Whats Bigger than the 968's injectotrs
xlr8ed
  • FORD FORD FORD
  • Member For: 21y 10m 28d
Hey Jeff,
I got some 19mm Garden hose if you want, 400rwkw ya crazy kid. Ya better get a drop tank fitted while you are at it, what capacity do the fuel lines carry tank to donk?
Scotty
  • Wanabe mechanical engineer
  • Member For: 20y 4m 28d
Dunno, but I bet those lines would need to be the diameter of a drain pipe just to get enough fuel up there!
lol :D
  • Phantom lives
  • Member For: 20y 9m 24d
Hey Jeff,
Scotty
So far I have to run a 600hp in tank pump to a surge tank then a 7-800hp pump to the injector rail.. But as for injectors I may have to use the bosch 363,s...
jeff
  • Member For: 20y 6m 1d
you should have a look around instead of just sticking with bosch stuff, there are a lot of brand around that will fit in the T's with out any mods, I can pretty much get anything from 500cc to 1600cc that will fit straight in, my pick would be the MSD 720cc jobs.
dale
  • Phantom lives
dale
Thanks Dale I did that and I got some Rochester 750cc injectors which is getting fitted as I type...Thanks to all for sound advice..
Except Scotty's garden hose trick, my misses attacked me for chopping up the hose... :kissmy:
jeff
dale
Except Scotty's garden hose trick, my misses attacked me for chopping up the hose... :glad:
jeff
rochester-MSD = same :)
MSD branded ones are cheaper for some reason!
  • Phantom lives
Ok tried the rochesters and they are no good..Cant take enough fuel out of them to run on idle.. So now fitting the 363's...
jeff
jeff
<{POST_SNAPBACK}>
the uni chip couldnt pull enough fuel out?? I have seen this before with uni chips on other cars,
when you start making big power you are going to need bigger squirters than the 363's, you might have to look at a managment upgrade
Dale
