My Computer
XRSICKT
  • Member For: 21y 9m 9d
If you are given a laptop to eveluate and write a review on, is the warranty voided if you open the underneath to have a look at the build then replace it?
Everything is in working condition but I would have thought if you are given something to evaluate to help you decide wether or not you are going to purchase 40 of these things and on top of that are asked by the supplier to write a review on it the warranty is not voided, it isn't voided anyway is it? what is you need to upgrade the RAM for example?
  • Replies 152
Guest FatBAt
  • Guests
I think the supplier would have rocks in his head to not cover it for warrantee given that you may buy 40 of these units.
You have been asked by the supplier to review it. Define the word review! It no way suggests that you cannot open the case. You are reviewing the unit....inside and out. This will obviously only be the case if you are reviewing hardware and not software. If it is software, you have no need to open the unit.
Some units have a sticker "void if removed or torn" over the top and bottom of the unit. If it did, it's a different story if you didn't ask the question before you removed it. If it didn't, then there is no legal problem.
Cheers
that's what I though, we told a supplier about a project we are working on, they offered a laptop as a possible solution to evaluate for some time as long as we would write a review which is when this thing came to me. I removed some screws to allow me to open the undercasing to have a look inside to alow me to complete the review for them, I handed it in and we have now been charged for the laptop because warranty had been voided by my actions.
I'll have a look to see if the unit has any stickers as you mentioned but I think I would have paused if I noticed any. Thanks..
Guest FatBAt
  • Guests
Can I ask what supplier this is. Why I ask is because like you said, if you want to install new ram, who is to do it. Obviously they can't because it voids the warrantee from their suppliers. It seems a little fishy to me. It seems he has taken your possibility of buying 40 units with a grain of salt. He wants a quick easy sale of one unit.
I certainly wouldn't be paying for it. Hands Down! Ask him where does it state that you cannot open the case. Warantees in Australia cannot be made on assumptions. It has to state categorically what it covers and more importantly what it doesn't.
Even a warrantee that says an item is not covered if misused....has to define what is regarded as misuse. A warantee might read something like this...
Misuse: The item will not be covered under this warrantee if it is found to be used for something other than its' intended use or has been misused.
This means absolutely nothing
If it contained
Misuse is (but not limited to) being dropped, overheated,......
This is explaining clearly what it doesn't cover.
The term but not limited to is the be all to end all. It is their saviour. If the customer doesn't ask the shop proprietor what that means, then you are leaving a big gap in your legal rights.
My son had a car amp fitted to his car and one of his speakers blew up. The guy in the shop said it wasn't covered because he turned it up too loud. I said show me in the warantee where it says that. He pointed to misuse and I said where does it say not to turn it up too loud....Long story short....the speaker was replaced....twice.
Stick by your guns and don't take sh!t.
Cheers
  • Member For: 17y 8m 12d
Ok, slightly more technical one for you guys....
2003 Server distributing DHCP to clients. A new default gateway is introduced to the DHCP settings (scope options not server options). The old default gateway is pushed down to be the secondary gateway.
All clients receive the settings but after five minutes, checking via ipconfig reveals that the clients have lost the setting of the new default gateway, and have reverted back to the old default gateway (now the secondary). Rebooting just replicates the problem, while a release/renew just starts the cycle again. Setting there, then not there.
There is only one DHCP server in the network.
Any ideas?
Background info... the office is in an area where adsl is not available, so we have satellite. This is very expensive. We are trialling unwired but because the signal is not that strong (reliable) we need all VPN traffic to run through the satellite, while all other traffic runs out of the unwired - hence the new default gateway.
Any thoughts?
Grant
Have to try to nail it down to local clients or the DHCP server. Also what OS is on the clients?
Do the computers function normally on the new gateway IP, or do they revert as soon as u try to access the internet?
If they do function normally on the new gateway IP I would make a trial one and install only the new gateway IP and see how long that machine functions for.
let me know how it goes and I'll see what I can think of then.. a lot of these issues require trial and error to resolve and is extremely hard via relayed msg's :D
Try:
ipconfig /all
It will tell you the IP address of the DHCP that you received your IP address from.
How are you doing two "default" gateways? Obviously two defaults are impossible for the computer to understand. Are you defining routes for different Internet addresses via each gateway using the route commands?
Can you main gateway router handle the re-direct for your clients? What I mean is, have one router as the gateway for all clients and have it know which way to route the traffic.??
Cheers,
Azz
Its not 2 default gateways, its a primary and secondary as always and he is using windows server 2003 as a DHCP server not a router. And yes I know the data is being routed anyway but I don't think routing is an issue here.
:D
  • 2 weeks later...
Thought I would try out this media player I heard lots of good things about, I downloaded the free sersion of BSPlayer but it come bundled with WhenU Save adware program that send out span through your SMTP account an brinf up add while browsing the web all the time, I uninstallled BSPlayer but it didn;t get rid of WhenU Save.
Web searches points to files and registry key I need to get rid of, ran a couple of crapware removal tools.. STILL THERE!
Any suggestions?
  • Mmmmm......BOOST
  • Member For: 17y 8m 27d
I had some crap on mine last week I couldnt get rid of so I did a system restore back to the day befor it turned up and that got rid of it
Good though, I went and tried it and nope. damn it..
  • Mmmmm......BOOST
try downlaoding every trail program you can get from avg grisoft
windows live one care program is good at finding this crap too
Edited by our06t
