Mals BA XR6T Member 381 Member For: 22y 3m 6d Location: Sydney Posted 22/12/04 09:38 AM Share Posted 22/12/04 09:38 AM Guys,I've run the edit today, please see a short list belowTHE GOOD1. Great mid range, and feels very strong (8 PSI Tune)2. The 8 PSI tune hits "Power Band" at 4500 rpm3. Great mid range, and feels even stronger (10 PSI Tune)4. Gear shifts no longer have the reduced power/torque when changing (Auto)5. Breaks traction very easy (this could be bad )6. The 10 PSI tune has smooth power until about 5200 rpm7. Quick and easy to installTHE BAD1. The mid range pull (peak) from the 8 PSI tune goes away after a short drive (I think it's the tune learning the correct settings?? Although I liked it, I suspect this is actually 'Good')2. No change to bottom end pull. I'm not impressed about this, I was lead to believe it would be improved.3. The gear changes are NOT firmer, IMO they are the same (excluding point 3 of THE GOOD of course)THE UGLY1. If traction control comes on at higher speeds a few times (say 60kms), it disables itself?? I'm not impressed about this at all2. Power at a higher rev range on the 10 PSI tune drops off quickly (above about 5200 rpm) I've reverted back to the 8 PSI as it feels much better.If anyone has any comments please feel free to post.Street Tuner, if you could comment on my experience that would be great.Please guys, I'm not interested in talking about alternative products, I've paid for the Flash Tuner, and that is all I'm interested in now regardless if it still needs some more development. I'm happy to work with CAPA/Street Tuner and provide some feedbackThanksMal Link to comment Share on other sites More sharing options...
xrturb god bless my kids Member 611 Member For: 20y 10m 12d Gender: Male Location: claremont meadows, sydney Posted 22/12/04 09:42 AM Share Posted 22/12/04 09:42 AM mine is a manual and the first thing I notice was on excelaration before it was like it was pulsing and now just direct power Link to comment Share on other sites More sharing options...
Guest Guests Posted 22/12/04 09:44 AM Share Posted 22/12/04 09:44 AM (edited) not another thread?well done there though! Edited 22/12/04 09:45 AM by Dynowog Link to comment Share on other sites More sharing options...
rapt Donating Members 317 Member For: 21y 4m 23d Location: gippsland Posted 22/12/04 09:45 AM Share Posted 22/12/04 09:45 AM Thanks mate for a well informed report with out all the crapThe traction control is my worry, the wife complains now about that, and mine is stockThanks Mal Link to comment Share on other sites More sharing options...
xrturb god bless my kids Member 611 Member For: 20y 10m 12d Gender: Male Location: claremont meadows, sydney Posted 22/12/04 09:48 AM Share Posted 22/12/04 09:48 AM I have had no probs with the traction control in the manuals Link to comment Share on other sites More sharing options...
rapt Donating Members 317 Member For: 21y 4m 23d Location: gippsland Posted 22/12/04 09:48 AM Share Posted 22/12/04 09:48 AM why dont we go to the chat ? Link to comment Share on other sites More sharing options...
xrturb god bless my kids Member 611 Member For: 20y 10m 12d Gender: Male Location: claremont meadows, sydney Posted 22/12/04 10:07 AM Share Posted 22/12/04 10:07 AM ok Link to comment Share on other sites More sharing options...
Street Tuner Member 727 Member For: 22y 2m 13d Posted 22/12/04 12:16 PM Share Posted 22/12/04 12:16 PM THE BAD1. The mid range pull (peak) from the 8 PSI tune goes away after a short drive (I think it's the tune learning the correct settings?? Although I liked it, I suspect this is actually 'Good')Correct this is good, its the system perfecting its closed loop boost control2. No change to bottom end pull. I'm not impressed about this, I was lead to believe it would be improved.The turbo can only 'spool' as fast as the compressor/turbine match will let it. The software is set to the 'instant ramp' timer in the program. It also runs much more boost at low throttle openings than a stock or piggybacked car.3. The gear changes are NOT firmer, IMO they are the same (excluding point 3 of THE GOOD of course)Commanded line pressure is at maximum for the force motor in your gearbox. The shifts might not feel any firmer because we stop the throttle from closing down the power on gearchange. If the throttle was allowed to shut (like stock) the shift would chirp the wheels.THE UGLY1. If traction control comes on at higher speeds a few times (say 60kms), it disables itself?? I'm not impressed about this at allThis is not a function of the PCM program, but rather your ABS system. It would seem you have a faulty wheel speed sensor, or have pushed the system outside of its external bounds....but isnt it good to lose traction over 60km/h?2. Power at a higher rev range on the 10 PSI tune drops off quickly (above about 5200 rpm) I've reverted back to the 8 PSI as it feels much better.It actually feels better at 8psi because the system doesn't ramp power down higher in the rev range to stop the injectors from 'maxxing out'. Its there to protect the engine, and it works. ie. you wont blow your engine or transmission with this software, which is more than can be said for a lot of other systems out there. ThanksMal<{POST_SNAPBACK}>No problem Link to comment Share on other sites More sharing options...
xrturb god bless my kids Member 611 Member For: 20y 10m 12d Gender: Male Location: claremont meadows, sydney Posted 22/12/04 12:32 PM Share Posted 22/12/04 12:32 PM well tomorrow I am trying the 8 psitub=ner what would be the power of the 8 psi map Link to comment Share on other sites More sharing options...
Street Tuner Member 727 Member For: 22y 2m 13d Posted 22/12/04 12:39 PM Share Posted 22/12/04 12:39 PM On a dead standard vehicle the 8psi map will provide the most linear power. Add an exhaust/cooler, and the 10psi map is the perfect partner. Link to comment Share on other sites More sharing options...
