My T busted a radiator
FPRXR-6
  • 3 months later...
Guest Mo2003turbo
  • Guests
....my T radiator core just started leaking for no apparent reason...it was replaced under warranty ....but I got the impression it was NOT an uncommon problem. I just noticed a few drops on the garage floor (each morning after it had cooled o'nite)....
Mo
  • Weird Member
  • Member For: 21y 10m 19d
Mine too.............. they noticed when replacing my front rotors and pads, and adjusting my handbrake under warranty the other day. :ermm:
Could be worse I guess, I could have to take it back to a Expensive Daewoo or Mitsubishi dealer.
"No we didn't find anything wrong with your car sir, all noises, leaks and lubricant consumption rates are within factory tollerance, perhaps you should consider carrying a few drums of oil and water with you" :ermm:
  • Member For: 19y 9m 27d
Mine got replaced in the 60k service (under warranty) as it had slight a crack in it... they didn't even mention anything until I took a look at the service report and noticed it there - replaced no questions asked!!
:blush:
They also told me that mine was at the upper end of power for the stock T's they see come through - apparently there are some quite significant variations in performance between stock T's...
Made my day anyway!!
  • Member For: 21y 2m 13d
How would they know that your car is at the upper end in performance. They dont use dynos. Maybe they were able to smoke the wheels up and with the previous car they couldnt. :blush:
