simmo Member 431 Member For: 22y 27d Gender: Male Location: byron bay more underarm hair per square km Posted 13/12/04 10:59 AM Share Posted 13/12/04 10:59 AM how many problems you had with your t Link to comment Share on other sites More sharing options...
xrturb god bless my kids Member 611 Member For: 20y 10m 11d Gender: Male Location: claremont meadows, sydney Posted 13/12/04 11:05 AM Share Posted 13/12/04 11:05 AM me 1)hand brake light staying on2)vibrating rear end3creaking in rear end 4)vct solinoid dirtty so they said 5)I think it went in to limp mode today for the first time .. had to stop and resart car engine light came on can someone explain limp mode and what causes it ps that list happened since I bought the car jun 04 Link to comment Share on other sites More sharing options...
TurboDewd FG Falcon fan! Member 1,452 Member For: 21y 8m 2d Gender: Male Location: Canberra Posted 13/12/04 11:32 AM Share Posted 13/12/04 11:32 AM Simmo, mate, youve had a shocker. Where is the option for ZERO problems old chap? You are forgiven. The only problems my car has are design flaws:1- power windows buttons not illuminated and (2) no footwell lighting! Link to comment Share on other sites More sharing options...
mickey_gee Member 593 Member For: 20y 4m 21d Gender: Male Location: Newcastle NSW Posted 13/12/04 12:15 PM Share Posted 13/12/04 12:15 PM My T has had2 replacement ICC's1 repaired tail shaft1 new tail shaft1 auto gearbox newthe boot liner stuck back inthe diff screws tightened so it stops leakingleft fog light replacedright low beam replacedthe rear view mirror tightenedwhen the fog light protectors were put on the ford mechanic forgot to screw the light in and I pushed it in when I was giving T a wash...... I was pissed!It took about 3 months to get all this fixed! all good now. I had to wait 28 days for ford to supply a replacemant ICC. no doof doof for a month...Im happy nowMG Link to comment Share on other sites More sharing options...
loaded Member 77 Member For: 21y 1m 3d Location: sydney Posted 13/12/04 12:18 PM Share Posted 13/12/04 12:18 PM It all started the day I picked her up from the dealer.Go to drive out and the rear end started to shutter badly.Told by service dept they will investigate further at 3000km complimentary inspection.To this day I wish I had not handed over the cheque that day.On the way home I go to open the sunroof and it doesn't work. I pull up at the lights and the breaks squealled badly.My problems are never ending and so are the bullsh*t excuses I get from Ford.List as follows: * Shuttering rear end, 2 diffs already replaced *Slipping clutch and hot spots on flywheel,Clutch replaced *Surgeing power, boost sensor changed twice *Replaced 2 throttle bodies already *oil leak from diff *Coolant leak from water pump *Oil consumption,2 litres used prior to 15k service *Clutch slipping again after 15k service(apprentice had some fun) *Break pads replaced on premium brakes, Still squealling *Centre console lid faulty,replaced *Rust on inside of door, Minor *Clunking noise coming from under rear end on light load cruising *Pipe from turbo fell off causing no power *power steering noise/vibration, changed hose but still makes noiseAll this from a car with 16k on the clock which cost me 57k. No I am not happy. Link to comment Share on other sites More sharing options...
TurboDewd FG Falcon fan! Member 1,452 Member For: 21y 8m 2d Gender: Male Location: Canberra Posted 13/12/04 12:40 PM Share Posted 13/12/04 12:40 PM loaded,Im sorry to hear your story. Dont worry, youre not alone, there are other lemons out there...and some which are worse.This is why we need Lemon Laws like in the US. If you ever bump into your state member of parliament offer your views on this matter.If ANY product fails to do what it is meant to do it should be replaced. Complex goods like cars are no different, if you fork out 50 grand and your car is off the road consistently for serious repairs then ya'll deserve a new vehicle or a refund. Link to comment Share on other sites More sharing options...
Flukey Seriously Flukey Member Donating Members 4,354 Member For: 20y 11m 15d Gender: Male Location: Melbourne Posted 13/12/04 12:42 PM Share Posted 13/12/04 12:42 PM It all started the day I picked her up from the dealer.Go to drive out and the rear end started to shutter badly.Told by service dept they will investigate further at 3000km complimentary inspection.To this day I wish I had not handed over the cheque that day.On the way home I go to open the sunroof and it doesn't work. I pull up at the lights and the breaks squealled badly.My problems are never ending and so are the bullsh*t excuses I get from Ford.List as follows: * Shuttering rear end, 2 diffs already replaced *Slipping clutch and hot spots on flywheel,Clutch replaced *Surgeing power, boost sensor changed twice *Replaced 2 throttle bodies already *oil leak from diff *Coolant leak from water pump *Oil consumption,2 litres used prior to 15k service *Clutch slipping again after 15k service(apprentice had some fun) *Break pads replaced on premium brakes, Still squealling *Centre console lid faulty,replaced *Rust on inside of door, Minor *Clunking noise coming from under rear end on light load cruising *Pipe from turbo fell off causing no power *power steering noise/vibration, changed hose but still makes noiseAll this from a car with 16k on the clock which cost me 57k. No I am not happy.I havent had any real problems. Creaky front end, a noise at the moment that sounds like rubbing, maybe pads,( u know, a Ch, Ch, Ch sound that speeds up as you increase speed ) and squeaking brakes. Is squeaky brakes warranty?? Link to comment Share on other sites More sharing options...
FPVPSI Member 503 Member For: 22y 20d Gender: Male Location: Victoria Posted 13/12/04 12:51 PM Share Posted 13/12/04 12:51 PM Bought it in July (I think) of 04, and so far have had a problem-less 7900km...the best car I've ever owned...just not to happy about the quality of a few things, that's about it... Link to comment Share on other sites More sharing options...
GlennAUII Former XT pilot Lifetime Members 4,791 Member For: 21y 7m 13d Gender: Male Location: The Womb Posted 13/12/04 01:17 PM Share Posted 13/12/04 01:17 PM oct 03 build sedan*‘shh shh’ noise coming from wheels (handbrake)*dented sun visor since brand new (looks like someones punched it hard)*audible diff whine at 85-110km/h*shunt when changing gears (auto)*exhaust heat shield rattle on idle*paint defect on drivers side rear lower door (splodge mark)*paint flaking off intercooler*Car stalls, and often at traffic lights or when coming to a stop *Car will idle very roughly and RPM drops like its going to stall*Drivers side rear window sill strip jerks out when window is rolled down, and makes shuddering noise*Steering wheel shudders excessively when turning at low speeds*rear passenger side window seal is of poor quality and creates wind noise*Front passenger seat has excessively worn causing the grey material to turn fuzzy (like the soft part of Velcro)*Front passenger side arm rest handle feels like it will fall off when you pull the door shut (very loose)*shuddering windscreen wipers*windscreen seal is dodgy and causes a lot of wind noise (loud whistling)*Clunk from rear when you plant it in 'D'There we go, that's 17 things wrong. Most of them are major though :DWe still love the car a lot Link to comment Share on other sites More sharing options...
Barry Blue Powered by Ford's 3.7 V6 = Zoom Zoom Zoom! Member 890 Member For: 20y 4m 5d Gender: Male Location: Tweed Heads Posted 14/12/04 06:27 AM Share Posted 14/12/04 06:27 AM How many K's on the clock? Link to comment Share on other sites More sharing options...
