  • god bless my kids
  • Member For: 21y 24d
  geea said:
  xrturb said:
well ive been a bit quiet about edit and as I was reading the post about the thte intercooler pipe coming off I thought there should have been more power from the sct ,so I check and there it was pipe  was off  ...well I connected it and away I went ...the power is just magic  and that is at 8psi I havae a manual and to just take off normally and plant isc and get wheel spin is  great ..all I can say is damn double points
<{POST_SNAPBACK}>
Brad will you be making the trek to WSID on Jan 12th. It would be great to see an edited T run down the 1/4. :spoton:
Geea. :w00t2:
<{POST_SNAPBACK}>
might do that but neeed pointers though
  • Replies 286
  • Site protagonist
  • Member For: 22y 7d
  xrturb said:
  geea said:
<{POST_SNAPBACK}>
Geea. :w00t2:
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
On the night there will be alot of blokes with 1/4 experience. I'll tell you what I know and no doubt others will do the same.
Geea. :ermm:
  • Wanabe mechanical engineer
  • Member For: 20y 8m 2d
I might even turn up, 12th you say eh..... Wednesday yes?
What time?
  • FPV521
  • Member For: 20y 8m 14d
  Dynowog said:
  Gavin Conroy said:
  Mals BA XR6T said:
It's CAPA's Flash Tuner (well SCT Flash Tuner to be exact, but programmed by CAPA)
<{POST_SNAPBACK}>
Thanks for that. Getting some good info. Great post!!! :spoton:
<{POST_SNAPBACK}>
just to confuse you more its the stealth!!!
ok ok its both they are the same the one the only sct advantage/capa edit/steath from herrod!!!
<{POST_SNAPBACK}>
Thanks, :w00t2:
  • EMS makes MAGIC MUMBO !
  • Member For: 21y 5m 7d
  bcl said:
  xrturb said:
question ..would you car loser power if the intercooler pipe came off
<{POST_SNAPBACK}>
I can't remember hearing this happening on the Ford, but I expect that the IC pipes should be pretty well clamped. IC pipe coming off is more likely where aftermarket kits have been fitted. If a clamp is not tight enough, a hose is most likely to separate when you give it a bootfull and you'll lose all power and probably cut out. It hasn't happenend on my Ford, but on my other cars where this has happened, and quite a few times, the car can be restarted, will act very sick, idles very roughly, massively overfuelling and giving out black smoke, as the air flow sensor is being bypassed.
Someone may have tested this on their Ford.
Brian
<{POST_SNAPBACK}>
BCL,
I have had the pipes off on my car, and because Ford doesn't actually have an Air Flow Sensor, (it works of Manifold Pressure) there is no issue with overfuelling etc.. It is basicaly then a low compression N/A !
Idle is fine, just don't expect performance ! Ask Geea, with his boostless run at Calder !
Hope this helps
Pretzel
  • Site protagonist
  Eugene said:
Hey Geea, you going to WSID on the 12th.
I can be there if there is going to be a crew, who is up.
(sorry off topic)
<{POST_SNAPBACK}>
Yep Eugene, I'll be there on the 12th.HERE is a link to the thread. It would be great if you could make it so I could meet you, too.
Geea. :nod:
  • Toughest BA Turbo
  • Member For: 22y 4m 25d
  Pretzel said:
BCL,
Hope this helps
Pretzel
<{POST_SNAPBACK}>
Thanks, it's good to know it's still drivable though.
  • Member For: 22y 5m 16d
Ok - Traction Control
It's all the extra power that is farking it up.
If I drive it like a complete tool, and keep my foot flat to the floor, even when the TC comes on, it turns itself off (on a dry road anyway).
If I drive it like a "normal human" (using my wifes words not mine) and TC comes on, and I back off just a little (with TC still flashing), than TC doesn't disable??
TC doesn't disable on a wet road regardless of how long the TC is on for.
Summary - You should stop driving like a Complete Tool! (yes dear :) )
I hope this information is interesting to some anyway.
Mal
