August 28 Cruise to Castlemaine
macka'sxr6t
Guest ROCKET
  • Guests
greetings all
guessed you must have been on a cruise, I saw a few of you on our way back from Heathcote, you should have droped in & gave you car a run whilst you were there
Craig you had the chance to compare the Subi to the 6T, it would have been interesting
regards
rod
  • Replies 62
Posted Images
  • Member For: 20y 9m 12d
Hi Daniel,
It's a pity you could'nt make it I was taking people for rides in the ute and they all loved it. As for extra Kw it's hard to say as my car was already producing good power. The shaker would perform better whilst on the road where you get the ramming effect. I can also tell you and the others that went for a ride will verify that the is vitually no lag.
I would like to dyno it on a stock T with a before and after graph, to see what benefits it could make. Mine is too far past stock to change it back.
Two things that I did notice straight away was the fuel economy inproved by 2 lt/100km. Whilst cruising along at 105km the computer was showing 7.2 lt/100 km. Down from 9.5lt/100km. The engine temp was also a lot cooler. Don't know the exact temp drop but it was about 2 needle widths above the 1/4 mark on the temp gauge. It used to run about 2 needle widths below the halfway mark.
Hope this gives you some info that you are after.
macka
