FPV 521 FPV521 Member 989 Member For: 20y 5m 16d Gender: Male Posted 27/10/04 08:25 AM Share Posted 27/10/04 08:25 AM Hi, The XR is the first Turbo car I have had and I just wonder weather you guys can give me any tips as far as looking after the bolted on snail. I have had people tell me I should let it idle for a time after a work out as it is good for the turbo, also heard that the wrong oil in the engine can bugger the turbo.Also what are the main reasons why a turbo will blow up and have any of you guys done that. I was told the turbo was very good quality and that I shouldnt have any problems with it down the track but you know what salesmen are likeCan you guys help out please. Gavin Link to comment Share on other sites More sharing options...
Guest richard_mmmm Guests Posted 27/10/04 08:34 AM Share Posted 27/10/04 08:34 AM Although I don't own a XR6T (yet), all my cars have been turbo's, and the first thing I buy after getting the car is a turbo timer. They are invaluble no waiting around in the car after a spirited run waiting for it to cool down, and they (if you get a decent one) automatically calculate how long to run the car for dependant on your driving style.with regards to oil if you are getting it serviced at a dealership you would expect them to be putting the correct oil in. I always use premium fully synthetic on my cars ( I have found motul 8000 to be the best). The main thing with turbo's is to change the oil regually most turbo cars recomend 5000k's (not sure with the XR) as the oil doesn't last as long due to the heat incurred in cooling the turbo down.I would assume the owners manual would have the type of oil recomended by ford, listed in it somewhere.GLrichard Link to comment Share on other sites More sharing options...
thebrunks Member 665 Member For: 20y 7m 11d Location: Gold Coast Posted 27/10/04 08:51 AM Share Posted 27/10/04 08:51 AM Unless you've been giving the car a flogging & need to pull up just after, there is no need to idle down these turbos!They're Roller Bearing, oil fed, water cooled turbos, and really there isn't much that can go wrong!The main culprit for stuffing turbos is old oil, obviously ford have done their research & know the life of the oil in day to day driving!In saying that if you have powered up your vehicle, you should change the oil more often, (between 5-10,000 k's) as you now produce more heat which will effect the oil!Russ Link to comment Share on other sites More sharing options...
mattpwc Member 51 Member For: 20y 8m 16d Location: New Zealand Posted 27/10/04 09:05 AM Share Posted 27/10/04 09:05 AM hey mate... there are heaps of really detailed threads on this subject... no need for turbo timer as the turbo is feed oil after switch off by some flash hot vs cold water system that goes beyond my understanding but that's what these guys said and I for one trust the knowledge on this site more than a ford mechanic... but it is advisable to let it idle for a min if you have flogged it just before you get home , after a few laps of phillip isld or a drag run... Link to comment Share on other sites More sharing options...
exar Member 187 Member For: 20y 11m 9d Posted 27/10/04 09:09 AM Share Posted 27/10/04 09:09 AM oil fed, water cooled turbos,Forgive a newbie question, but could you explain a little what that means. I have been told about oil under pressure supplying turbo bearings, but how is the water used? Is there a water jacket that is used to remove heat from the bearings or something? Link to comment Share on other sites More sharing options...
Guest Guests Posted 27/10/04 09:15 AM Share Posted 27/10/04 09:15 AM Although I don't own a XR6T (yet), all my cars have been turbo's, and the first thing I buy after getting the car is a turbo timer. They are invaluble no waiting around in the car after a spirited run waiting for it to cool down, and they (if you get a decent one) automatically calculate how long to run the car for dependant on your driving style.GLrichardgood advice although I use german OWS oils not as cheap as motul though OWS comes in at $25 per litre awsome stuff Link to comment Share on other sites More sharing options...
Guest Guests Posted 27/10/04 09:18 AM Share Posted 27/10/04 09:18 AM oil fed, water cooled turbos,Forgive a newbie question, but could you explain a little what that means. I have been told about oil under pressure supplying turbo bearings, but how is the water used? Is there a water jacket that is used to remove heat from the bearings or something?<{POST_SNAPBACK}> Link to comment Share on other sites More sharing options...
mattpwc Member 51 Member For: 20y 8m 16d Location: New Zealand Posted 27/10/04 09:19 AM Share Posted 27/10/04 09:19 AM oil fed, water cooled turbos,Forgive a newbie question, but could you explain a little what that means. I have been told about oil under pressure supplying turbo bearings, but how is the water used? Is there a water jacket that is used to remove heat from the bearings or something?<{POST_SNAPBACK}>This is cut and pasted from another thread as I dont know how to link... please forgive me... Ford used the thermosyphon trick..how it works simply,turn off donk,turbo hot boils coolant,boiling coolant rises up the pipe which means new coolant flows in,so you get a flow of coolant moving around and around with out the water pump running.Pretty neat trick that,good for around town stuff.If you do a track day and sting the living sh!t out of it,you should let it run a bit before shut downVik Link to comment Share on other sites More sharing options...
Blown BA In Your Face Member 6,195 Member For: 21y 11m 12d Gender: Male Location: Peninsula Posted 27/10/04 09:40 AM Share Posted 27/10/04 09:40 AM oil fed, water cooled turbos,Forgive a newbie question, but could you explain a little what that means. I have been told about oil under pressure supplying turbo bearings, but how is the water used? Is there a water jacket that is used to remove heat from the bearings or something?<{POST_SNAPBACK}>Ford used the thermosyphon trick..how it works simply,turn off donk,turbo hot boils coolant,boiling coolant rises up the pipe which means new coolant flows in,so you get a flow of coolant moving around and around with out the water pump running.Pretty neat trick that,good for around town stuff.If you do a track day and sting the living sh!t out of it,you should let it run a bit before shut downVik<{POST_SNAPBACK}> Link to comment Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 5m 28d Gender: Male Location: Perth, WA Posted 28/10/04 03:12 AM Share Posted 28/10/04 03:12 AM Cool that answers a question I had as to why ford havent documented anywhere the need to let the turbo idle after some hard driving. Link to comment Share on other sites More sharing options...
