Guest Guests Posted 28/12/04 03:38 AM Share Posted 28/12/04 03:38 AM no point in me repling to this is there? :lol: diferent system run diferent control stratigies and it seems there is another reason why ems can get more from these injectors than piggy backs and posibly edit but hey that's all I say as I dont want another deleted thread!there are many so called std theories as to 5cc = 1hp etc this is upto the individual as to which to believe there are many sites with this info google search will bring up heaps of them. Link to comment Share on other sites More sharing options...
turb06 Dark Knight Mafia Member No. - 666 Member 3,667 Member For: 22y 1m 16d Location: Toowoomba Posted 28/12/04 03:54 AM Share Posted 28/12/04 03:54 AM Dynowog said: no point in me repling to this is there? :lol: diferent system run diferent control stratigies and it seems there is another reason why ems can get more from these injectors than piggy backs and posibly edit but hey that's all I say as I dont want another deleted thread!there are many so called std theories as to 5cc = 1hp etc this is upto the individual as to which to believe there are many sites with this info google search will bring up heaps of them.<{POST_SNAPBACK}>If you know dynowog please tell us, its just that APS and chiptorque recommend different injectors above 280kw, from what I understand the standard injectors will run that power but in doing so are performing at their peak nearly all the time and that reduces injector life considerably. Gav - most guys are running bosch 968's they are expensive but will handle lots of power.Dazza. Link to comment Share on other sites More sharing options...
aps Member 1,505 Member For: 22y 1m 3d Posted 28/12/04 04:18 AM Share Posted 28/12/04 04:18 AM jetute said: you can run the 10psi on standard injectors... the two maps are for stock cars remember... I have been in a ar that runs the 10psi... feels great!!<{POST_SNAPBACK}>I'd love to see the air fuel mixtures at 10 PSI...............I reclon they'd be dangerously lean. Peter Link to comment Share on other sites More sharing options...
turb06 Dark Knight Mafia Member No. - 666 Member 3,667 Member For: 22y 1m 16d Location: Toowoomba Posted 28/12/04 04:20 AM Share Posted 28/12/04 04:20 AM aps said: jetute said: you can run the 10psi on standard injectors... the two maps are for stock cars remember... I have been in a ar that runs the 10psi... feels great!!<{POST_SNAPBACK}>I'd love to see the air fuel mixtures at 10 PSI...............I reclon they'd be dangerously lean. Peter<{POST_SNAPBACK}>Pete what is the ideal air/fuel ratio for an xr6T?Dazza Link to comment Share on other sites More sharing options...
aps Member 1,505 Member For: 22y 1m 3d Posted 28/12/04 04:21 AM Share Posted 28/12/04 04:21 AM xrturb said: mind you maybe the scare tactic that aps puts into everyone<{POST_SNAPBACK}>Or maybe the truth..............you'll never know unless you check the mixtures across the entire rpm range at full engine load. :lol: Peter Link to comment Share on other sites More sharing options...
aps Member 1,505 Member For: 22y 1m 3d Posted 28/12/04 04:25 AM Share Posted 28/12/04 04:25 AM turb06 said: aps said: jetute said: you can run the 10psi on standard injectors... the two maps are for stock cars remember... I have been in a ar that runs the 10psi... feels great!!<{POST_SNAPBACK}>I'd love to see the air fuel mixtures at 10 PSI...............I reclon they'd be dangerously lean. Peter<{POST_SNAPBACK}>Pete what is the ideal air/fuel ratio for an xr6T?Dazza<{POST_SNAPBACK}>At full engine load (high rpm) I would not run the engine any leaner than .82 lambda. Peter Link to comment Share on other sites More sharing options...
turb06 Dark Knight Mafia Member No. - 666 Member 3,667 Member For: 22y 1m 16d Location: Toowoomba Posted 28/12/04 04:37 AM Share Posted 28/12/04 04:37 AM aps said: turb06 said: aps said: jetute said: you can run the 10psi on standard injectors... the two maps are for stock cars remember... I have been in a ar that runs the 10psi... feels great!!<{POST_SNAPBACK}>I'd love to see the air fuel mixtures at 10 PSI...............I reclon they'd be dangerously lean. Peter<{POST_SNAPBACK}>Pete what is the ideal air/fuel ratio for an xr6T?Dazza<{POST_SNAPBACK}>At full engine load (high rpm) I would not run the engine any leaner than .82 lambda. Peter<{POST_SNAPBACK}>Ok...I'm gonna need to do some research to find out exactly what that means But thanks.Dazza. Link to comment Share on other sites More sharing options...
CrankyBen Member 37 Member For: 20y 7m 9d Location: Canberra Posted 28/12/04 05:16 AM Share Posted 28/12/04 05:16 AM Quote Pete what is the ideal air/fuel ratio for an xr6T?DazzaAt full engine load (high rpm) I would not run the engine any leaner than .82 lambda. PeterOk...I'm gonna need to do some research to find out exactly what that means But thanks.Dazza.From my simplisitc understanding of it, 0.82 lambda means 18% richer than stoichiometric (stoichiometric being the "ideal" combustion where all the fuel is burned completely). Link to comment Share on other sites More sharing options...
jordak Member 1,226 Member For: 20y 10m 1d Posted 28/12/04 05:22 AM Share Posted 28/12/04 05:22 AM aps said: jetute said: you can run the 10psi on standard injectors... the two maps are for stock cars remember... I have been in a ar that runs the 10psi... feels great!!<{POST_SNAPBACK}>I'd love to see the air fuel mixtures at 10 PSI...............I reclon they'd be dangerously lean. Peter<{POST_SNAPBACK}>You have, they were on my Dyno Sheet.You commented on the fluctuations but not on the fact that it peaked @ 12.5 Is 12.5 dangerously high ?Steve Link to comment Share on other sites More sharing options...
Guest Guests Posted 28/12/04 05:23 AM Share Posted 28/12/04 05:23 AM aps said: jetute said: you can run the 10psi on standard injectors... the two maps are for stock cars remember... I have been in a ar that runs the 10psi... feels great!!<{POST_SNAPBACK}>I'd love to see the air fuel mixtures at 10 PSI...............I reclon they'd be dangerously lean. Peter<{POST_SNAPBACK}>peter in the only instance that ive seen one done they were ritcher than the std mixtures but were still 13'sand forgive me if im wrong they seemed leaner than normal?that's why my offer to do a free b4 and after on someones edit for my peace of mind? Link to comment Share on other sites More sharing options...
