Ace blind leading the blind Member 3,657 Member For: 16y 7m 19d Gender: Male Location: Mt Alford, Queensland Posted 09/03/10 12:21 PM Share Posted 09/03/10 12:21 PM Spiro - its just what I do Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/29/#findComment-989498 Share on other sites More sharing options...
Guest EGOXRT Guests Posted 09/03/10 12:29 PM Share Posted 09/03/10 12:29 PM Go the biggest tune Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/29/#findComment-989501 Share on other sites More sharing options...
Philbo84 Member 20 Member For: 16y 5m 13d Posted 07/06/10 01:29 AM Share Posted 07/06/10 01:29 AM Hey allI have just had an engine built for my ute and the engine builder who built it said you should never idle your engine for to long due to your doing damage that's why turbo timers are a bad idea, reason being if I understand it correctly, when your car idles everything is loose inside, the bearing etc which means they are not under load which reduces the life of your engine.......when I had the new engine put in I was told to drive it like I would drive any vehicle due to your running the engine in the way u drive it, none of this hold it at certain speeds or gears nonsense. So far car has been running sweet no dramas, and will hopfully this month have the finall tuning done with max boost etc (not tuned to max due to dyno braking). Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/29/#findComment-1013984 Share on other sites More sharing options...
Viper XR50T Member 61 Member For: 14y 6m 24d Posted 25/10/10 11:09 AM Share Posted 25/10/10 11:09 AM (edited) hi guysim set to pick up my 50th xr6 turbo this friday and wanted to know how to run in a new engine. ive never owned a new car so this will be my first run-inI've been reading around the net and most say to run it hard but I have a few questions like: oil change at what kms, semi synth?, brand of oil, etcand pretty much the dos and don'ts with a new xr6 turboI found this link on the net: Break In Secrets--How To Break In New Motorcycle and Car Engines For More Powerseems pretty good but I'd like to know first hand experiences, what brand oil you used, how hard to push it, how far to push it without overdoing it(whats the limit), etc. Edited 25/10/10 11:10 AM by Viper XR50T Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/29/#findComment-1050437 Share on other sites More sharing options...
GOLDIE My new toy Lifetime Members 5,344 Member For: 22y 8d Gender: Male Location: stanthorpe wine capital of qld. Posted 25/10/10 11:18 AM Share Posted 25/10/10 11:18 AM as these motors are run in the factory before fitment run is not that important just drive it normally just remeber to not labour the motor.If it is an auto that is not a probelm in a manuel just dont use a to high of gear.As for oil change I would do at 1500km first using agood brand of synthetic oil and new filter I use penrite.Change oil every 5000 ks also use 10w40 or 15w40 as with turbos anythinner is to thin when they get hot.Ian Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/29/#findComment-1050440 Share on other sites More sharing options...
fordboy1981 Donating Members 2,075 Member For: 22y 3m 12d Gender: Male Location: Sydney, NSW Posted 25/10/10 11:58 AM Share Posted 25/10/10 11:58 AM basically, make sure it's warm and then thrash the f*ck out of it, but just go easy on the RPM for the first couple 100 kms. I'd use cheap mineral oil for the first 1500km to bed the rings in properly, then the BEST quality synthetic you can get... Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/29/#findComment-1050455 Share on other sites More sharing options...
g6t Silver Donating Members 328 Member For: 15y 14d Gender: Male Location: sunshine state Posted 26/10/10 02:35 AM Share Posted 26/10/10 02:35 AM (edited) drove it hard from 60ks Edited 26/10/10 02:44 AM by g6et06 Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/29/#findComment-1050569 Share on other sites More sharing options...
unclewal Donating Members 583 Member For: 14y 7m 10d Posted 26/10/10 04:43 AM Share Posted 26/10/10 04:43 AM Keep it out of the red and off the limiter and dont labour it, but drive it like you stole it, always run all my vehicles in (road bikes dirt bikes and the likes from new and never had a drama) Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/29/#findComment-1050596 Share on other sites More sharing options...
Viper XR50T Member 61 Member For: 14y 6m 24d Posted 26/10/10 07:42 AM Share Posted 26/10/10 07:42 AM thanks guys, great responses goldie would you recommend a semi synth oil like HPR 10 (10w/50) or HPR 5 (5w/40) for the 1500K oil change?then switch to Sin 0 (0w/50) at 5000K oil change? Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/29/#findComment-1050648 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 10m 11d Gender: Male Location: Earth Posted 26/10/10 07:47 AM Share Posted 26/10/10 07:47 AM I wouldn't recommend a full synthetic or semi synthetic for at least the first 5000kms.And you should not even contemplate the SIN 0 oil. Stick with the SIN 15 and you shouldn't have a drama. Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/29/#findComment-1050651 Share on other sites More sharing options...
