Guest Guests Posted 07/10/04 02:14 AM Share Posted 07/10/04 02:14 AM yeah dont doubt it its just that as I said I dont know much about gtechs Link to comment https://www.fordxr6turbo.com/forum/topic/13272-accuracy-of-g-tech-performance-timers/page/2/#findComment-173459 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 8m 24d Gender: Male Location: Newcastle Posted 07/10/04 02:22 AM Share Posted 07/10/04 02:22 AM I have a G-Tech Pro Competition and the power, torque readings can be quite accurate when the right vehicle weight is entered. I weighed my car on a weigh bridge before doing runs and I was quite suprised at the results. I can also down load the data to my PC and print all the graghs of time, torque, power etc. It's a great device and fun to use. Link to comment https://www.fordxr6turbo.com/forum/topic/13272-accuracy-of-g-tech-performance-timers/page/2/#findComment-173462 Share on other sites More sharing options...
turb06 Dark Knight Mafia Member No. - 666 Member 3,667 Member For: 22y 2m 4d Location: Toowoomba Posted 07/10/04 02:25 AM Author Share Posted 07/10/04 02:25 AM I take it this is the newer version that superseeded the one I have, how much was it?Dazza. Link to comment https://www.fordxr6turbo.com/forum/topic/13272-accuracy-of-g-tech-performance-timers/page/2/#findComment-173464 Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 22y 1m 13d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 07/10/04 03:31 AM Share Posted 07/10/04 03:31 AM 14.5 quite acceptable for a stockie at "the bank"Scotty Link to comment https://www.fordxr6turbo.com/forum/topic/13272-accuracy-of-g-tech-performance-timers/page/2/#findComment-173489 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 2m 16d Gender: Male Location: Sydney Posted 07/10/04 03:35 AM Share Posted 07/10/04 03:35 AM Have a look at www.gtechpro.com, the GTech Pro Comp has been discontinued and replaced with the RR and SS versions. US$299.95 for the RR version is great value...now all I need is for them to make it in blue backlighting Link to comment https://www.fordxr6turbo.com/forum/topic/13272-accuracy-of-g-tech-performance-timers/page/2/#findComment-173491 Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 7m 21d Gender: Male Location: Mildura Posted 07/10/04 05:21 AM Share Posted 07/10/04 05:21 AM Benny said: I have a G-Tech Pro Competition and the power, torque readings can be quite accurate when the right vehicle weight is entered. I weighed my car on a weigh bridge before doing runs and I was quite suprised at the results. im still scepticle..fair enuf u weighed your car.. say it was 1500kg. fair enough.BUT my poitn still stands if u change the diff ratio to a shorter gearing the acceleration is still going to be stonger and faster than the stock diff.. therefor making the power figures to be greater than they should be..its to easy to fool if it just runs of g-forces.. Link to comment https://www.fordxr6turbo.com/forum/topic/13272-accuracy-of-g-tech-performance-timers/page/2/#findComment-173549 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 2m 16d Gender: Male Location: Sydney Posted 07/10/04 05:37 AM Share Posted 07/10/04 05:37 AM I understand what you are saying, but the HP is not just calculated by G's.The unit will measure gearchanges, RPM, curb weight, G's and even the squat of the car when you launch. It is a very impressive piece of equipment for the AU$400 it costs. While I would not think it is perfect, I would think with the accurate figures, it would be -/+10% on its readings.It is not a replacement for the drags, but a handy tuning tool just as a dyno is Link to comment https://www.fordxr6turbo.com/forum/topic/13272-accuracy-of-g-tech-performance-timers/page/2/#findComment-173556 Share on other sites More sharing options...
Guest Guests Posted 07/10/04 05:41 AM Share Posted 07/10/04 05:41 AM Trough Lolly said: [bUT my poitn still stands if u change the diff ratio to a shorter gearing the acceleration is still going to be stonger and faster than the stock diff.. therefor making the power figures to be greater than they should be..its to easy to fool if it just runs of g-forces.. in this case the shockers if stuffed will allow more movement body roll showing more g's for a split second. I think the makers would have used a g sensor that compensates for this. still scepticle like you though Link to comment https://www.fordxr6turbo.com/forum/topic/13272-accuracy-of-g-tech-performance-timers/page/2/#findComment-173557 Share on other sites More sharing options...
poida97 Member 124 Member For: 21y 2m Location: Bossley Park, NSW Posted 07/10/04 06:19 AM Share Posted 07/10/04 06:19 AM In my opinion G-techs are far more consistent than dynos in their power readings. Dynos (as we are all aware) have great variances between each other and need to be recalibrated to maintain accuracy. There are also too many variables that need to be monitored in order to compare different dyno's readings.G-techs work by measuring acceleration and time and they use those to calculate torque and power at the wheels. It is all mathematics. You can calculate the average net power developed at the wheels of any car with a quarter-mile timeslip printout. Is it an accurate figure? It is exact. The problem is that it includes power-sapping losses due to wind resistance, lack of traction, driveline friction, temperature, humidity, and driver ability. For that reason it is not the exact power that the car PRODUCES (the GROSS power output).Your car's engine may be capable of producing 500 horses and it may be capable of running a 12 second quarter- but if you do the run at half throttle and it takes you 20 seconds- will a G-tech still show 500 hp? Of course not. The same applies to a dyno. Dynos have that one extra variable- that is that they need to be correctly calibrated. Link to comment https://www.fordxr6turbo.com/forum/topic/13272-accuracy-of-g-tech-performance-timers/page/2/#findComment-173578 Share on other sites More sharing options...
Turbo6man Lifetime Members 4,084 Member For: 22y 6m 19d Gender: Male Location: South Coast NSW Posted 07/10/04 06:32 AM Share Posted 07/10/04 06:32 AM Trough Lolly said: Benny said: I have a G-Tech Pro Competition and the power, torque readings can be quite accurate when the right vehicle weight is entered. I weighed my car on a weigh bridge before doing runs and I was quite suprised at the results.im still scepticle..fair enuf u weighed your car.. say it was 1500kg. fair enough.BUT my poitn still stands if u change the diff ratio to a shorter gearing the acceleration is still going to be stonger and faster than the stock diff.. therefor making the power figures to be greater than they should be..its to easy to fool if it just runs of g-forces.. Diff ratios, wheel sizes, gear ratios have zero input to the G-Tech's calculations. It uses the force of accelleration measured over time - simple, no more no less. If you enter correct weight it can also calculate power. As has been said, it is a true or "real time" measurement of the force/power applied to the wheels and the power readings will be lower than what a dyno will show because it takes into account ALL outside variables acting upon the vehicle at the time of the "run". If you're skeptical (or can't spell), go learn some physics or get a technical buletin from G-Tech to understand how it's done. And, as for accuracy it is more in the order of 1% not 10%. BUT - like any instrument it is only as good as the operator and errors can easily creep in if not used exactly according to the "book". Link to comment https://www.fordxr6turbo.com/forum/topic/13272-accuracy-of-g-tech-performance-timers/page/2/#findComment-173582 Share on other sites More sharing options...
