  • Flower Power
  • Member For: 22y 8m 26d
Easy terms..
The latest Pentium processor is faster (by processing speed) than the latest celeron processor.
Pentium processors have a greater load capacity.
  • The Noble Leader
  • Administrator
  • Member For: 22y 8m 25d
Celeron CPU has less cache memory than Pentium 4's do. A Celeron might have 128 kilobytes of L2 cache, while a Pentium 4 can have four times that. The amount of L2 cache memory can have a big effect on performance.
Clock speed - Intel manufactures the Pentium 4 chips to run at a higher clock speed than Celeron chips. The fastest Pentium 4 might be 60 percent faster than the fastest Celeron.
Bus speed - There are differences in the maximum bus speeds that the processors allow. Pentium 4s tend to be about 30 percent faster than Celerons.
Basically at the end of the day the Celeron is a less gruntier chip then the Pentium 4, it cant handle the amount of processes the Pentium 4 can do, and cant send information faster enough down to other devices via the bus.
For Performance go Pentium 4, anything else go Celeron ie email etc.
You should check out my PC site.. have the latest news and stuff.. also some of my reviews of PC hardware..
www.auspcworld.com for you IT geeks :)
  • In Your Face
  • Member For: 22y 3m 27d
If you want 'bang-for-buck', get an AMD Athlon CPU.
e.g.
AMD Athlon XP 3200+ $282
Intel Pentium IV 3.2GHz $429
<I>Prices from http://www.fluidtek.com.au/</I>]http://www.fluidtek.com.au/ </I>
I find the AMD athlon XP faster than the Pentium 4.
Guest casgeroth
  • Guests
The last 3 PC's I've built (for myself) have been AMD machines. I've found them to be a lot more reliable and of course better for overclocking. But this is sidetracking from the thread topic a bit. From the sound of it Falchoon has the option of buying either a Celeron or a Pentium.
It would depend on what you're going to use it for. If it's everyday surfing the net, email, some basic Word documents etc... the Celery will do the job, but if you want to start gaming and using it for heavier applications you will want the P4.
Edited by casgeroth
What are the differences in non-geek speak please :spoton: between these computers. :sleepystuff:
One is like a Rolls Royce and the other is a Bentley Mulsanne twin turbo ...
