  • Member For: 21y 1m 5d
Just wondering if anyone makes a down pipe and high flow cat that connects to the standard exhaust? Seems like a way to go if you want to keep the system near to original but free the flow up.Correct me if I am wrong the two original mufflers are straight through.
Biggy
  • Replies 28
  • Award Winning Photo guy
  • Member For: 21y 4m 29d
I hear KTford knows a reputable dealer of high performance cats ;)
I think I remember reading though that the turbo pipe on the xr is already free flowing enough.. the restriction is in the rest of the system on low boost applications
  • Member For: 21y 8m 12d
try this for a little info
A post by "brownster" called "new exhaust system"
Post preview number 154253
There is info about exhaust and dump pipes MRC Dyno And Performance are fitting.
Hope this helps
  • ASHA - Anti Stooge Hunter Association
  • Member For: 21y 11m 23d
Biggy
Std dump pipe is 3" already, so you dont need to change that, major restriction with the whole cat section.
you will also gain a couple kw by removing the centre muffler.
Ive tried and tested a couple systems, PM if you want a link to my dyno sheets.
  • TRAITOR
  • Member For: 22y 7m 16d
Check out the thread beauies has mentioned previously.
Showing some huge gains, seemingly by seperating the Exhaust and Wastegate flows from the turbo.
Std dump pipe is NOT of efficient design.
And std cat is quite a good unit. Better than the aftermarket high flow cat I had installed (25rwkw better in fact)
Just a shame the std cat couldn't handle the power. :spoton:
  • Member For: 22y 4m 17d
that doesn't make sense dude! if the standard cat makes 25rwkws more then your current aftermarket cat, then it does handle the power and your aftermarket one doesn't!!
please explain??
Dave.
  • In Your Face
  • Member For: 22y 2m 26d
Just a shame the std cat couldn't handle the power.  :popcorn:
please explain??
Dave.
What he said :fishin:
  • FORD FORD FORD
  • Member For: 22y 2m 18d
I know where you live & work.
Scotty
  • In Your Face
Scotty
:lol: :lol:
