jordak Member 1,226 Member For: 20y 11m 18d Posted 04/01/05 01:46 PM Share Posted 04/01/05 01:46 PM 51XRT said: rapt said: Three questions that I havent yet seen the answers to:-1) what are the claimed rwkw and therfore engine KW for the 8psi and 10 psi maps on a standard T with no custome tune?2) can you still safely use the lower 2 fuel grades, being unleaded (91 Ron) and premium (95 Ron) with the 8psi edit?3) how long does it actually take to swap between the different maps, including back to standard? at a guess the 10psi would be about 230 rwkw8psi about 200 rwkwas I said a guess<{POST_SNAPBACK}>Another way to look at the power increases is to look at the improvement in RWKW from standard. That way, you can take into account the differences in the engine outputs before any program changes.So, how many ADDITIONAL RWKW do you guys thing you are getting from the 2 maps?<{POST_SNAPBACK}>30rwkw on 8 and 60rwkw on 10 Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/22/#findComment-205454 Share on other sites More sharing options...
Blonk Iconoclast Donating Members 4,330 Member For: 20y 8m 1d Gender: Male Location: CH Posted 04/01/05 04:39 PM Share Posted 04/01/05 04:39 PM Sounds about right from what I have gathered...........Cheap HP............... Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/22/#findComment-205475 Share on other sites More sharing options...
DBOSS Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car Member 3,918 Member For: 21y 11m 5d Location: D SHIRE! Posted 04/01/05 09:59 PM Share Posted 04/01/05 09:59 PM Without dyno to back me up I would say 20-30 RWKLW at 8 psi and about an extra 10-20 rwklw tops for the 10 psi mapCYA JEFF Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/22/#findComment-205512 Share on other sites More sharing options...
jordak Member 1,226 Member For: 20y 11m 18d Posted 05/01/05 04:05 AM Share Posted 05/01/05 04:05 AM jordak said: 51XRT said: rapt said: Three questions that I havent yet seen the answers to:-1) what are the claimed rwkw and therfore engine KW for the 8psi and 10 psi maps on a standard T with no custome tune?2) can you still safely use the lower 2 fuel grades, being unleaded (91 Ron) and premium (95 Ron) with the 8psi edit?3) how long does it actually take to swap between the different maps, including back to standard? at a guess the 10psi would be about 230 rwkw8psi about 200 rwkwas I said a guess<{POST_SNAPBACK}>Another way to look at the power increases is to look at the improvement in RWKW from standard. That way, you can take into account the differences in the engine outputs before any program changes.So, how many ADDITIONAL RWKW do you guys thing you are getting from the 2 maps?<{POST_SNAPBACK}>30rwkw on 8 and 60rwkw on 10 <{POST_SNAPBACK}>Sorry should have said......that's not a guess, that's what the dyno showed ! Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/22/#findComment-205620 Share on other sites More sharing options...
johng001 Member 192 Member For: 21y 23d Location: Melb Posted 05/01/05 07:37 AM Share Posted 05/01/05 07:37 AM jordak said: johng001 said: rapt said: Three questions that I havent yet seen the answers to:-1) what are the claimed rwkw and therfore engine KW for the 8psi and 10 psi maps on a standard T with no custome tune?2) can you still safely use the lower 2 fuel grades, being unleaded (91 Ron) and premium (95 Ron) with the 8psi edit?3) how long does it actually take to swap between the different maps, including back to standard? at a guess the 10psi would be about 230 rwkw8psi about 200 rwkwas I said a guess<{POST_SNAPBACK}>At the Herred launch night they got 236kw from the 8psi and 252kw from the 10 psi. From a stock atandard T.<{POST_SNAPBACK}>What was the stock rwkw and was it a manual or auto?<{POST_SNAPBACK}>It was manual, I'm not sure of the stock figure exactly I think it was 203kw. DW Was there he may remember. Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/22/#findComment-205678 Share on other sites More sharing options...
Guest Guests Posted 05/01/05 07:49 AM Share Posted 05/01/05 07:49 AM sounds right? Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/22/#findComment-205685 Share on other sites More sharing options...
rapt Donating Members 317 Member For: 21y 7m 13d Location: gippsland Posted 05/01/05 09:00 AM Share Posted 05/01/05 09:00 AM It was manual, I'm not sure of the stock figure exactly I think it was 203kw. DW Was there he may remember.mmmmmmm sounds a lot for a stock T !!!!!!!!!!!!!!! Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/22/#findComment-205708 Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 20y 4m 24d Location: Perth Posted 05/01/05 10:56 AM Share Posted 05/01/05 10:56 AM Just read this topic, sounds good.Anyone done bigger injectors, fuel pump, FMIC and exhaust and tried the SCT tuning? Would be interesting to see an APS Phase 3 setup without the Unichip and with the SCT tune.What would be the limit of boost with this type of setup and what rwkw would you expect? Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/22/#findComment-205749 Share on other sites More sharing options...
DBOSS Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car Member 3,918 Member For: 21y 11m 5d Location: D SHIRE! Posted 05/01/05 11:04 AM Share Posted 05/01/05 11:04 AM M6 XR6T said: Just read this topic, sounds good.Anyone done bigger injectors, fuel pump, FMIC and exhaust and tried the SCT tuning? Would be interesting to see an APS Phase 3 setup without the Unichip and with the SCT tune.What would be the limit of boost with this type of setup and what rwkw would you expect?<{POST_SNAPBACK}>Im ready to go the problem is there's nobody available in Sydney that can custom tune it Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/22/#findComment-205754 Share on other sites More sharing options...
Trumpy What's happening? Lifetime Members 1,605 Member For: 22y 5m 24d Gender: Male Location: Steel City, NSW Posted 05/01/05 11:05 AM Share Posted 05/01/05 11:05 AM xr6ikness said: Im ready to go the problem is there's nobody available in Sydney that can custom tune it <{POST_SNAPBACK}>Have you called CPC yet? Link to comment https://www.fordxr6turbo.com/forum/topic/14775-edit-review/page/22/#findComment-205755 Share on other sites More sharing options...
