Flukey Seriously Flukey Member Donating Members 4,354 Member For: 20y 11m 3d Gender: Male Location: Melbourne Posted 09/11/04 11:35 AM Share Posted 09/11/04 11:35 AM Vik, Im with you mate. I know just what you mean because it happens to me all the time. My solution.........I close my sunroof Link to comment Share on other sites More sharing options...
Cashie Donating Members 663 Member For: 22y 29d Gender: Male Location: Perth Posted 09/11/04 09:06 PM Share Posted 09/11/04 09:06 PM Yeah, I've experienced both the speedo glare and the bonnet bulge glare.The speedo glare seems to be linked to my sunglasses, whilst wearing them at a certain time of the day, the dassh is hard to see (especially the digital readouts on the odometer and trip computer), if I remove them I can see them........ strange!The bonnet bulge glare I can live with! Link to comment Share on other sites More sharing options...
Guest Guests Posted 09/11/04 09:42 PM Share Posted 09/11/04 09:42 PM Try draining the indicator fluid out, as that will raise the front of the car a little so you wont have to worry about the glare till about 1 o'clock . Ken<{POST_SNAPBACK}>Been there done that!!! I tried it with trans fluid in the radiator.I figured if I got all the trans fluid up the front of the car,the nose would dip and Id be laughing.Dont try this folkes, cause you end up crying vik of the overboost Link to comment Share on other sites More sharing options...
Ford_Power Member 798 Member For: 21y 10m 24d Posted 10/11/04 07:49 AM Share Posted 10/11/04 07:49 AM (edited) XR8 Ute Posted Today, 07:06 AM Yeah, I've experienced both the speedo glare and the bonnet bulge glare.The speedo glare seems to be linked to my sunglasses, whilst wearing them at a certain time of the day, the dassh is hard to see (especially the digital readouts on the odometer and trip computer), if I remove them I can see them........ strange!The bonnet bulge glare I can live with!The reason this happens is because the LCD display from which your odometer is made from is horizontally polarised. Horizontal polarisation blocks the majority of light that reflected in the horizontal plane - this is to reduce glare (horizontal light). Your glasses will be polarised too - for the same reason - to reduce glare. The problem here is that your glasses and the dash combined are filtering out both the horizontal and vertical component of the light.... thus the text seems to disappear! (In theory this shouldnt happen as both the LCD and your glasses should be horizontally polarised, but if your glasses are cheap then the polarisation may not be dead level horizontal and thus its causing the problem - no offence intended) You will probably find that if you rotate your glasses slowly between 0-90 degrees and look through them you will be able to read the odometer clearly.Ross Edited 10/11/04 07:55 AM by Ford_Power Link to comment Share on other sites More sharing options...
Blown BA In Your Face Member 6,195 Member For: 21y 11m 15d Gender: Male Location: Peninsula Posted 10/11/04 08:53 AM Share Posted 10/11/04 08:53 AM XR8 Ute Posted Today, 07:06 AM Yeah, I've experienced both the speedo glare and the bonnet bulge glare.The speedo glare seems to be linked to my sunglasses, whilst wearing them at a certain time of the day, the dassh is hard to see (especially the digital readouts on the odometer and trip computer), if I remove them I can see them........ strange!The bonnet bulge glare I can live with!The reason this happens is because the LCD display from which your odometer is made from is horizontally polarised. Horizontal polarisation blocks the majority of light that reflected in the horizontal plane - this is to reduce glare (horizontal light). Your glasses will be polarised too - for the same reason - to reduce glare. The problem here is that your glasses and the dash combined are filtering out both the horizontal and vertical component of the light.... thus the text seems to disappear! (In theory this shouldnt happen as both the LCD and your glasses should be horizontally polarised, but if your glasses are cheap then the polarisation may not be dead level horizontal and thus its causing the problem - no offence intended) You will probably find that if you rotate your glasses slowly between 0-90 degrees and look through them you will be able to read the odometer clearly.Ross<{POST_SNAPBACK}>So there you go Vik....you weren't illusinating after all :lol: Link to comment Share on other sites More sharing options...
