  • Replies 64
  • Member For: 22y 6m 15d
I have. As my neighbour has an XR6T with standard brakes. I just picked up my car from service. they used the brake trest machine on it and reported a 30% brake performance differential over the standard BA brakes.
My car has premiums and they are very good and in my view essential for this car to stop effectivley.
The stopping distance is fantastic.....
  • Member For: 22y 5m 26d
I've also noticed that the brakes to work very good when there cold, for example if you tack of up the street to about 85k/h and try slowing down there doesn't seem to be much bite.
OK, I spoke to Rob Herrod today and he has a 4 pot caliper and bigger rotors to bolt straight onto our cars for $5500 + installation, keep in mind this price is for 4 pots all round front and back, so when you compare the $3000 + 5% stamp duty for the factory premium brake package which only bolts new calipers to the front it's not a bad price.
I think I might go with these and end my braking issues, I think I might express deliver my standard brakes to Mr Polites and asking to smash them over the heads of the engineers who choose these crappy brakes. :D
I have driven both. Fast.
Premium no question about it. If brakes are an issue at all for you, spend the money on them. This car can deliver serious speed and there are times when you need to stop. Fast.
See its simple!
No point going on about the value. They are integrated and tested and they work well.
  • Member For: 22y 5m 2d
well from what I can tell from all the specs I've read, you'd be better off just getting the standards and putting DBA cross-drilled and slotted discs and some bendex Ultimates (or better) pads on, that would stop as good if not better then premiums and cost almost 1/3 the price.....
Dave.....
  • Bored Member
  • Administrator
  • Member For: 22y 7m 6d
Bit of info from Dattoman (PF members will know who i mean):
  Quote
Standard brakes DBA504 front 298mm x 28mm
DBA505 rear 303mm x 16mm
Performance brake option DBA506 Front 329mm x 28mm
both these are eliptically slotted
GT Brembo option 355mm x 32mm (I think) front disc with S type jag 4 piston caliper (since Jag and Ford are in bed together it seems logical to use something out of their parts bin)
rear brembo is DBA507 28mm thick vented with a smaller caliper
Apparently the GT isn't coming with the Brembos as standard. They are an extra $ option. The AU3 and BA are very similar brakes so I'd say its very close to the Pursuit ute for brakes but with the 506 on the front not 355mm. Though I believe the GT will have very different offset wheels to clear the brakes. So you'd need GT wheels to fit them to other models.
Aftermarket Brembo kits are in development.
  • Member For: 22y 6m 17d
What sh*ts me, is why the hell did they change the brakes from the old AU XR8 anyway. I never had a problem with those.
These brakes are the worst I have ever seen. Sure they stop you, and do it quite well, but if you have to stop quite a few times that's when the problem starts! As soon as they get some heat into them they warp. They don't even get a chance to fade, and even if there was fade you wouldn't be able to tell over the shudder it causes :angry:
I agree with the option of DBA, and the guy who looks after my car suggested that, however shouldn't the point be that Ford at least produce brakes that work on the car that they were designed to STOP! :nugget: This is a 240kW 1800kg family sedan!
  • Poison Fish. Poison Fish. TASTY FISH!!!
  • Member For: 22y 3m 5d
There was a point made back away somewhere it IS a FAMILY sedan.but who will treat it like one?Like my brother who bought a WRX over a mustang because it had 4 doors for his kid.....
From all accounts I have heard that DBA are very good brakes and it seems they keep coming up with new innovations however a word of warning when it comes to Cross-drilling,if your looking for show,fine they are so nifty BUT any hard stopping continuously(Track days,GT Production...)will have cracks start from around the Drilled holes.This is why Skyline GTRs and Supercars etc run only slotted brakes.Well so I have read
From what I have been told and read the standard callipers are warping when hey heat up, so dba rotors wont really help.
4 pots all round is the answer!!!!!
