bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 4m 21d Gender: Male Location: Sydney Posted 22/12/04 09:05 PM Share Posted 22/12/04 09:05 PM Mals BA XR6T said: Also, I thought that the timing/cams control was changed, and this should have produced more bottom end? (After 2 years with the Turbo, I still miss the bottom end pull of my old AU 5ltr)....Mal<{POST_SNAPBACK}>Mal, I don't think there is any substitute for cubic inches when it comes to initial torque from idle to 1500 revs. The Nizpro revised piping gives better response from say 1800 revs, but for off-idle torque it's very hard to beat a 5-6 litre V8 (fyi I've had 8 V8's). Also, I don't think that this new software has independent cam control, (correct me if I'm wrong), so retaining the inefficient factory inlet piping, and without the independent cam control, I would not expect much extra low down torque.I'm going down the more expensive path of Motec with independent cam control feature and larger turbo, so that'll be interesting to see what low down improvement in torque is possible.Brian Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/3/#findComment-202048 Share on other sites More sharing options...
DBOSS Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car Member 3,918 Member For: 21y 10m 23d Location: D SHIRE! Posted 23/12/04 07:59 AM Share Posted 23/12/04 07:59 AM When will your beast be ready Brian Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/3/#findComment-202380 Share on other sites More sharing options...
FPV 521 FPV521 Member 989 Member For: 20y 8m 10d Gender: Male Posted 23/12/04 08:13 AM Share Posted 23/12/04 08:13 AM Probably a really stupid question but is this edit the stealth or something different. It sounds like you have fitted it yourself.There are that many different systems being talked about I am wondering which one this is? Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/3/#findComment-202386 Share on other sites More sharing options...
Mals BA XR6T Member 381 Member For: 22y 5m 12d Location: Sydney Posted 23/12/04 08:28 AM Author Share Posted 23/12/04 08:28 AM It's CAPA's Flash Tuner (well SCT Flash Tuner to be exact, but programmed by CAPA) Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/3/#findComment-202391 Share on other sites More sharing options...
FPV 521 FPV521 Member 989 Member For: 20y 8m 10d Gender: Male Posted 23/12/04 08:32 AM Share Posted 23/12/04 08:32 AM Mals BA XR6T said: It's CAPA's Flash Tuner (well SCT Flash Tuner to be exact, but programmed by CAPA)<{POST_SNAPBACK}>Thanks for that. Getting some good info. Great post!!! Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/3/#findComment-202393 Share on other sites More sharing options...
Mals BA XR6T Member 381 Member For: 22y 5m 12d Location: Sydney Posted 23/12/04 08:34 AM Author Share Posted 23/12/04 08:34 AM Damn, my Traction Control is still broken. I'll go back to the factory tune and see if it still happens Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/3/#findComment-202396 Share on other sites More sharing options...
fordboy1981 Donating Members 2,075 Member For: 22y 3m 27d Gender: Male Location: Sydney, NSW Posted 23/12/04 10:06 AM Share Posted 23/12/04 10:06 AM fordboy1981 said: sheet, there's quite a few people reading this!So the AFs won't be perfect when you first flash the PCM, but as time goes on it will learn and correct the AFs??wasn't the cam timing changed too, so wouldn't this affect (for the better) it's off boost response??I was under the impression that the 8psi tune was set very rich, why was this done??The 10psi tune was meant to have all it's safety limits move out of harms way, does this mean that with the addition of a big exhaust (including cat) and intercooler the computer will "learn" to cope and stay at 10psi with good AFs??Dave.^^^^anyone care to try ând answer my questions??^^^^ Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/3/#findComment-202429 Share on other sites More sharing options...
obrut6 Member 160 Member For: 21y 1m 8d Location: Sydney Posted 23/12/04 10:30 AM Share Posted 23/12/04 10:30 AM got mine today,its AWESOME !!!!!!straight in to the 10psi map,at a couple of stages it would drop power for an instant then pick up again, not as smooth for me as the 8psi which I am using now. cant get enough of this, its like having a new car again. Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/3/#findComment-202454 Share on other sites More sharing options...
xrturb god bless my kids Member 611 Member For: 21y 20d Gender: Male Location: claremont meadows, sydney Posted 23/12/04 10:33 AM Share Posted 23/12/04 10:33 AM I am the same ..I am using the 8psi it seem to work better for me too Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/3/#findComment-202457 Share on other sites More sharing options...
C.S.I Member 651 Member For: 20y 4m 29d Gender: Male Location: Gold Coast Posted 23/12/04 10:40 AM Share Posted 23/12/04 10:40 AM xrturb said: I am the same ..I am using the 8psi it seem to work better for me too<{POST_SNAPBACK}>Brad, can you keep us posted on whether the efuel economy goes up or down at 'normal' levels of driving.Thanks, Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/3/#findComment-202461 Share on other sites More sharing options...
