spin Member 15 Member For: 21y 7m 15d Location: Melbourne Posted 04/01/05 12:06 PM Share Posted 04/01/05 12:06 PM Thought I would share this with you all to see if any one else has had a similar problem with their Interior Command Centre thingy (just another of my go-machines many problems).On my way back from watching Team America (a must see for some pant wetting laughs), I notice the CD I was playing stated sounding way off the normal quality of the prem. audio system. I'm not sure most people would pick it up as it was quite subtle and I have expirience in music and sound engineering . I would explain it as though there was too much gain comming from the amp therefore the end sound being slightly distorted and harder to listen to.Anywho. I stop my go-machine at the servo, start it up and hear a beep from the ICC. I look @ the screen which briefly displayed "SYSTEM ERROR" after which it reset itself (full reset), took its time to find the loaded CD's and resumed normal function with normal sound quality.Stepped into my now familiar service department, had a chat and they have never heard of the ICC thingys doing this before so he's apparently speaking to ford tomorrow about it. It also seems quite hard to contact the overseas manufacturers regarding this or should I say in general (can't recall their name).Anyone else had problems with the prem audio packs (technical only lol) or ICC's?..hope so lol :(Also, in case it hasn't yet been mentioned, Ford have released a new patch for the resin boxes fixng rough idle issues, overboost fangdoodles and something else which escapes my memory. -> comming to a service department near you in the next few weeks. Apparently takes 3/4's hr.cheers Link to comment https://www.fordxr6turbo.com/forum/topic/14967-icc-system-error/ Share on other sites More sharing options...
Falchoon I see red Member 5,758 Member For: 22y 6m 21d Location: nowhere in particular Posted 04/01/05 09:58 PM Share Posted 04/01/05 09:58 PM Haven't heard of that problem before either. Only problem I've heard of is when some DIYers or dodgy shops try and fit mobile phone kits and drill holes where there isn't meant to be holes drilled and end up stuffing the ICC. Link to comment https://www.fordxr6turbo.com/forum/topic/14967-icc-system-error/#findComment-205510 Share on other sites More sharing options...
BlueXR6Turbo The Best Member Donating Members 1,970 Member For: 22y 5m 28d Gender: Male Location: Adelaide Posted 05/01/05 04:47 AM Share Posted 05/01/05 04:47 AM Only problem I've had is when the 6-stacker jammed and I couldn't get my CD's out. Link to comment https://www.fordxr6turbo.com/forum/topic/14967-icc-system-error/#findComment-205630 Share on other sites More sharing options...
spin Member 15 Member For: 21y 7m 15d Location: Melbourne Posted 05/01/05 09:41 AM Author Share Posted 05/01/05 09:41 AM Yeah I remember reading about your cd's getting stuck while it was happening, hoping it wouldnt do that to me.. I think I might check out the amp to see if it had anything to do with it.. :lol: lol about the hole drilling Link to comment https://www.fordxr6turbo.com/forum/topic/14967-icc-system-error/#findComment-205729 Share on other sites More sharing options...
SOON2BXR6T Member 78 Member For: 22y 1m Location: Adelaide Posted 05/01/05 10:25 PM Share Posted 05/01/05 10:25 PM Hi spininterested in the new ecu flash you talk about. My idle goes all over the shop when rolling up to lights etc but evens up when I actually stop. They re-flashed it at 30k service before x-mas (that will fix it and give you better fuel economy and provide world peace!) but it didnt make any difference at all!where did you find out about the "new" one? Is it the same as this one:http://www.fordxr6turbo.com/forum/index.php?showtopic=14750Thanks Ian Link to comment https://www.fordxr6turbo.com/forum/topic/14967-icc-system-error/#findComment-205832 Share on other sites More sharing options...
Antisocial Weird Member Member 1,347 Member For: 22y 5m 5d Location: ACT Posted 06/01/05 11:44 AM Share Posted 06/01/05 11:44 AM Mine did this when I disconnected it whilest installing mt DTV STB.I just turned it off locked then unlocked the car, put the key in the ign and turned it to acc and the ICC was happy again, scared crap out of me for a few moments though. Link to comment https://www.fordxr6turbo.com/forum/topic/14967-icc-system-error/#findComment-206157 Share on other sites More sharing options...
Lawsy Wanabe mechanical engineer Donating Members 960 Member For: 20y 9m 21d Gender: Male Location: At the computer, obviously..... Posted 06/01/05 12:45 PM Share Posted 06/01/05 12:45 PM Does that when you change the battery too..... It just takes a second boot for it to auto dial in your security code (which is locked to your car). If you were to take it out and put it into another car it wouldn't work and would give you that message constantly.....ps, scared the crap out of us too! We only took tbe battery out to allow access to under the battery (duh!).... We thought we totaly munted the thing..... Link to comment https://www.fordxr6turbo.com/forum/topic/14967-icc-system-error/#findComment-206187 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 2m 13d Gender: Male Location: Brisbane Posted 06/01/05 09:05 PM Share Posted 06/01/05 09:05 PM I've noticed with the poverty pack sound you have to actually start the car after reconnecting the batterry - I can't remember exactly what it says but I think it is either 'code' or 'error'. But you can't do anything until the engine is running in any case.Trent. Link to comment https://www.fordxr6turbo.com/forum/topic/14967-icc-system-error/#findComment-206240 Share on other sites More sharing options...
tupperware Member 113 Member For: 22y 6m 11d Location: South Brizzy Posted 01/02/05 10:59 PM Share Posted 01/02/05 10:59 PM Spin,Any progress with the error? I had this come up twice, both times it reset after a couple of seconds, but it makes your pucker twitch. I can hear it now " Sorry sir you've edited the PCM, that's $2500 for a new ICC, have a nice day"Regards,Cameron Link to comment https://www.fordxr6turbo.com/forum/topic/14967-icc-system-error/#findComment-215213 Share on other sites More sharing options...
HUSTLER Member 663 Member For: 21y 10m 17d Location: Broken Hill Posted 01/02/05 11:54 PM Share Posted 01/02/05 11:54 PM Are u sure u just didnt have the loud button on!!! LOL and then slammed the door too hard with the sh*ts when u jumped back in the car causing the ECU to fail !! Link to comment https://www.fordxr6turbo.com/forum/topic/14967-icc-system-error/#findComment-215225 Share on other sites More sharing options...
