • Member For: 20y 7m 28d
Well that's really dissapointing. :msm:
Good luck getting all that fixed. :sofa:
Are your dealers idiots or something? :smilielol:
I mean how could they let all of these problems mount up.
Ive had a body rattle that was fixed and the squeeky brakes thing is being fixed on Tuesday.
My dealer is great.
I do expect one or two small problems in the first couple of years of owning a new car, but the list you guys have is mind boggling :sofa:
Edited by Gavin Conroy
  • Former XT pilot
Forgot to add..
22. Cracks in blue plastic part of ICC
23. Paint wearing off cup holder and gear selector surround.
  • Colossal Member
2.    Resprayed bonnet, faulty paint.....
........................her inspections required
NOT HAPPY JAN  :wacko:  :wacko:  :nono:
<{POST_SNAPBACK}>
:o :nono::nono:
Would have been cheaper for ford to give you a new car.
  • Member For: 20y 10m 10d
:nono: Rust removed from drivers side roof , Roof respray and replacement windscreen rust appeared when it was only 6 months old
now the ute has done 25000ks diff has to be replaced also turbo leak somewhere but otherwise a nice ute to clock up the ks in :wacko:
