  • Member For: 21y 8m 17d
there are a couple of dyno days coming up at MRC in castle hill sydney.
My ute has had the centre muffler removed, so if anyone is interested in having a listen pop down to the dyno days and will kindly give anyone a listen if they ask. Excellent note not droney in car.
  • Replies 28
Guest XR6Twish
  • Guests
Hey guys, sorry its taken me a while gettin back to you. Not been around the puter all that much.
You know, we could all sprout on about how good a second dump pipe for the wastegate would be and so it goes, however until someone actually fabricates a twin pipe dump that actually works better than the factory item in "back to back testing", well, then there is no proof.
Genius aren't I! Fact is, until this happens I am absolutely sticking to my story. If on the other hand it can be proven, then great, that's awesome.
Only problem I see is that showing a before and after dyno sheet without actually witnessing the runs yourself, makes it quite difficult. You know why of course. Because whos to say that between the first and second run, boost is wound right up and other mods are undertaken.
It would be great if someone looking to do a twin dump pipe contatcs a magazine and they do a story on it. That way we would see if it was for real.
Geting back to my first post, the only time I believe a twin jobbie would be used is once you upgrade to a much bigger turbo and extractors.
  • Dark Knight Mafia Member No. - 666
  • Member For: 22y 3m 13d
I will post some dyno results of when I get mine done, I will have it dynod again shortly because I have had a few mods since the last time it was on the rollers and it will be dynod again after the dump pipe goes on (wont be for about 3-4 weeks).
It will be done on the same dyno in the same mode and the boost cant be wound up as I dont have a chip as yet, xlr8ed and JPM86 can confirm this.
Dazza.
  • ASHA - Anti Stooge Hunter Association
  • Member For: 21y 11m 27d
Guys, I have a mate that owns an exhaust shop and we did some research into exhausts for the T. Here are my results:
I dyn'o'd the car;
Standard - 202.5 rwKw
Cat back dual 2.5" system - 201.3 rwKw
3" single cat back system - 203.7 rwKw
3" single cat back with no centre muffler - 205.3 rwKw
3" single from dump pipe back including hi flow 3" cat - 213.6 rwKw.
Further information - the car was dynod on saturdays at approx 1pm by the same dyno operator on the same dyno (note I did this to keep in consistant). Also note that the car was running optimax.
As far as the dump pipe is concerned I am about to start work on the dump pipe and run the car through another dyno run. When I get it done, ill let you guys know.
Regz,
Dean
  • Member For: 22y 7m 29d
OK so you don't get on the 'puter much, but when you did there were at least two direct questions put to you that you have chosen not to answer.
Next time on could you please address these as there are many people here interested in what you have to say if you can back it up?
I dyn'o'd the car;
Regz,
Dean
Dean since you know your way around an xr6t exhaust, can you tell me if the stock exhaust is dual 2" or 2.25" I have never known this and it sh*ts me.
Dazza.
  turb06 said:
I dyn'o'd the car;
Regz,
Dean
Dazza.
Dazza,
The standard exhaust on the T is comprised of a 3" dump pipe to the cat, followed by a 2.25" twin exit from the back of the cat to the end of the system.
Regz
Dean
PS Dazza, if you want pics or anything let me know, ive got the std system sitting on my garage floor :)
Edited by XR6ISM
  XR6ISM said:
  turb06 said:
I dyn'o'd the car;
Regz,
Dean
Dazza.
Dazza,
Regz
Dean
No pics needed, you have more than answered my question.
Thanks.
Dazza.
  • Member For: 22y 4m 21d
Difilippo has a 3" dump pipe with seperate 1 3/4" wastegate pipe, which can be bought seperately. They also have a Hi-flow cat, join this up to the standard system with the centre muffler removed and I think you'd be on a winner...
Here's the webpage if anyone wants a look...
http://www.darrendifilippo.com.au/ford_sys.html
Dave.
