  • Replies 319
  • EMS makes MAGIC MUMBO !
  • Member For: 21y 6m 6d
Hey everyone,
Macka mentioned his shaker was to be tested on a stock T, well that test was completed this afternoon.
Now before you start asking for Dyno graphs, I have them, but need to wait until Monday at work to scan them to be able to post them !
The car is a Stock T with a manual gearbox
Rear wheel figure with standard intake 210KW
Rear wheel figure with Macka's Shaker 227KW :msm:
That's a 17KW gain or an 8% power increase at the wheels ! :w00t2:
Yes the figure was repeatable with additional runs confirming the increase.
So in addition to the appearance, there is quite a significant performance gain to be had !
The only problem with it was that Macka took it back once the test was completed :whistle:
All in all a very good result for all the effort, money, and time that Macka has put in to the Shaker. Thanks Macka ! :spoton:
Pretzel
  • Member For: 21y 22d
1axr, the filter is mounted inside the shaker itself. The filter I used is a BMC flat panel filter. It will take a stock factory one or K&N or any other brand that uses the factory dimensions.
The oil filler location will be relocated to another location on the rocker cover and an exchange program for this item will be offered.
macka
  • Member For: 22y 4m 20d
HI Macka,
Were you at a workshop in Louvain St Coburg today by any chance? Cause if you weren't then there is another white ute running a shaker setup. :whistle:
No I didn't see you there, I am a mate of the mechanic across the road from where you were. I saw the blueprint sedan out the front though so maybe you were still inside.
When I got there the boys said that there was a white turbo with a shaker across the road earlier and I thought it must have been you. Small world mate. :spoton:
Hi Vik,
It's a pity you don't live in melbourne I could have put it on yours as well. :spoton:
Unfornatually their seems to be quite a variation in the cars of the showroom. Don't be too concerned mine started at 170kw as well
macka
