Geeseman Donating Members 1,805 Member For: 21y 3m 27d Location: Sydney Posted 23/11/04 10:24 PM Share Posted 23/11/04 10:24 PM Here they are from the december issue of wheelsTyphoon0-100kph 6.3 sec0-400m 14.6@162kphGT0-100kph 6.1 sec0-400m 14.2@166kphHSV Clubsport0-100kph 6.0 sec0-400m 14.2@169kph Link to comment Share on other sites More sharing options...
vuster Member 112 Member For: 20y 3m 20d Location: Melbourne Posted 23/11/04 10:35 PM Share Posted 23/11/04 10:35 PM That is very disapointing. They look like quite conservative times though. HSV 6 seconds? Factory released times are like 5.1. Link to comment Share on other sites More sharing options...
jordak Member 1,226 Member For: 20y 8m 13d Posted 23/11/04 10:42 PM Share Posted 23/11/04 10:42 PM . ......up a snow covered mountain into 150 knot headwind with MR Bean behind the wheel Link to comment Share on other sites More sharing options...
vuster Member 112 Member For: 20y 3m 20d Location: Melbourne Posted 23/11/04 10:46 PM Share Posted 23/11/04 10:46 PM This came from wheels mag which should explain the slow times:As a track surface 'rubbers up' (becomes impregnated with tyre rubber) it usually brings more grip, but not during our visit to Calder Park, VIC. Thick rubber from a recent drag meet killed any meaningful standing-start attempts, and our times reflect this. Getting grip of the line was impossible, and all cars turned their 'best' times with low-rev, zero wheelspin launches. However, look closely at the 80-100km/h times, where it's all about engine performance and gearing. The F6 Typhoon's weight and torque advantage combine with tighter gearing to smoke the V8's. It's decisively quicker in every gear we tested. And with good traction underneath, the Typhoon should also embarrass the V8's off the line. Link to comment Share on other sites More sharing options...
Mr X Donating Members 998 Member For: 21y 6m 30d Gender: Male Location: Adelaide Hills Posted 23/11/04 11:12 PM Share Posted 23/11/04 11:12 PM This came from wheels mag which should explain the slow times:As a track surface 'rubbers up' (becomes impregnated with tyre rubber) it usually brings more grip, but not during our visit to Calder Park, VIC. Thick rubber from a recent drag meet killed any meaningful standing-start attempts, and our times reflect this. Getting grip of the line was impossible, and all cars turned their 'best' times with low-rev, zero wheelspin launches. However, look closely at the 80-100km/h times, where it's all about engine performance and gearing. The F6 Typhoon's weight and torque advantage combine with tighter gearing to smoke the V8's. It's decisively quicker in every gear we tested. And with good traction underneath, the Typhoon should also embarrass the V8's off the line.Sounds like high 13's then. Link to comment Share on other sites More sharing options...
Geeseman Donating Members 1,805 Member For: 21y 3m 27d Location: Sydney Posted 24/11/04 12:11 AM Author Share Posted 24/11/04 12:11 AM That box out sounds like an excuse for their drivers for not posting better times. Regardless, it shows the trend that the phoon is slower than the GT and the HSV, which is mirrored in the times seen in motor mag.How they can say it's faster in each gear and off the mark when they say in the article the phoon has lag and the v8's throttle response is better is absurd.Even their own times contradict their statements. Link to comment Share on other sites More sharing options...
Turbo6man Lifetime Members 4,084 Member For: 22y 4m 13d Gender: Male Location: South Coast NSW Posted 24/11/04 12:21 AM Share Posted 24/11/04 12:21 AM . ......up a snow covered mountain into 150 knot headwind with MR Bean behind the wheel <{POST_SNAPBACK}> :w00t2: Link to comment Share on other sites More sharing options...
Turbo6man Lifetime Members 4,084 Member For: 22y 4m 13d Gender: Male Location: South Coast NSW Posted 24/11/04 12:27 AM Share Posted 24/11/04 12:27 AM That box out sounds like an excuse for their drivers for not posting better times. Regardless, it shows the trend that the phoon is slower than the GT and the HSV, which is mirrored in the times seen in motor mag.How they can say it's faster in each gear and off the mark when they say in the article the phoon has lag and the v8's throttle response is better is absurd.Even their own times contradict their statements. <{POST_SNAPBACK}>They write dribble ... However, the turbo can have less throttle response, or call it lag if you like, than the V8s and still whip their butts from a rolling start through each gear. Simply because it has more torque at lower revs. The T6 does this now doesn't it? Why wouldn't the Typhoon? Link to comment Share on other sites More sharing options...
Geeseman Donating Members 1,805 Member For: 21y 3m 27d Location: Sydney Posted 24/11/04 12:49 AM Author Share Posted 24/11/04 12:49 AM The T6 does this now doesn't it? Why wouldn't the Typhoon?Not according to their times. Phoon GT0-60 3.4s 3.1s0-80 4.8s 4.6s0-100 6.3s 6.1s0-120 8.6s 8.1s0-140 11.0s 10.4s0-160 14.1s 13.1s0-180 17.7s 16.2s 1776kgs 1825kgsSomething is a miss here. Perhaps the phoon does hit 9lb early on but it must be drawn back to stock levels above 4500rpm or something for the GT to pull away so hard. Link to comment Share on other sites More sharing options...
Turbo6man Lifetime Members 4,084 Member For: 22y 4m 13d Gender: Male Location: South Coast NSW Posted 24/11/04 01:03 AM Share Posted 24/11/04 01:03 AM Link to comment Share on other sites More sharing options...
