What Build Date is your car?
Guest Maniac
  • Replies 39
  • Just sit back and enjoy the ride...!
  • Member For: 21y 5m 12d
Oct 2003
- Brake Shudder @ 22000km last month
- Broken seal on a water pipe (detected and fixed while in for brake shudder fix)
- Sun Shade peeling off rear window (replaced back in Nov 2003)
- Premium CD Changer refused to play CDs (replaced back in Nov 2003)
Have the complementary set of stone chips and tiny scratches that come with 26000km on the clock in my Black Beast's first ten months. To be expected really.... :spoton:
  • Member For: 21y 10m 22d
Jan 2003, 28,000kms and do you really want me to fill a whole page with one post!!! :nono:
What he said,mines 31/01/03 phantom,slushie
I ended up with a list of 15.. :blink: you ford
vik
.......but I still loooove driving it, still makes me smile. :spoton:
feb 04
tailgate misaligned
drivers door misaligned
rh side window trim lifting
rh rear caliper guide pin misalignment
exhaust tailpipe misaligned
hard to start
tensioner bearing
serpentine belt
timing cover bolt oil leak
harmonic balancer keyway oil leak
cruise control excessive speed flutuation
tonneau cover torn
axle tube to diff centre oil leak
headlight alignment
inconsistent acceleration
tailgate wont open
5th gear selector ring
squeaking rear bushes
clutch...My bad :sofa:
but I still love her :P
  • Member For: 21y 4d
dec03
heat shield rattle (fixed)
warps in hardcover (new lid supplied)
new hardcover has paint blemishes (need to book in to get it repainted)
new lid chipped as fitted incorrectly
driveline shunt (normal :censored: )
rattle in gearbox (replaced gearbox)
rattle in new gearbox (now this is appareantly a common problem and there is no fix for this)
rattle in dash (not found)
surging throughout rev range (car gone into limp mode, new ecu flash twice, now there is no fix for this)
whistle in window (appareatly fixed, but is still there)
rear seal fallen off twice (fixed both times)
leather around gearknob broken (new one ordered under warranty, yet to arrive)
power steering pump shudder (this has gone away by itself WTF?)
handbrake did not work (fixed)
Knock from backend of car (fixed, some bolts aorund the springs or spring area were loose?? dont ask, I have NFI)
A high pitch whine while driving, I have no idea where this is from, yet to show the dealer.
Think that's it :lol:
  • Team "I don't have no Falcon now"
  • Member For: 21y 7m 9d
I'm not saying anything, sig says it all :3gears:
Well Apart from this obviously, oh and what I just wrote above this line too...... :3gears:
Cheers,
Cameron
  • Member For: 20y 11m 23d
Apr04 build
:3gears: Factory Driveline clunk :pooh:
no other problems :3gears:
  • Flower Power
  • Member For: 22y 3m 26d
no other problems :owned:
Except windscreen wipers don't work at 140km/h eh? :banem:
Actually saw some good Apexi gear today that would fix your problem....
  • Member For: 20y 8m 23d
  • Gender: Female
October 03 built
Steering Fault> Oil leak found lower transmission hose loose causing oil leak. Tightened and all was ok.
Exhaust was vibrating at Idle> All adjusted and now ok
No major problems :smilielol:
