Ezy10z Member 211 Member For: 21y 10m 1d Location: Ballarat Posted 02/10/04 02:11 AM Share Posted 02/10/04 02:11 AM rusht said: I understand that the Territory RWD and AWD have very similar 0-100 times, but only because the heavier AWD has a different diff ratio to compensate. Therefore, same diff - slower AWD.When I had a WRX the AWD I reckon was a disadvantage most of the time as you could not break traction when launching, it absorbed more power (drivetrain loss) and made the car heavier. It became an advantage only when traction was an issue, ie wet roads and roundabouts. I always wondered if you could disable and remove the front WRX diff to get rid of the weight to see how it went. I think a RWD WRX (not heavily modifed where the traction was required) would have a better power to weight and would be quicker and understeer a hell of a lot less.This thread started by looking at AWD as an option to 450kW through the rear wheels only. Obviously the weight and drivetrain loss would be worth it in this case. I agree that it can be difficult to get a good start in a WRX due to the traction and bogging down. But once you do some basic mods it's not that hard to get the front wheels spinning and a better launch but you really need some wheelspin to get a good a good launch especially at Calder. I found that on a normal bituman even with basic mods 5500rpm will spin the wheels no problem but at calder bogged down so much the revs went below 3000rpm so had to dump the clutch at 6000rpm +++Robbie. Link to comment https://www.fordxr6turbo.com/forum/topic/13040-awd-xr6t/page/5/#findComment-171589 Share on other sites More sharing options...
rusht Member 198 Member For: 20y 9m 29d Posted 02/10/04 03:21 AM Share Posted 02/10/04 03:21 AM Ezy10z said: I found that on a normal bituman even with basic mods 5500rpm will spin the wheels no problem but at calder bogged down so much the revs went below 3000rpm so had to dump the clutch at 6000rpm +++Robbie. Robbie,Dumping clutches at 5500-6000 rpm sounds expensive. Link to comment https://www.fordxr6turbo.com/forum/topic/13040-awd-xr6t/page/5/#findComment-171599 Share on other sites More sharing options...
Guest Guests Posted 06/10/04 12:18 PM Share Posted 06/10/04 12:18 PM turbo territory sounds fine, awd xr6t dont sound like good value for money unless you want to make a statement to which you must start with a large bank statement! Link to comment https://www.fordxr6turbo.com/forum/topic/13040-awd-xr6t/page/5/#findComment-173327 Share on other sites More sharing options...
FPV GTHO Member 118 Member For: 20y 8m 24d Posted 06/10/04 12:21 PM Share Posted 06/10/04 12:21 PM umm....the cars already 450kw, its lost plety of value already...AWD may even increase it for its exclusitivity Link to comment https://www.fordxr6turbo.com/forum/topic/13040-awd-xr6t/page/5/#findComment-173328 Share on other sites More sharing options...
