ExAreSix TRAITOR Member 1,063 Member For: 22y 7m 17d Gender: Male Location: Townsville, NQ Posted 24/08/04 07:42 AM Share Posted 24/08/04 07:42 AM fordboy1981 said: ExAreSix said: And std cat is quite a good unit. Better than the aftermarket high flow cat I had installed (25rwkw better in fact)Just a shame the std cat couldn't handle the power. that doesn't make sense dude! if the standard cat makes 25rwkws more then your current aftermarket cat, then it does handle the power and your aftermarket one doesn't!!please explain??Dave. Sorry... Was a bit vague.My standard cat collapsed. It shat itself. It flowed great... 25rwkws better than my aftermarket job. Till the 'brick' collapsed and blocked itself up. Link to comment https://www.fordxr6turbo.com/forum/topic/12493-standard-exhaust-with-free-flow-downpipe-and-cat/page/2/#findComment-157936 Share on other sites More sharing options...
Guest XR6Twish Guests Posted 24/08/04 07:49 AM Share Posted 24/08/04 07:49 AM Quote Std dump pipe is NOT of efficient design.Have you actually had a close look at the factory dump? I think you will find - irrespctive of what you refer to in the other thread - it is a good thing. Producing a fabricated dump pipe with a secondary wategate pipe is a great idea - but only once you start getting really serious. For applications like most of us are using, I seriously don't think it's worth considering.Stick with the factory dump I say.Actually, having said that I think I need one, a dump that is Link to comment https://www.fordxr6turbo.com/forum/topic/12493-standard-exhaust-with-free-flow-downpipe-and-cat/page/2/#findComment-157937 Share on other sites More sharing options...
ducatijb Lifetime Members 3,448 Member For: 22y 2m 3d Gender: Male Location: sydney Posted 24/08/04 07:58 AM Share Posted 24/08/04 07:58 AM XR6Twish said: Producing a fabricated dump pipe with a secondary wategate pipe is a great idea - but only once you start getting really serious. For applications like most of us are using, I seriously don't think it's worth considering.Stick with the factory dump I say.Actually, having said that I think I need one, a dump that is XR6Twish,at what power levels would you say the factory dump pipe is good to?? Link to comment https://www.fordxr6turbo.com/forum/topic/12493-standard-exhaust-with-free-flow-downpipe-and-cat/page/2/#findComment-157941 Share on other sites More sharing options...
Turbo6man Lifetime Members 4,084 Member For: 22y 7m 26d Gender: Male Location: South Coast NSW Posted 24/08/04 08:04 AM Share Posted 24/08/04 08:04 AM XR6Twish said: Quote Std dump pipe is NOT of efficient design.Have you actually had a close look at the factory dump? I think you will find - irrespctive of what you refer to in the other thread - it is a good thing. Producing a fabricated dump pipe with a secondary wategate pipe is a great idea - but only once you start getting really serious. For applications like most of us are using, I seriously don't think it's worth considering.Stick with the factory dump I say.Actually, having said that I think I need one, a dump that is On what experience do you base this please?If you have read the other thread that was identified above, could you please rationalise for us if you have better information? Link to comment https://www.fordxr6turbo.com/forum/topic/12493-standard-exhaust-with-free-flow-downpipe-and-cat/page/2/#findComment-157944 Share on other sites More sharing options...
ExAreSix TRAITOR Member 1,063 Member For: 22y 7m 17d Gender: Male Location: Townsville, NQ Posted 24/08/04 08:21 AM Share Posted 24/08/04 08:21 AM XR6Twish said: Quote Std dump pipe is NOT of efficient design.Have you actually had a close look at the factory dump? I think you will find - irrespctive of what you refer to in the other thread - it is a good thing. Producing a fabricated dump pipe with a secondary wategate pipe is a great idea - but only once you start getting really serious. For applications like most of us are using, I seriously don't think it's worth considering.Stick with the factory dump I say.Actually, having said that I think I need one, a dump that is Yes, I've seen the standard dump. Was a pleasant surprise to see it was quite a large diameter dump.BUT both Wastegate and Exhaust gases flow through it. I'm no expert on the subject, but I would imagine that having two gas streams, both at differing velocities (Wastgate being on/off), running into each other in a confined space, would cause quite a bit of turbulence.Turbulence is bad, mmkay.Having the wastagate gases introduced to the exhaust system after the initial bends in the dump pipe would substantially minimize turbulent flow through the rest of the exhaust.That's my understanding. Link to comment https://www.fordxr6turbo.com/forum/topic/12493-standard-exhaust-with-free-flow-downpipe-and-cat/page/2/#findComment-157952 Share on other sites More sharing options...
