  • Team Blueprint
  • Member For: 21y 5m 12d
Hi Craig
Not sure why you would need one.. unless you are pluging in a mic or a turntable???
PM me and let me know what your trying to do.
  • Award Winning Photo guy
  • Member For: 21y 3m 24d
Alpine also make them... part no. A4311 )converts high power speaker output signals to pre-out level - 2 channels only) so you'll need to get 2 of them.. they are roughly $30 ea...
I've tried the blau ones and I heard stinger are the same, and that is good for loads of SPL but you'll get a bit of engine noise through them..
the Alpine ones are super quite and I can barely notice the difference in sound levels if it is decreased!
good luck
hmm.. best to ask your local audio shop bro.. I would say so.. but I'm no expert :(
  • Member For: 21y 8m 10d
You will need one for your front channels and one for your back channels! =4 ch
I put mine in my boot, you will need to run speaker wire spliced from the other speakers wires then run them into the convertor!
Guest ALEXhaynes
  • Guests
I had the same problems installing a sterio in my BA ute. Decided on buying amps with high level inputs to make the install easy. I have fitted 2 amps, a one channel class D MTX Thunder 421D powering 2 MTX 12 inch subs and a 2 channel MTX running MTX 6.5 inch splits. Have no problems with noise entering the system and am very impressed :loc: as the amps dont need a remote turn on wire, the amps detect the sound from the head unit and turn on (without delays). :msm:
