turbocorty Donating Members 178 Member For: 21y 7m 8d Gender: Male Location: Melbourne Posted 01/11/04 03:34 PM Share Posted 01/11/04 03:34 PM Hi,I am not a specialist, but I am fairly sure that its a problem in the ignition timing (algorithm / map) that’s causing the over boost.I have experienced this problem when tuning my engine (250) which has an external wastegate set at 8psi. By just altering the timing curve, I was getting unstable boost peeking way above the preset level. Usually too much advance and too aggressive a curve would bring it on.Most BA complaints of this problem are when the temp is low and the car has been cruised for a while, indicating that Ford engineers must be peeking the timing to get the best fuel economy in cold conditions. When you nail it, the computer must be still using the "advanced" timing causing the boost to increase in an unpredictable manner.This would explain why one of the engine tuners can eliminate the problem, yet others can't.But then again..I could be totally wrong...Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/13481-newsflash/page/7/#findComment-181929 Share on other sites More sharing options...
Guest Guests Posted 01/11/04 04:05 PM Share Posted 01/11/04 04:05 PM turbocorty said: Hi,I am not a specialist, but I am fairly sure that its a problem in the ignition timing (algorithm / map) that’s causing the over boost.I have experienced this problem when tuning my engine (250) which has an external wastegate set at 8psi. By just altering the timing curve, I was getting unstable boost peeking way above the preset level. Usually too much advance and too aggressive a curve would bring it on.Most BA complaints of this problem are when the temp is low and the car has been cruised for a while, indicating that Ford engineers must be peeking the timing to get the best fuel economy in cold conditions. When you nail it, the computer must be still using the "advanced" timing causing the boost to increase in an unpredictable manner.This would explain why one of the engine tuners can eliminate the problem, yet others can't.But then again..I could be totally wrong...Cheers<{POST_SNAPBACK}>good theory who knows havnt seen enough of them doing it to know! macka's was definately way to lean causing knock! increase in timing can also cause knock! cruising along cool air with the air box full stab the throttle the air rush causing overboost. or cruising along and the mixtures leaning of stab the throttle an ping. to many good scenario's for my liking just sounds like theve out smarted them selves with all the extra's to stop us modding the T? just an observation! Link to comment https://www.fordxr6turbo.com/forum/topic/13481-newsflash/page/7/#findComment-181932 Share on other sites More sharing options...
Mr X Donating Members 998 Member For: 21y 9m 14d Gender: Male Location: Adelaide Hills Posted 02/11/04 08:03 AM Share Posted 02/11/04 08:03 AM Dynowog said: turbocorty said: Hi,I am not a specialist, but I am fairly sure that its a problem in the ignition timing (algorithm / map) that’s causing the over boost.I have experienced this problem when tuning my engine (250) which has an external wastegate set at 8psi. By just altering the timing curve, I was getting unstable boost peeking way above the preset level. Usually too much advance and too aggressive a curve would bring it on.Most BA complaints of this problem are when the temp is low and the car has been cruised for a while, indicating that Ford engineers must be peeking the timing to get the best fuel economy in cold conditions. When you nail it, the computer must be still using the "advanced" timing causing the boost to increase in an unpredictable manner.This would explain why one of the engine tuners can eliminate the problem, yet others can't.But then again..I could be totally wrong...Cheersgood theory who knows havnt seen enough of them doing it to know! macka's was definately way to lean causing knock! increase in timing can also cause knock! cruising along cool air with the air box full stab the throttle the air rush causing overboost. or cruising along and the mixtures leaning of stab the throttle an ping. to many good scenario's for my liking just sounds like theve out smarted them selves with all the extra's to stop us modding the T? just an observation!You reckon they're that smart DW?I don't think so! Link to comment https://www.fordxr6turbo.com/forum/topic/13481-newsflash/page/7/#findComment-182250 Share on other sites More sharing options...
Guest Guests Posted 02/11/04 12:15 PM Share Posted 02/11/04 12:15 PM You reckon they're that smart DW?I don't think so!<{POST_SNAPBACK}>certainly did not expect that answer! give them a break theyll work it out probibly not the dealers but but the ford engineers will Link to comment https://www.fordxr6turbo.com/forum/topic/13481-newsflash/page/7/#findComment-182341 Share on other sites More sharing options...
