Wenier Donating Members 1,736 Member For: 15y 3m 12d Gender: Male Location: Christchurch, New Zealand Posted 09/03/10 04:06 AM Share Posted 09/03/10 04:06 AM I wouldnt give it long durations of idle when running in. Also 10w40 should be low enough 5 is getting a bit low IMO. I agree with loading it up obviously just for a little bit not the whole time and then just keeping varying ya revs and don't labour the engine by being in too higher gear for the speeds.Also as said ditch the old fuel no harm in doing the filter, may or may not need it who knows.As for using a K&N oil filter, I haven't used them didn't know they made them. So are they expensive? A simple Ryco one would do the same job really. Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/28/#findComment-989312 Share on other sites More sharing options...
Guest EGOXRT Guests Posted 09/03/10 05:23 AM Share Posted 09/03/10 05:23 AM If you idle it too long you will glaze the bores and screw the whole process. You need to get as much pressure as possible behind the rings to get them bedded ASAP. This doesn't mean huge revs, just load it up through the gears and keep an eye on the temp. Don't be afraid to get the revs up in the last 5 mins just don't sustain for too long. You will have a nicely bedded in motor as long as the clearances are spot good...lol Don't be tight and drain the oil and turf the filter as soon as you have done the above. Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/28/#findComment-989333 Share on other sites More sharing options...
Guest XR09 Guests Posted 09/03/10 05:46 AM Share Posted 09/03/10 05:46 AM If you idle it too long you will glaze the bores and screw the whole process. Sorry I should have highlighted the "run at temp bit". Or worded it better. But I have no idea what normal running temp is on a tuned 6 is. And it's a new motor so you will want to look at it running for a while. How many more sleeps Matt. And while your there, check all the fluid points, including welsh plugs and pumps. Fitting ends. Sorry if I am stating the bleading obvious. On my bikes the fans cut in around 107c. And I usually wait till 91c before I ride them. Running temps usually around 97c. Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/28/#findComment-989340 Share on other sites More sharing options...
mattyb Donating Members 1,097 Member For: 16y 10m 16d Gender: Male Location: Gold Coast, QLD Posted 09/03/10 09:33 AM Share Posted 09/03/10 09:33 AM (edited) Cheers for the advice guys. So...Drain the fuel. Add new fuel.Start her up, let her idle for a minute.Reverse out the driveway.Drive normal for the first Minutre or 500m till I get out of my little street, and then load her up, maybe 3/4 throtte up and down through the rev range (ZF 6 speed).Drive it at 3/4 throttle up and down through the rev range for 20 minutes, and then bring her home and drain the oil and change the filter.How do I drain the fuel? I'm gonna need a 50L drum cos she blew with a full tank. lol. Good for mower fuel.Also, my tunes areValet - up to 3000rpm330rwkw - 95 octane tune wife power delivery360rwkw - 98 Octane agressive power tuneWhich tune? Edited 09/03/10 09:41 AM by mattyb Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/28/#findComment-989406 Share on other sites More sharing options...
typhoon_freak Cryptic Clothing Company Donating Members 4,556 Member For: 16y 9m 20d Gender: Male Location: Brisvages, Capalaba Posted 09/03/10 09:50 AM Share Posted 09/03/10 09:50 AM I get my car bak nxt week to run in my engine, and they told me to take it to a hilly area, put the engine on a bit of load. and not to really rev past 4000rpm. that's what iv been told Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/28/#findComment-989411 Share on other sites More sharing options...
mattyb Donating Members 1,097 Member For: 16y 10m 16d Gender: Male Location: Gold Coast, QLD Posted 09/03/10 09:54 AM Share Posted 09/03/10 09:54 AM Would love to do that, but unfortunately there a ZERO hilly areas around here lol. Funnily enough I live in the Central Highlands... Go Figure. Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/28/#findComment-989412 Share on other sites More sharing options...
SPIKO Gold Donating Members 1,924 Member For: 20y 23d Gender: Male Posted 09/03/10 11:49 AM Share Posted 09/03/10 11:49 AM On 09/03/2010 at 3:43 AM, XR09 said: Seriously only twenty minutes ? I'm not arguing. I'm asking. I don't really know.Just thought about 500km would be around the mark. Just put a little stress on the motor, not much but vary the load on the bottom end and revs on the top. And let it idle for like twenty minutes before driving anywhere after a rebuild, or as long as it runs at temp. That's how I run my bikes in.If I did it at 25km which is all it would haveat best after twenty minutes, I would feel that I should do the next dump at 500km. Then every 6000 or 6 months.But Matt hey, I am no expert on it. I really am asking.20minute's FIRM........... Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/28/#findComment-989481 Share on other sites More sharing options...
SPIKO Gold Donating Members 1,924 Member For: 20y 23d Gender: Male Posted 09/03/10 11:50 AM Share Posted 09/03/10 11:50 AM (edited) On 09/03/2010 at 9:50 AM, typhoon_freak said: I get my car bak nxt week to run in my engine, and they told me to take it to a hilly area, put the engine on a bit of load. and not to really rev past 4000rpm. that's what iv been toldUrban Legend.... Not True......I intend to document, video & share this with you guy's very soon.....next couple of day's Edited 09/03/10 11:52 AM by SPIKO Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/28/#findComment-989482 Share on other sites More sharing options...
Ace blind leading the blind Member 3,657 Member For: 16y 7m 19d Gender: Male Location: Mt Alford, Queensland Posted 09/03/10 11:52 AM Share Posted 09/03/10 11:52 AM XR09 if you spiro says 20mins id believe him - he is good at destroying diffs I mean running engines in Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/28/#findComment-989483 Share on other sites More sharing options...
SPIKO Gold Donating Members 1,924 Member For: 20y 23d Gender: Male Posted 09/03/10 11:53 AM Share Posted 09/03/10 11:53 AM LMAO Mat you weapon you Link to comment https://www.fordxr6turbo.com/forum/topic/14404-running-in/page/28/#findComment-989485 Share on other sites More sharing options...
