Guest TRACK Guests Posted 14/12/04 11:55 AM Share Posted 14/12/04 11:55 AM Mine will hit the limiter anywhere between 5,800 & 6,200. It doesn't really seem to depend on conditions, as a romp through the gears will yield a different rev limiter value in 1st, 2nd & 3rd gear. Haven't hit the limiter in 4th....yet! (if it will, will they??) Really its a bit of a lottery, as to where the limiter will spoil the fun. Link to comment Share on other sites More sharing options...
Spool Member 28 Member For: 21y 4m 17d Posted 14/12/04 01:04 PM Share Posted 14/12/04 01:04 PM I mean...The motor died..No more going..I thought a six would rev harder.It felt like it could go to 6500 easy..<{POST_SNAPBACK}>Whats the use of reving it that hard when you will just go slower?You have cubes and turbo, not a rotary so you shouldnt be concerned about hgh revs especially when its past its peak at that stage. Link to comment Share on other sites More sharing options...
sixfan Flaccid Member Donating Members 2,503 Member For: 21y 8m 4d Gender: Male Location: NOONAMAH, go figure..... Posted 14/12/04 01:36 PM Share Posted 14/12/04 01:36 PM large rotating mass.......big stroke......6000 aint that bad.my 76 V12 daimler revs to 7000+tiny little pistons and tiny little strokelacks the torque of T down low though.Hmm...Never seen my T reach 6200.....Never wanted it to. Link to comment Share on other sites More sharing options...
Lawsy Wanabe mechanical engineer Donating Members 960 Member For: 20y 4m 8d Gender: Male Location: At the computer, obviously..... Posted 14/12/04 01:49 PM Share Posted 14/12/04 01:49 PM But with the right crank, rods and pistons, 7500 can be easily achieved with this engine. Just a matter of money and balance. Link to comment Share on other sites More sharing options...
ducatijb Lifetime Members 3,448 Member For: 21y 9m 22d Gender: Male Location: sydney Posted 14/12/04 07:20 PM Share Posted 14/12/04 07:20 PM 5800 revs for mine<{POST_SNAPBACK}>Yeah for how long... Link to comment Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 1m 1d Gender: Male Location: Sydney Posted 14/12/04 07:50 PM Share Posted 14/12/04 07:50 PM 5800 revs for mine<{POST_SNAPBACK}>Yeah for how long... <{POST_SNAPBACK}>7500 next week, with fpv instrument cluster that has 8000 rev limit tacho Link to comment Share on other sites More sharing options...
PASHEN Member 868 Member For: 21y 1m 30d Location: Need one.. Posted 14/12/04 10:49 PM Share Posted 14/12/04 10:49 PM Brian, just the thought of that gets me excited! What did you have to do to make sure the engine will handle it? Mind giving us an idea of $?Wish you were coming to the end of 2004 QLD cruise - I'd love to go for a ride. Link to comment Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 1m 1d Gender: Male Location: Sydney Posted 15/12/04 12:29 AM Share Posted 15/12/04 12:29 AM Brian, just the thought of that gets me excited! What did you have to do to make sure the engine will handle it? <{POST_SNAPBACK}>Nizpro rebuild the engines with rods/pistons suitable for high revs, and both my old and new engines are capable of higher revs. Motec controls the rev limit.Although the forthcoming Edit will allow the rev limit to be changed, you are highly likely to destroy the motor if you increase the rev limit without changing the rods.I've just had the reverse situation with my Sti, when going from 2L to 2.5L. Given that I've kept the stock Sti rods I've had to reduce the rev limit from 8000 revs to 7400 revs to protect the motor.I'm not sure of the $cost for rods alone, as all my work was packaged.After being used by high revving motors I've found the 5800 limit very hard to cope with. Remember that although the motor doesn't rev, it's design does produce good torque.Brian Link to comment Share on other sites More sharing options...
Turbo6man Lifetime Members 4,084 Member For: 22y 3m 15d Gender: Male Location: South Coast NSW Posted 15/12/04 01:01 AM Share Posted 15/12/04 01:01 AM Brian I think any rev limit in YOUR car is going to be hard to cope with - after this new motor goes in you won't be able to change gears quickly enough! ... Link to comment Share on other sites More sharing options...
Falchoon I see red Member 5,758 Member For: 22y 1m 9d Location: nowhere in particular Posted 15/12/04 01:07 AM Share Posted 15/12/04 01:07 AM Brian, just the thought of that gets me excited! What did you have to do to make sure the engine will handle it? <{POST_SNAPBACK}>I'm not sure of the $cost for rods alone, as all my work was packaged.<{POST_SNAPBACK}>Depending on what brand of rods are used about $4K is the figure I've heard. DucatiJB may be able to give you more info on brands. Then there are forged pistons to buy and h/d rod bolts. Wouldn't get much change from $10K I expect. Link to comment Share on other sites More sharing options...