Dr Z Member 378 Member For: 21y 2m 16d Posted 03/11/04 01:03 AM Share Posted 03/11/04 01:03 AM Since I went APS Phase II with Spiro at Autotech, not a single overboost. Link to comment https://www.fordxr6turbo.com/forum/topic/13481-newsflash/page/7/#findComment-182454 Share on other sites More sharing options...
Guest Guests Posted 03/11/04 04:12 PM Share Posted 03/11/04 04:12 PM Dr Z said: Since I went APS Phase II with Spiro at Autotech, not a single overboost. <{POST_SNAPBACK}>as ive said in previous posts spiro does some good work and thus no more hasles. with aftermarket ecu control you can't get it unless the jobs not done right! the only way for you to get more boost is to cap the sensor output so that the ecu never see's the real boost! Link to comment https://www.fordxr6turbo.com/forum/topic/13481-newsflash/page/7/#findComment-182727 Share on other sites More sharing options...
Guest silver toy Guests Posted 05/11/04 11:11 AM Share Posted 05/11/04 11:11 AM Fault found:My xr6t has gone into limp modewhen hot, when coldin auto in manual in performanceon the wrong side of the road x 2on the middle lane of the monash freeway x1total of about 12 episodeshad it reflashed, re checkedtoday ford disabled the ecu for control of turbo ie over boost and state it will work fine in manual boost modeford are testing NEW NEW NEW software for the ecu, will be available in about a monthstill love it, but dammhave sent them a letter from my solicitor advising them I will invoke a coronial inquest if I am in a car accident , and logged calls to customer response team at broadmeadoes, ford are concerned and worried by potential for legal issuewe will win Link to comment https://www.fordxr6turbo.com/forum/topic/13481-newsflash/page/7/#findComment-183442 Share on other sites More sharing options...
Blown BA In Your Face Member 6,195 Member For: 22y 1m 29d Gender: Male Location: Peninsula Posted 05/11/04 11:14 AM Share Posted 05/11/04 11:14 AM silver toy said: have sent them a letter from my solicitor advising them I will invoke a coronial inquest if I am in a car accident , and logged calls to customer response team at broadmeadoes, ford are concerned and worried by potential for legal issuewe will win<{POST_SNAPBACK}>That's what we want to hear....ACTION well done Link to comment https://www.fordxr6turbo.com/forum/topic/13481-newsflash/page/7/#findComment-183443 Share on other sites More sharing options...
Guest Guests Posted 05/11/04 11:37 AM Share Posted 05/11/04 11:37 AM silver toy said: Fault found:My xr6t has gone into limp modewhen hot, when coldin auto in manual in performanceon the wrong side of the road x 2on the middle lane of the monash freeway x1total of about 12 episodeshad it reflashed, re checkedtoday ford disabled the ecu for control of turbo ie over boost and state it will work fine in manual boost modeford are testing NEW NEW NEW software for the ecu, will be available in about a monthstill love it, but dammhave sent them a letter from my solicitor advising them I will invoke a coronial inquest if I am in a car accident , and logged calls to customer response team at broadmeadoes, ford are concerned and worried by potential for legal issuewe will win<{POST_SNAPBACK}>How about a copy of the letter to ford,so we can all down load it,put our names on it,and send it off.I hate this car now after the over boost incedent!!! Wonder if ford is in partnership with bill gates???the car runs as good as windows vik Link to comment https://www.fordxr6turbo.com/forum/topic/13481-newsflash/page/7/#findComment-183451 Share on other sites More sharing options...
XR6_ED Member 1,517 Member For: 22y 1m 24d Posted 05/11/04 11:57 AM Share Posted 05/11/04 11:57 AM MK II has 3 extra switches on the dash for overboost situations..Just have to press these 3 switches labelled CTRL , ALT , DEL Link to comment https://www.fordxr6turbo.com/forum/topic/13481-newsflash/page/7/#findComment-183461 Share on other sites More sharing options...
