  • Member For: 22y 2m 18d
Now that I have been running the ute for a couple of weeks I am keen to experiment a bit with the tyre pressures.
What pressures front and rear have all you ute guys found to be best?
https://www.fordxr6turbo.com/forum/topic/13313-tyre-pressures/
  • Member For: 22y 6m 4d
Start with 40 psi front and 36 psi rear - if you put it down the strip drop your rears to 20 psi.
If you are towing or load her up put 40 psi in the rears.
Keep a close eye on your rear tyre wear - if they start to wear in the centres drop the pressure by 2 - 4 psi. And, if you do this you may then also have to drop your fronts to 38 psi.
