Guest PSIXR6 Guests Posted 28/12/04 05:24 AM Share Posted 28/12/04 05:24 AM From what I recall from the Herrod demo night of "Stealth" when the 10psi map was run, boost was tappered off from 4800rpm to about 7psi.... Just to give the injectors a bit of head room. ~allen Link to comment https://www.fordxr6turbo.com/forum/topic/14836-boost-and-the-stealth/page/4/#findComment-203472 Share on other sites More sharing options...
Guest Guests Posted 28/12/04 05:26 AM Share Posted 28/12/04 05:26 AM turb06 said: aps said: turb06 said: aps said: jetute said: you can run the 10psi on standard injectors... the two maps are for stock cars remember... I have been in a ar that runs the 10psi... feels great!!<{POST_SNAPBACK}>I'd love to see the air fuel mixtures at 10 PSI...............I reclon they'd be dangerously lean. Peter<{POST_SNAPBACK}>Pete what is the ideal air/fuel ratio for an xr6T?Dazza<{POST_SNAPBACK}>At full engine load (high rpm) I would not run the engine any leaner than .82 lambda. Peter<{POST_SNAPBACK}>Ok...I'm gonna need to do some research to find out exactly what that means But thanks.Dazza.<{POST_SNAPBACK}>low 12's Link to comment https://www.fordxr6turbo.com/forum/topic/14836-boost-and-the-stealth/page/4/#findComment-203473 Share on other sites More sharing options...
aps Member 1,505 Member For: 22y 2m 21d Posted 28/12/04 05:36 AM Share Posted 28/12/04 05:36 AM Dynowog said: aps said: jetute said: you can run the 10psi on standard injectors... the two maps are for stock cars remember... I have been in a ar that runs the 10psi... feels great!!<{POST_SNAPBACK}>I'd love to see the air fuel mixtures at 10 PSI...............I reclon they'd be dangerously lean. Peter<{POST_SNAPBACK}>peter in the only instance that ive seen one done they were ritcher than the std mixtures but were still 13's mind?<{POST_SNAPBACK}>Nick Only a mad man would run a turbo engine at 13:1 air fuel ratio under full load conditions (whose car was running these sort of mixtures)...............gee this is going to be a good year for engine builders if this is the case. :lol: Peter Link to comment https://www.fordxr6turbo.com/forum/topic/14836-boost-and-the-stealth/page/4/#findComment-203474 Share on other sites More sharing options...
Guest Guests Posted 28/12/04 05:51 AM Share Posted 28/12/04 05:51 AM aps said: Dynowog said: aps said: jetute said: you can run the 10psi on standard injectors... the two maps are for stock cars remember... I have been in a ar that runs the 10psi... feels great!!<{POST_SNAPBACK}>I'd love to see the air fuel mixtures at 10 PSI...............I reclon they'd be dangerously lean. Peter<{POST_SNAPBACK}>peter in the only instance that ive seen one done they were ritcher than the std mixtures but were still 13's mind?<{POST_SNAPBACK}>Nick Only a mad man would run a turbo engine at 13:1 air fuel ratio under full load conditions (whose car was running these sort of mixtures)...............gee this is going to be a good year for engine builders if this is the case. :lol: Peter<{POST_SNAPBACK}>hence my concerns I did not reveal this earlier as I did not want a fightremember though they were ritcher than std map by about 20-30% so it was a step in the right direction and a lot ritcher than some others ive tested! Link to comment https://www.fordxr6turbo.com/forum/topic/14836-boost-and-the-stealth/page/4/#findComment-203476 Share on other sites More sharing options...
xrturb god bless my kids Member 611 Member For: 21y 1m 3d Gender: Male Location: claremont meadows, sydney Posted 28/12/04 06:37 AM Share Posted 28/12/04 06:37 AM I dont think capa would have brought a product out in the market without knowing it would be up to scratch saying that I bet this is how you reacted when ls1edit came out Link to comment https://www.fordxr6turbo.com/forum/topic/14836-boost-and-the-stealth/page/4/#findComment-203490 Share on other sites More sharing options...