Biggy Member 47 Member For: 21y 1m 7d Location: Mount Annan , NSW Posted 24/08/04 08:43 AM Author Share Posted 24/08/04 08:43 AM I was thinking that by having the separate dump pipe system including a good free flow cat and the rest standard then for most how wish not to spend great sums of money could have a eng that would breath that bit better. Most systems allow you to do the rear first but all you get is noise so why not start at the front since the standard system has a reasonable note already. The MRC front pipe into the standard system would be the way to go.?Biggy Link to comment https://www.fordxr6turbo.com/forum/topic/12493-standard-exhaust-with-free-flow-downpipe-and-cat/page/2/#findComment-157964 Share on other sites More sharing options...
ExAreSix TRAITOR Member 1,063 Member For: 22y 7m 17d Gender: Male Location: Townsville, NQ Posted 24/08/04 08:52 AM Share Posted 24/08/04 08:52 AM Biggy said: The MRC front pipe into the standard system would be the way to go.?Biggy I reckon so My plan also... Though I might get a custom dump made, but similar to MRC.Keep us updated if you go ahead. Before and after dyno prints a must! Link to comment https://www.fordxr6turbo.com/forum/topic/12493-standard-exhaust-with-free-flow-downpipe-and-cat/page/2/#findComment-157967 Share on other sites More sharing options...
turb06 Dark Knight Mafia Member No. - 666 Member 3,667 Member For: 22y 3m 11d Location: Toowoomba Posted 24/08/04 09:41 AM Share Posted 24/08/04 09:41 AM Biggy said: I was thinking that by having the separate dump pipe system including a good free flow cat and the rest standard then for most how wish not to spend great sums of money could have a eng that would breath that bit better. Most systems allow you to do the rear first but all you get is noise so why not start at the front since the standard system has a reasonable note already. The MRC front pipe into the standard system would be the way to go.?Biggy Biggy - I agree that would be a way to go, I think even on a near stock or stock engine the changing of the dump pipe would be good, I am getting a local exhaust shop to make me one to hopefully save some $$$ and put on a high flow cat too.I also chopped the centre muffle section out, I did this to make it a bit louder. I would suggest doing this also as word is the centre muffler isnt the best straight through mufler, and if you find it a bit too loud chuck some hotdogs on to shut it up a little, I think the note with the centre muffler gone to be awesome and not intrusivley loud. Dazza. Link to comment https://www.fordxr6turbo.com/forum/topic/12493-standard-exhaust-with-free-flow-downpipe-and-cat/page/2/#findComment-157998 Share on other sites More sharing options...
Biggy Member 47 Member For: 21y 1m 7d Location: Mount Annan , NSW Posted 24/08/04 10:23 AM Author Share Posted 24/08/04 10:23 AM Hi Turbo6Let us all know how it goes if you do it. Have yet to listen to one with the center muffler out before I do it , want a good deep note not harsh or droney.Biggy Link to comment https://www.fordxr6turbo.com/forum/topic/12493-standard-exhaust-with-free-flow-downpipe-and-cat/page/2/#findComment-158020 Share on other sites More sharing options...
turb06 Dark Knight Mafia Member No. - 666 Member 3,667 Member For: 22y 3m 11d Location: Toowoomba Posted 24/08/04 10:52 AM Share Posted 24/08/04 10:52 AM Biggy said: Hi Turbo6Let us all know how it goes if you do it. Have yet to listen to one with the center muffler out before I do it , want a good deep note not harsh or droney.Biggy will do.The exhaust note is nice and deep, I think it is anyway, its a little loud on startup but give it a few minutes to heat up and it quitens down.Dazza. Link to comment https://www.fordxr6turbo.com/forum/topic/12493-standard-exhaust-with-free-flow-downpipe-and-cat/page/2/#findComment-158026 Share on other sites More sharing options...
