Silverbullet Member 100 Member For: 21y 8m 29d Location: Brisbane Posted 14/11/04 08:08 AM Share Posted 14/11/04 08:08 AM XR6_ED said: factory gap is not that crash hot .. when I pulled mine out the gap was all over the place..gapped to .7 mm/27 thou made the engine feel down on horses...gapped to 32 thou / .81 mm and horses back and better response under 2500 rpmIt's Amazing how 5 thou can make an engine difference <{POST_SNAPBACK}>What would be the best Plug Gap for the BA XR6 N/A??? Would it be the same as the "T"???Cheers. Link to comment https://www.fordxr6turbo.com/forum/topic/13955-plug-gap/page/2/#findComment-187046 Share on other sites More sharing options...
XR6_ED Member 1,517 Member For: 22y 2m 6d Posted 14/11/04 08:16 AM Share Posted 14/11/04 08:16 AM If you are keen drop your gap by .1 of a mill and take her for a run..Then drop it another .1 and see if there is a differenceI think is is 1.1mm from factory ... But you will probably find that your sparks are not the correct gapping in the first place... Link to comment https://www.fordxr6turbo.com/forum/topic/13955-plug-gap/page/2/#findComment-187048 Share on other sites More sharing options...
Silverbullet Member 100 Member For: 21y 8m 29d Location: Brisbane Posted 14/11/04 08:29 AM Share Posted 14/11/04 08:29 AM XR6_ED said: If you are keen drop your gap by .1 of a mill and take her for a run..Then drop it another .1 and see if there is a differenceI think is is 1.1mm from factory ... But you will probably find that your sparks are not the correct gapping in the first place...<{POST_SNAPBACK}>Thanks, I've bought some performance plugs and want to get it right the first time. If I went to the 0.9mm gap straight away I wonder if that would cause any problems??Cheers. Link to comment https://www.fordxr6turbo.com/forum/topic/13955-plug-gap/page/2/#findComment-187060 Share on other sites More sharing options...
XR6_ED Member 1,517 Member For: 22y 2m 6d Posted 14/11/04 08:36 AM Share Posted 14/11/04 08:36 AM My Modded ED XR6 run NGK's at 36 thou (just over.9mm) no dramas... Link to comment https://www.fordxr6turbo.com/forum/topic/13955-plug-gap/page/2/#findComment-187066 Share on other sites More sharing options...
Silverbullet Member 100 Member For: 21y 8m 29d Location: Brisbane Posted 14/11/04 08:40 AM Share Posted 14/11/04 08:40 AM XR6_ED said: My Modded ED XR6 run NGK's at 36 thou (just over.9mm) no dramas...<{POST_SNAPBACK}>I just measured the stock plug gap...1.321mm. Does this change things!! Link to comment https://www.fordxr6turbo.com/forum/topic/13955-plug-gap/page/2/#findComment-187072 Share on other sites More sharing options...
Guest Guests Posted 14/11/04 08:50 AM Share Posted 14/11/04 08:50 AM Silverbullet said: XR6_ED said: My Modded ED XR6 run NGK's at 36 thou (just over.9mm) no dramas...<{POST_SNAPBACK}>I just measured the stock plug gap...1.321mm. Does this change things!!<{POST_SNAPBACK}>not realy the gap for example on a dunnydoor is 1.5 this is for better spark the only reason you should go lower than the 1.1 is if you had higher comp or more boost std plugs are iridium and shouldnt require replacement for at least 50,000 ks and some manufactures recomend 100,000 ks Link to comment https://www.fordxr6turbo.com/forum/topic/13955-plug-gap/page/2/#findComment-187079 Share on other sites More sharing options...
Silverbullet Member 100 Member For: 21y 8m 29d Location: Brisbane Posted 14/11/04 08:59 AM Share Posted 14/11/04 08:59 AM Dynowog said: not realy the gap for example on a dunnydoor is 1.5 this is for better spark the only reason you should go lower than the 1.1 is if you had higher comp or more boost std plugs are iridium and shouldnt require replacement for at least 50,000 ks and some manufactures recomend 100,000 ks<{POST_SNAPBACK}>Dynowog,I've done some fairly significant mods to the N/A but no internals at this stage. My Km's are starting to get up there and the car gets driven fairly hard (redline nearly everyday), have I wasted my money on Spitfire platium twin sparks for my N/A??Thanks in advance. Link to comment https://www.fordxr6turbo.com/forum/topic/13955-plug-gap/page/2/#findComment-187084 Share on other sites More sharing options...