Miyagi fordxr5turbodotcom Member 892 Member For: 21y 4m 14d Gender: Male Location: Point Cook, Vic Posted 10/11/04 09:21 AM Share Posted 10/11/04 09:21 AM sometimes when driving.. I find it impossible to read the tacho completely!... then I realise it's night time and turn my headlights on Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 9m 30d Gender: Male Location: Brisbane Posted 10/11/04 10:03 AM Share Posted 10/11/04 10:03 AM XR8 Ute Posted Today, 07:06 AM Yeah, I've experienced both the speedo glare and the bonnet bulge glare.The speedo glare seems to be linked to my sunglasses, whilst wearing them at a certain time of the day, the dassh is hard to see (especially the digital readouts on the odometer and trip computer), if I remove them I can see them........ strange!The bonnet bulge glare I can live with!The reason this happens is because the LCD display from which your odometer is made from is horizontally polarised. Horizontal polarisation blocks the majority of light that reflected in the horizontal plane - this is to reduce glare (horizontal light). Your glasses will be polarised too - for the same reason - to reduce glare. The problem here is that your glasses and the dash combined are filtering out both the horizontal and vertical component of the light.... thus the text seems to disappear! (In theory this shouldnt happen as both the LCD and your glasses should be horizontally polarised, but if your glasses are cheap then the polarisation may not be dead level horizontal and thus its causing the problem - no offence intended) You will probably find that if you rotate your glasses slowly between 0-90 degrees and look through them you will be able to read the odometer clearly.Ross<{POST_SNAPBACK}>[commence serious post]All jokes aside, this place is absolutely unreal. I don’t think that a day has passed that I haven’t learnt anything from this forum.Keep up the great work with these little gems of information, although they will probably not impact on anything greatly or change the world significantly, it is very interesting to hear nonetheless.Trent.[/return to meaningless dribble] Link to comment Share on other sites More sharing options...
Guest Guests Posted 10/11/04 10:54 AM Share Posted 10/11/04 10:54 AM XR8 Ute Posted Today, 07:06 AM Yeah, I've experienced both the speedo glare and the bonnet bulge glare.The speedo glare seems to be linked to my sunglasses, whilst wearing them at a certain time of the day, the dassh is hard to see (especially the digital readouts on the odometer and trip computer), if I remove them I can see them........ strange!The bonnet bulge glare I can live with!The reason this happens is because the LCD display from which your odometer is made from is horizontally polarised. Horizontal polarisation blocks the majority of light that reflected in the horizontal plane - this is to reduce glare (horizontal light). Your glasses will be polarised too - for the same reason - to reduce glare. The problem here is that your glasses and the dash combined are filtering out both the horizontal and vertical component of the light.... thus the text seems to disappear! (In theory this shouldnt happen as both the LCD and your glasses should be horizontally polarised, but if your glasses are cheap then the polarisation may not be dead level horizontal and thus its causing the problem - no offence intended) You will probably find that if you rotate your glasses slowly between 0-90 degrees and look through them you will be able to read the odometer clearly.Ross<{POST_SNAPBACK}>I know what your saying,but driving the overbooster at the time I wasnt wearing goggles,Ive actually got a pair of polaroides when I drive the XY,hooly dooly,,,like having polker dots all over the joint,and as you say,rotate 0-90 and it goes away.When polaroids first came out,that was the first thing you did to make sure you were cool check em on a wind screen!vik of the overboost Link to comment Share on other sites More sharing options...
Cro Flower Power Lifetime Members 6,114 Member For: 22y 4m 14d Gender: Male Location: Sydney Posted 10/11/04 12:18 PM Share Posted 10/11/04 12:18 PM Vik, as sixfan mentioned try the polorized sunnies, they do the trick for me. Link to comment Share on other sites More sharing options...
Cashie Donating Members 663 Member For: 22y 29d Gender: Male Location: Perth Posted 10/11/04 09:20 PM Share Posted 10/11/04 09:20 PM XR8 Ute Posted Today, 07:06 AM Yeah, I've experienced both the speedo glare and the bonnet bulge glare.The speedo glare seems to be linked to my sunglasses, whilst wearing them at a certain time of the day, the dassh is hard to see (especially the digital readouts on the odometer and trip computer), if I remove them I can see them........ strange!The bonnet bulge glare I can live with!The reason this happens is because the LCD display from which your odometer is made from is horizontally polarised. Horizontal polarisation blocks the majority of light that reflected in the horizontal plane - this is to reduce glare (horizontal light). Your glasses will be polarised too - for the same reason - to reduce glare. The problem here is that your glasses and the dash combined are filtering out both the horizontal and vertical component of the light.... thus the text seems to disappear! (In theory this shouldnt happen as both the LCD and your glasses should be horizontally polarised, but if your glasses are cheap then the polarisation may not be dead level horizontal and thus its causing the problem - no offence intended) You will probably find that if you rotate your glasses slowly between 0-90 degrees and look through them you will be able to read the odometer clearly.RossRoss, thanks for the explaination, bloody Bolle sunglasses, might have to pick up a set of $10 sunnies from Clints. Link to comment Share on other sites More sharing options...