FPV 521 FPV521 Member 989 Member For: 20y 8m 22d Gender: Male Posted 28/12/04 06:46 AM Author Share Posted 28/12/04 06:46 AM turb06 said: Dynowog said: no point in me repling to this is there? :lol: diferent system run diferent control stratigies and it seems there is another reason why ems can get more from these injectors than piggy backs and posibly edit but hey that's all I say as I dont want another deleted thread!there are many so called std theories as to 5cc = 1hp etc this is upto the individual as to which to believe there are many sites with this info google search will bring up heaps of them.<{POST_SNAPBACK}>If you know dynowog please tell us, its just that APS and chiptorque recommend different injectors above 280kw, from what I understand the standard injectors will run that power but in doing so are performing at their peak nearly all the time and that reduces injector life considerably. Gav - most guys are running bosch 968's they are expensive but will handle lots of power.Dazza.<{POST_SNAPBACK}>Thanks for the injector info Dazza. What valve springs are best to use? Link to comment https://www.fordxr6turbo.com/forum/topic/14836-boost-and-the-stealth/page/4/#findComment-203494 Share on other sites More sharing options...
aps Member 1,505 Member For: 22y 2m 21d Posted 28/12/04 07:03 AM Share Posted 28/12/04 07:03 AM Dynowog said: remember though they were ritcher than std map by about 20-30% so it was a step in the right direction and a lot ritcher than some others ive tested!<{POST_SNAPBACK}>Nick I'm not sure what you are referring to though the stock XR6T engine runs very rich mixtures at stock boost levels.Peter Link to comment https://www.fordxr6turbo.com/forum/topic/14836-boost-and-the-stealth/page/4/#findComment-203501 Share on other sites More sharing options...
aps Member 1,505 Member For: 22y 2m 21d Posted 28/12/04 07:06 AM Share Posted 28/12/04 07:06 AM xrturb said: I dont think capa would have brought a product out in the market without knowing it would be up to scratch <{POST_SNAPBACK}>We ars discussing the air/fuel mixtures here not the actual product, obviously the mixtures can be made richer or the boost lowered to make the mixtures safe. Peter Link to comment https://www.fordxr6turbo.com/forum/topic/14836-boost-and-the-stealth/page/4/#findComment-203503 Share on other sites More sharing options...
Guest Guests Posted 28/12/04 07:12 AM Share Posted 28/12/04 07:12 AM Gavin Conroy said: Thanks for the injector info Dazza. What valve springs are best to use? <{POST_SNAPBACK}>std till you have a problem same with the injectorsjust a little equation for you allif you have 6000 rpm you then divide this by 60 seconds it gives you 100 milliseconds you then multi ply this by 2 as the pcm only fires injectors every 2nd rpm/4th stroke you now have 200 milliseconds you then divde this by six as you have six pulse's due to cylinder count it gives you 33.333333 milliseconds you then divide this by 100 to give you duty cycle and as an example pretzel uses 14 milliseconds at 10 psi boost how much dutycycle is he using and how much injector has he left for more power?this is at best your answer to injector size!!!!!enjoy dw Link to comment https://www.fordxr6turbo.com/forum/topic/14836-boost-and-the-stealth/page/4/#findComment-203504 Share on other sites More sharing options...
rapt Donating Members 317 Member For: 21y 7m 13d Location: gippsland Posted 28/12/04 07:15 AM Share Posted 28/12/04 07:15 AM std till you have a problem same with the injectorsjust a little equation for you allif you have 6000 rpm you then divide this by 60 seconds it gives you 100 milliseconds you then multi ply this by 2 as the pcm only fires injectors every 2nd rpm/4th stroke you now have 200 milliseconds you then divde this by six as you have six pulse's due to cylinder count it gives you 33.333333 milliseconds you then divide this by 100 to give you duty cycle and as an example pretzel uses 14 milliseconds at 10 psi boost how much dutycycle is he using and how much injector has he left for more power?this is at best your answer to injector size!!!!!enjoy dw LMFAOOOOOOOOOOOOOO :lol: Link to comment https://www.fordxr6turbo.com/forum/topic/14836-boost-and-the-stealth/page/4/#findComment-203505 Share on other sites More sharing options...
